    Noise Functions
    33 Posts 0 Posters 17.0k Views
      On 05/06/2010 at 09:15, xxxxxxxx wrote:
      Here is an example of the noise I am getting when I apply the Turbulence() noise function to my cube.
      The code I use to do this is:
      Real arr[12];
      	InitFbm(arr,10,0.1,0.5);
      	for (int i = 0; i < pointCount; i++)
      		Real rmf = RidgedMultifractal(arr, points[i], octaves, offset, gain) * 2;
      		Real turb = Turbulence(points[i],octaves, abs) * 2;
      		Real wavturb = WavyTurbulence(points[i],time, octaves, 1) * 2;
      		Real noise = PNoise(points[i], points[i]) * 2;
      		turb = turb * pi;
      		Real turb1 = (1 - cos(turb)) * .5;
      		//RIDGED MULTIFRACTAL
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_RIDGEDMULTIFRACTAL)
      			points[i] = points[i] * rmf;
      		//Turbulence
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_TURBULENCE)
      			points[i] = points[i] * turb;
      		//Wavy Turbulence
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_WAVY_TURBULENCE)
      			points[i] = points[i] * wavturb;
      		//Noise
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_NOISE)
      			points[i] = points[i] * noise;
      This is for all noise functions but you can see within this how I am using the turbulence() function.  I get the same basci result for all the functions.  Just a clutter of noise.
      I would like the have a more even transition between the points so that they are not flying all over the place.  Could anyone guide me toward how I would accomplish this?
      ~Shawn
        On 05/06/2010 at 11:46, xxxxxxxx wrote:
        what about using Real Mix(Real v1, Real v2, Real t) to build certain inbetween values. works with Real and with Vector...
        plus i'd use some slider to adjust the power of each noise type.. maybe add some checkbox for each noise and not just the option to use only one noise. this would enable to create much more different styles
          On 05/06/2010 at 11:47, xxxxxxxx wrote:
          I'll give it a try..  thanks ello
          ~Shawn
            On 05/06/2010 at 11:49, xxxxxxxx wrote:
            😉 that was fast. you replied while i was editing
              On 05/06/2010 at 11:54, xxxxxxxx wrote:
              So someting like this?
              points[i] = Mix(points[i] * turb, points[i], .5);
                On 05/06/2010 at 11:58, xxxxxxxx wrote:
                exactly
                  On 05/06/2010 at 12:04, xxxxxxxx wrote:
                  hmm. still getting some pretty funky results..   could it be because I am looping through all of the points and effecting each individual point?  is it possible to compare the result of a variable in one cycle of a loop to the result in the last cycle of a loop?
                  ~Shawn
                    On 05/06/2010 at 12:13, xxxxxxxx wrote:
                    I assume I'll need a global variable for that..   do you think it would be more effective to catch the location of the last point that was modified in the global variable  and use that to adjust the position of the next point. make the mix function mix the distance between the last point and the current point?
                    something like that?
                    ~Shawn
                      On 05/06/2010 at 12:14, xxxxxxxx wrote:
                      you could try to use some smaller value for the noise functions. for example point _/100.. and see what happens. i'd use a slider for this value than, too...
                        On 05/06/2010 at 12:21, xxxxxxxx wrote:
                        ha, you are just too fast for my replies. however, i wouldnt care for that.. you have your base form and apply just some values to each point, so the form still stays similar to your original mesh. maybe you dont use a cube as a base, but a sphere with low polycount? maybe you apply some scale vector additionally so the object doesnt look so round anymore
                          On 05/06/2010 at 12:22, xxxxxxxx wrote:
                          well smaller numbers definitely help but still don't quite give me what I'm looking for.  I think I might need to compare the current point position with the last point position..     Maybe.,.    LOL
                            On 05/06/2010 at 12:23, xxxxxxxx wrote:
                            lol...   sorry I replied before you had a chance to again.  HAHA
                              On 05/06/2010 at 12:30, xxxxxxxx wrote:
                              if you use Mix with keeping more to your original point, say values between 0.5 and 1 for t, you should be able to get exactly that (in theory of course, since i'm not actually trying atm)
                                On 05/06/2010 at 12:37, xxxxxxxx wrote:
                                LOL..  yep you're right...   it worked/./   just had to do a little tweaking with the numbers..  Thanks a lot for your help ello.    I really appreciate you taking the time to help me.
                                ~Shawn
                                  On 05/06/2010 at 12:39, xxxxxxxx wrote:
                                  glad i am able sometimes 🙂
                                    On 05/06/2010 at 12:45, xxxxxxxx wrote:
                                    Hey while you're here do you know if it is safe to subdivide an object from within the GetVirtualObjects() method?
                                    ~Shawn
                                      On 05/06/2010 at 12:53, xxxxxxxx wrote:
                                      i place my object inside  a hypernurbs (Osds) to do so, but i think you mean something other. it should be able by using CommandData
                                      here is a snippet of how i used the optimize command on a polygon object.
                                            if (op->GetType()==Opolygon)
                                                ModelingCommandData cd;
                                                cd.doc = doc;
                                                cd.op = op;
                                                BaseContainer bc;
                                                bc.SetReal(MDATA_OPTIMIZE_TOLERANCE, tolerance);
                                                bc.SetReal(MDATA_OPTIMIZE_POINTS, TRUE);
                                                bc.SetReal(MDATA_OPTIMIZE_POLYGONS, TRUE);
                                                bc.SetReal(MDATA_OPTIMIZE_UNUSEDPOINTS, TRUE);
                                                cd.bc = &bc;
                                                if(SendModelingCommand(MCOMMAND_OPTIMIZE, cd))
                                                    cd.op->Message(MSG_UPDATE, NULL);
                                                    BaseTag *phongTag = op->MakeTag(Tphong);
                                                    BaseContainer *bc = phongTag->GetDataInstance();
                                                    bc->SetBool(PHONGTAG_PHONG_ANGLELIMIT,TRUE);
                                                    bc->SetReal(PHONGTAG_PHONG_ANGLE,ToRad(winkel));
                                                } else {
                                                     GePrint("failed");
                                      hope this makes sense 🙂
                                      edit: in your case it'd be the MCOMMAND_SUBDIVIDE .. check the sdk for its parameters...
                                        On 05/06/2010 at 12:59, xxxxxxxx wrote:
                                        I was doing something simliar with
                                        MCOMMAND_SUBDIVIDE_<_h4_>_
                                        but for some reason it keeps crashiung on me when I try to do it.
                                          On 05/06/2010 at 13:01, xxxxxxxx wrote:
                                          hm.. did you set the parameters? i guess its some trial and error now, since i dont know why it crashes.
                                            On 05/06/2010 at 13:03, xxxxxxxx wrote:
                                            this is how I am attempting to subdivide
                                            but it keeps crashing
                                            		if (mdat.bc->GetBool(HYPERNURBS_SUBDIVISION, TRUE))  //If HyperNURBS is checked
                                            		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                                            		else
                                            		mdat.bc->SetBool(MDATA_SUBDIVIDE_HYPER, FALSE);
                                            		mdat.bc->SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                                            	    mdat.bc->SetReal(MDATA_SUBDIVIDE_ANGLE, mdat.bc->GetReal(MAX_ANGLE));
                                            	//Subdivision Command
                                            	SendModelingCommand(MCOMMAND_SUBDIVIDE, mdat);
