    Fractal surface
    40 Posts 0 Posters 27.8k Views
      On 31/05/2010 at 05:50, xxxxxxxx wrote:
      Okay Jack here's what I have...
      BaseObject *SpaceRock::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh)
      	Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA);
          if (!dirty) return op->GetCache(hh);
      	BaseObject *cube = BaseObject::Alloc(Ocube);
      	if(!cube) goto Error;
      	cube->SetParameter(PRIM_CUBE_SUBX, GeData(4),0);
      	cube->SetParameter(PRIM_CUBE_SUBY, GeData(4),0);
      	cube->SetParameter(PRIM_CUBE_SUBZ, GeData(4),0);
      	PolygonObject *polyCube = ToPoly(cube);
      	Vector * points = polyCube->GetPointW();
      	LONG pointCount = polyCube->GetPointCount();
      	for (int i = 0; i < pointCount; i++)
      		Real arr[20];
      		InitFbm(arr,10,2.0,0.5);
      		RidgedMultifractal(arr, points[i], 10, 3, 7);
      		Turbulence(points[i],10, TRUE);
      		SNoise(points[i]);
      		Fbm(arr, points[i], 10);
      	cube->Message(MSG_UPDATE);
          return polyCube;
      Error:
      	return NULL;
      Unfortunately nothing happens to the cube ..  so I must be doing something wrong...   I figured I'd try all the noise functions just to see what happened....    Do you see anything I should change?
      ~Shawn
        On 31/05/2010 at 05:51, xxxxxxxx wrote:
        And Thanks again Matthias...
        ~Shawn
          On 31/05/2010 at 06:55, xxxxxxxx wrote:
          Maybe the changes you're making to the point positions are just too small to see? Remember, the noise functions only return values between 0 and 1 (or -1 and 1), so you'll want to multiply them with some value control the deformation intensity.
          Frank
            On 31/05/2010 at 08:06, xxxxxxxx wrote:
            Could you post a quick example of what you mean by that?
              On 31/05/2010 at 17:19, xxxxxxxx wrote:
              What other noise functions are you refering to?
              All of them, just take a look into the SDK documentation.
              Well, just multiply it.
              Real x = Turbulence(points[i],10, TRUE) * 5.0;
              You actually do know that those Noise functions return values, right? In your code it looks like you just call them without doing anything with their results.
              I strongly advise you to stick your nose into the SDK documentation and read about the basics, since most of your questions here are answered there!
              Also your code looks quite inefficient in several places, e.g. initializing the Fbm array in every iteration of your loop is neither necessary nor does it lead to a good performance. Last but not least, you have to convert your allocated object to a polygon object. In your code, you just cast it. Read about Current State To Object in the SDK docs. Don't forget to check for memory leaks by using the c4d_debug.txt file.
              Jack
                On 31/05/2010 at 17:34, xxxxxxxx wrote:
                Hey Jack,
                Yeah I did know that the functions returned a value.  🙂  I often seem to come off a bit naive when I am charting in to new territory for myself because I am mostly learning as I go.  I do appreciate you answering my questions as it helps to make it all more clear.
                I will poke around in the SDK to get a better understanding of these concepts.  The Current State To Object I have not used before but i will look in to that.
                Thanks again.
                ~Shawn
                  Sometimes, maybe, a little 😛
                  That's how most of us learned it, I guess. Nothing wrong with that.
                  I don't mind answering lots of questions, but I want people to do some research on their own.
                  "Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime."
                  Frank
                    On 31/05/2010 at 17:41, xxxxxxxx wrote:
                    I'll go fishing.  🙂  Thanks!
                      On 31/05/2010 at 18:06, xxxxxxxx wrote:
                      I am only find this about Current State To Object:
                      Current State To Object (CSTO)
                      CSTO has to be executed on a duplicate of an object because CSTO modifies the existing caches. In some cases you have to use a temporary document as well (GetVirtualObjects()).
                      Is there more in the SDK about it?   Should I use a CallCommand() to do CSTO?
                        On 31/05/2010 at 19:21, xxxxxxxx wrote:
                        Okay so after doing some more digging in the SDK and some searches here at the cafe, I have found two ways to do the current State To Object.
                        	ModelingCommandData mcd;
                        	if(!polyCube) goto Error;
                        	//mcd.op = polyCube;
                        	//mcd.mode = MODIFY_ALL;
                        	//SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd);
                        	Real arr[20];
                        		Real rmf = RidgedMultifractal(arr, points[i], 10, 3, 7) * 5.0;
                        		Real turb = Turbulence(points[i],10, TRUE) * 5.0;
                        		Real snoise = SNoise(points[i]) * 5.0;
                        		Real fbm = Fbm(arr, points[i], 10) * 5.0;
                        		points[i] = points[i] * turb;
                        		points[i] = points[i] * rmf;
                        		points[i] = points[i] * snoise;
                        		points[i] = points[i] * fbm;
                        	//CallCommand(12233); //Current State To Object
                        	return polyCube;
                        Error:
                        	return NULL;
                        I have commented both ways out but you can see that I do it with the CallCommand() and I also do it with a SendModelingCommand().    Is there a particularly more effective way to do it?   Also, I still must not be doing it correctly, because nothing is happening to my cube.  I believe that given the changes I made to the loop that at least something should happen to the points _but nothing is which leads me to believe that it is still not correctly doing the CSTO.
                        Do you notice anything in particular that I am doing wrong?  I will keep looking for more info here and in the SDK as well.   Thanks,
                        ~Shawn
                          On 01/06/2010 at 00:43, xxxxxxxx wrote:
                          You need to use SendModelingCommand(), then get the result.
                          Also remember that you sometimes have to clone your original object, and use the modeling command on the clone, as it's shown in some threads here in the forum.
                          The ToPoly cast can be removed, since it does not change the object. Rather cast the modeling command result to a PolygonObject, that would make more sense 😉
                          Also, if you would have taken a close look into the SDK, as I advised you, you would have found some nice demo code for exactly this modeling command in the documentation. It also shows you how to get the result.
                          Jack
                            On 01/06/2010 at 16:11, xxxxxxxx wrote:
                            Well after some blood, sweat, and SDK searching I finally figured it out.   When you're right you're right Jack,,,   I learned much more by combing through the SDK...
                            Thanks for the pep talk..  LOL
                            ~Shawn
                              On 03/06/2010 at 18:26, xxxxxxxx wrote:
                              If I want to subdivide the rock using the SendModelingCOmmand()  is this okay to do from within GetVirtualObjects or is that unsafe?   I know it says you can't chan ge the scene from within GVO but if the object hasn't been added to the scene yet, is it safe to subdivide it?
                              ~Shawn
                                On 05/06/2010 at 21:38, xxxxxxxx wrote:
                                Hey Jack,
                                So I have successfully created an object and am using noise functions to alter the look of the object.
                                Here is the code I am using.
                                Real arr[20];
                                	InitFbm(arr,20,7,0.5);
                                		Real rmf = RidgedMultifractal(arr, points[i], octaves, offset, gain) * .8;
                                		Real turb = Turbulence(points[i],octaves, abs) * .8;
                                		Real wavturb = WavyTurbulence(points[i],time, octaves, 1) * .8;
                                		Real noise = Noise(points[i]) * .8;
                                		//RIDGED MULTIFRACTAL
                                		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_RIDGEDMULTIFRACTAL)
                                			points[i] = Mix(points[i] * rmf, points[i], amt);
                                		//Turbulence
                                		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_TURBULENCE)
                                			points[i] = Mix(points[i] * turb, points[i], amt);
                                		//Wavy Turbulence
                                		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_WAVY_TURBULENCE)
                                			points[i] = Mix(points[i] * wavturb, points[i], amt);
                                		//Noise
                                		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_NOISE)
                                			points[i] = Mix(points[i] * noise, points[i], amt);
                                	//SUBDIVISION
                                		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
                                		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
                                		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
                                		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
                                		mcd2.bc = &bc2;
                                		mcd2.op = polyCube;
                                		mcd2.mode = MODIFY_ALL;
                                		mcd2.doc = hh->GetDocument();
                                		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
                                			GePrint("done");
                                		else
                                			GePrint("failed");
                                My results are okay but I would like to get a more detailed and fine noise look.  Do you have any tips on how to improve the way I am affecting the object with the noise functions.  This is how my object looks right now with noise applied.
                                  On 06/06/2010 at 10:57, xxxxxxxx wrote:
                                  well, i guess you first need to create more faces to get more details. than you could apply more layers of noise at different scales and coordinates..  or you  simply add the detail using a nice mix of noises in the relief channel
                                  Ello
                                    On 06/06/2010 at 11:04, xxxxxxxx wrote:
                                    Hi ello,
                                    even when I subdivide the rock the noise still follows this broad pattern.  as if it's not fully affecting each point.  I would like the ripples and bumps to be on a smaller scale.     Hopefully that makes sense.
                                    Can you provide an example of layering the noise functions?  I have tried to do this but don't seem to be getting success.
                                    ~Shawn
                                      On 06/06/2010 at 11:08, xxxxxxxx wrote:
                                      does using the subdivide command actually add more polygons to the image?
                                        On 06/06/2010 at 19:50, xxxxxxxx wrote:
                                        okay so I'm getting some good results now but I want to add some bulges throughout the rock.   Take a look at this image.
                                        you can see that this particular spacerock is a bit too perfect.  I want to use the noise functions to create som random buldges to the overall shape of the rock.  Is it possible to apply noise to the whole rock?   Does anyone have any thoughts on how I could accomplish these random bulges?
                                        Would it work to create a random function and then iterate through the rock's points again and only apply noise to random points this time?
                                        Thanks in advance.
                                        ~Shawn
                                          On 06/06/2010 at 21:46, xxxxxxxx wrote:
                                          you could use another noise and do something like if (noise>0.8) add certain ammount to point offset
                                          plus, you should add different results to the x, y and z part of the points.. like
                                                            Real rmf1 = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                                                            Real rmf2 = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                                                            Real rmf3 = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                                                            points[i] += Vector(rmf1,rmf2,rmf3);
                                          hope this helps
                                          edit: plus you really should use bools for the noise types so to make a mix off all of them 🙂
                                            On 07/06/2010 at 05:14, xxxxxxxx wrote:
                                            I'm not sure what you mean by factor.x is factor a vector?   and is strength a vector?   or should the .x .y and .z be on the points _?
                                            ~Shawn
