    Fractal surface
    40 Posts 0 Posters 27.4k Views
      On 31/05/2010 at 17:34, xxxxxxxx wrote:
      Hey Jack,
      Yeah I did know that the functions returned a value.  🙂  I often seem to come off a bit naive when I am charting in to new territory for myself because I am mostly learning as I go.  I do appreciate you answering my questions as it helps to make it all more clear.
      I will poke around in the SDK to get a better understanding of these concepts.  The Current State To Object I have not used before but i will look in to that.
      Thanks again.
      ~Shawn
        On 31/05/2010 at 17:39, xxxxxxxx wrote:
        Sometimes, maybe, a little 😛
        That's how most of us learned it, I guess. Nothing wrong with that.
        I don't mind answering lots of questions, but I want people to do some research on their own.
        "Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime."
        Frank
          On 31/05/2010 at 17:41, xxxxxxxx wrote:
          I'll go fishing.  🙂  Thanks!
            On 31/05/2010 at 18:06, xxxxxxxx wrote:
            I am only find this about Current State To Object:
            Current State To Object (CSTO)
            CSTO has to be executed on a duplicate of an object because CSTO modifies the existing caches. In some cases you have to use a temporary document as well (GetVirtualObjects()).
            Is there more in the SDK about it?   Should I use a CallCommand() to do CSTO?
              On 31/05/2010 at 19:21, xxxxxxxx wrote:
              Okay so after doing some more digging in the SDK and some searches here at the cafe, I have found two ways to do the current State To Object.
              BaseObject *SpaceRock::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh)
              	Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA);
                  if (!dirty) return op->GetCache(hh);
              	ModelingCommandData mcd;
              	BaseObject *cube = BaseObject::Alloc(Ocube);
              	if(!cube) goto Error;
              	cube->SetParameter(PRIM_CUBE_SUBX, GeData(4),0);
              	cube->SetParameter(PRIM_CUBE_SUBY, GeData(4),0);
              	cube->SetParameter(PRIM_CUBE_SUBZ, GeData(4),0);
              	PolygonObject *polyCube = ToPoly(cube);
              	if(!polyCube) goto Error;
              	Vector * points = polyCube->GetPointW();
              	LONG pointCount = polyCube->GetPointCount();
              	//mcd.op = polyCube;
              	//mcd.mode = MODIFY_ALL;
              	//SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd);
              	Real arr[20];
              	InitFbm(arr,10,2.0,0.5);
              	for (int i = 0; i < pointCount; i++)
              		Real rmf = RidgedMultifractal(arr, points[i], 10, 3, 7) * 5.0;
              		Real turb = Turbulence(points[i],10, TRUE) * 5.0;
              		Real snoise = SNoise(points[i]) * 5.0;
              		Real fbm = Fbm(arr, points[i], 10) * 5.0;
              		points[i] = points[i] * turb;
              		points[i] = points[i] * rmf;
              		points[i] = points[i] * snoise;
              		points[i] = points[i] * fbm;
              	//CallCommand(12233); //Current State To Object
              	cube->Message(MSG_UPDATE);
              	return polyCube;
              Error:
              	return NULL;
              I have commented both ways out but you can see that I do it with the CallCommand() and I also do it with a SendModelingCommand().    Is there a particularly more effective way to do it?   Also, I still must not be doing it correctly, because nothing is happening to my cube.  I believe that given the changes I made to the loop that at least something should happen to the points _but nothing is which leads me to believe that it is still not correctly doing the CSTO.
              Do you notice anything in particular that I am doing wrong?  I will keep looking for more info here and in the SDK as well.   Thanks,
              ~Shawn
                On 01/06/2010 at 00:43, xxxxxxxx wrote:
                You need to use SendModelingCommand(), then get the result.
                Also remember that you sometimes have to clone your original object, and use the modeling command on the clone, as it's shown in some threads here in the forum.
                The ToPoly cast can be removed, since it does not change the object. Rather cast the modeling command result to a PolygonObject, that would make more sense 😉
                Also, if you would have taken a close look into the SDK, as I advised you, you would have found some nice demo code for exactly this modeling command in the documentation. It also shows you how to get the result.
                Jack
                  On 01/06/2010 at 16:11, xxxxxxxx wrote:
                  Well after some blood, sweat, and SDK searching I finally figured it out.   When you're right you're right Jack,,,   I learned much more by combing through the SDK...
                  Thanks for the pep talk..  LOL
                  ~Shawn
                    On 03/06/2010 at 18:26, xxxxxxxx wrote:
                    If I want to subdivide the rock using the SendModelingCOmmand()  is this okay to do from within GetVirtualObjects or is that unsafe?   I know it says you can't chan ge the scene from within GVO but if the object hasn't been added to the scene yet, is it safe to subdivide it?
                    ~Shawn
                      On 05/06/2010 at 21:38, xxxxxxxx wrote:
                      Hey Jack,
                      So I have successfully created an object and am using noise functions to alter the look of the object.
                      Here is the code I am using.
                      Real arr[20];
                      	InitFbm(arr,20,7,0.5);
                      		Real rmf = RidgedMultifractal(arr, points[i], octaves, offset, gain) * .8;
                      		Real turb = Turbulence(points[i],octaves, abs) * .8;
                      		Real wavturb = WavyTurbulence(points[i],time, octaves, 1) * .8;
                      		Real noise = Noise(points[i]) * .8;
                      		//RIDGED MULTIFRACTAL
                      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_RIDGEDMULTIFRACTAL)
                      			points[i] = Mix(points[i] * rmf, points[i], amt);
                      		//Turbulence
                      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_TURBULENCE)
                      			points[i] = Mix(points[i] * turb, points[i], amt);
                      		//Wavy Turbulence
                      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_WAVY_TURBULENCE)
                      			points[i] = Mix(points[i] * wavturb, points[i], amt);
                      		//Noise
                      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_NOISE)
                      			points[i] = Mix(points[i] * noise, points[i], amt);
                      	//SUBDIVISION
                      		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
                      		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                      		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                      		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
                      		mcd2.bc = &bc2;
                      		mcd2.op = polyCube;
                      		mcd2.mode = MODIFY_ALL;
                      		mcd2.doc = hh->GetDocument();
                      		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
                      			GePrint("done");
                      		else
                      			GePrint("failed");
                      My results are okay but I would like to get a more detailed and fine noise look.  Do you have any tips on how to improve the way I am affecting the object with the noise functions.  This is how my object looks right now with noise applied.
                        On 06/06/2010 at 10:57, xxxxxxxx wrote:
                        well, i guess you first need to create more faces to get more details. than you could apply more layers of noise at different scales and coordinates..  or you  simply add the detail using a nice mix of noises in the relief channel
                        Ello
                          On 06/06/2010 at 11:04, xxxxxxxx wrote:
                          Hi ello,
                          even when I subdivide the rock the noise still follows this broad pattern.  as if it's not fully affecting each point.  I would like the ripples and bumps to be on a smaller scale.     Hopefully that makes sense.
                          Can you provide an example of layering the noise functions?  I have tried to do this but don't seem to be getting success.
                          ~Shawn
                            On 06/06/2010 at 11:08, xxxxxxxx wrote:
                            does using the subdivide command actually add more polygons to the image?
                              On 06/06/2010 at 19:50, xxxxxxxx wrote:
                              okay so I'm getting some good results now but I want to add some bulges throughout the rock.   Take a look at this image.
                              you can see that this particular spacerock is a bit too perfect.  I want to use the noise functions to create som random buldges to the overall shape of the rock.  Is it possible to apply noise to the whole rock?   Does anyone have any thoughts on how I could accomplish these random bulges?
                              Would it work to create a random function and then iterate through the rock's points again and only apply noise to random points this time?
                              Thanks in advance.
                              ~Shawn
                                On 06/06/2010 at 21:46, xxxxxxxx wrote:
                                you could use another noise and do something like if (noise>0.8) add certain ammount to point offset
                                plus, you should add different results to the x, y and z part of the points.. like
                                                  Real rmf1 = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                                                  Real rmf2 = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                                                  Real rmf3 = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                                                  points[i] += Vector(rmf1,rmf2,rmf3);
                                hope this helps
                                edit: plus you really should use bools for the noise types so to make a mix off all of them 🙂
                                  On 07/06/2010 at 05:14, xxxxxxxx wrote:
                                  I'm not sure what you mean by factor.x is factor a vector?   and is strength a vector?   or should the .x .y and .z be on the points _?
                                  ~Shawn
                                    On 07/06/2010 at 05:30, xxxxxxxx wrote:
                                    those are vectors you can let the user change, to adjust the size (factor) and the strength of the noise..
                                    btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                                      On 08/06/2010 at 17:56, xxxxxxxx wrote:
                                      can someone provide me an example of layering noise functions.  many resources mention that it is important to layer noise functions.  I am not entirely sure what is exactly meant by that.  Could someone elaborate?
                                      ~Shawn
                                        On 08/06/2010 at 21:42, xxxxxxxx wrote:
                                        there are many ways how you can mix some noises. for example:
                                        Vector someNoise = 0;
                                        someNoise.x = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                                        someNoise.y = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                                        someNoise.z = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                                        Vector anotherNoise = 0;
                                        anotherNoise.x = Turbulence(points[i]*anotherFactor.x,20, false) * anotherStrength.x; anotherNoise.y = Turbulence(points[i]*anotherFactor.y,20, false) * anotherStrength.y; anotherNoise.z = Turbulence(points[i]*anotherFactor.z,20, false) * anotherStrength.z;
                                        Vector myNoise = Mix (someNoise,anotherNoise,mix);
                                        where mix is a user value or jet another noise...
                                        or you could multiply
                                        Vector myNoise = someNoise * anotherNoise;
                                        or add
                                        Vector myNoise = someNoise + anotherNoise;
                                        or just try anything out.. there are just too many things you can do 🙂
                                        hope it helps..
                                          On 09/06/2010 at 15:51, xxxxxxxx wrote:
                                          Okay that's easy enough.,. thanks a lot. ello!
                                          ~Shawn
                                            ..btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                                            As an aside, here is some Normal info...
                                            For faces, you can simply do:
                                                 Vector *padr = ToPoly(op)->GetPointW();
                                                 CPolygon *polys = ToPoly(op)->GetPolygonW();
                                                 Vector vNorm = CalcFaceNormal(padr, polys[poly_of_interest]);
                                            For Point Normals, I created a helper structure, similar to how the UVWStruct is used...
                                            struct NormalStruct
                                                 NormalStruct(_DONTCONSTRUCT dc) : a(DC), b(DC), c(DC), d(DC) { }
                                                 NormalStruct(void) {}
                                                 NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c, const Vector &t;_d) { a=t_a; b=t_b; c=t_c; d=t_d; }
                                                 NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c) { a=t_a; b=t_b; c=t_c; }
                                                 Vector a,b,c,d;
                                            ...for Point Normals, you want "a normal for every vertex/point of every polygon" (ie. not just one per point) - this allows for Phong Edge-Breaks in the shading. So, assuming that the mesh _has_ a Phong Tag, you can just do:
                                                 NormalStruct *pNorms = (NormalStruct * )ToPoly(op)->CreatePhongNormals();
                                            ...the CreatePhongNormals() routine will return a pointer to an array of Point Normals - **4** normals for every polygon in the mesh (just like the UVW Tag returns 4 uv coordinates per polygon). This is the same as the NormalStruct I list above, so you can use that structure to access the (a,b,c,d) normals.
                                            If the mesh doesn't have a Phong Tag (ie. CreatePhongNormals() returns a Null), you can either skip it, or generate normals based on averaging the face normals (I'd suggest writing your own routine that does this, allocating, filling in and returning the same NormalStruct pointer/array).
                                            Be sure to GeFree(pNorms) when done.
