    Fractal surface
    40 Posts 0 Posters 28.7k Views
      On 03/06/2010 at 18:26, xxxxxxxx wrote:
      If I want to subdivide the rock using the SendModelingCOmmand()  is this okay to do from within GetVirtualObjects or is that unsafe?   I know it says you can't chan ge the scene from within GVO but if the object hasn't been added to the scene yet, is it safe to subdivide it?
      ~Shawn
        On 05/06/2010 at 21:38, xxxxxxxx wrote:
        Hey Jack,
        So I have successfully created an object and am using noise functions to alter the look of the object.
        Here is the code I am using.
        Real arr[20];
        	InitFbm(arr,20,7,0.5);
        	for (int i = 0; i < pointCount; i++)
        		Real rmf = RidgedMultifractal(arr, points[i], octaves, offset, gain) * .8;
        		Real turb = Turbulence(points[i],octaves, abs) * .8;
        		Real wavturb = WavyTurbulence(points[i],time, octaves, 1) * .8;
        		Real noise = Noise(points[i]) * .8;
        		//RIDGED MULTIFRACTAL
        		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_RIDGEDMULTIFRACTAL)
        			points[i] = Mix(points[i] * rmf, points[i], amt);
        		//Turbulence
        		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_TURBULENCE)
        			points[i] = Mix(points[i] * turb, points[i], amt);
        		//Wavy Turbulence
        		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_WAVY_TURBULENCE)
        			points[i] = Mix(points[i] * wavturb, points[i], amt);
        		//Noise
        		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_NOISE)
        			points[i] = Mix(points[i] * noise, points[i], amt);
        	//SUBDIVISION
        		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
        		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
        		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
        		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
        		mcd2.bc = &bc2;
        		mcd2.op = polyCube;
        		mcd2.mode = MODIFY_ALL;
        		mcd2.doc = hh->GetDocument();
        		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
        			GePrint("done");
        		else
        			GePrint("failed");
        My results are okay but I would like to get a more detailed and fine noise look.  Do you have any tips on how to improve the way I am affecting the object with the noise functions.  This is how my object looks right now with noise applied.
          On 06/06/2010 at 10:57, xxxxxxxx wrote:
          well, i guess you first need to create more faces to get more details. than you could apply more layers of noise at different scales and coordinates..  or you  simply add the detail using a nice mix of noises in the relief channel
          Ello
            On 06/06/2010 at 11:04, xxxxxxxx wrote:
            Hi ello,
            even when I subdivide the rock the noise still follows this broad pattern.  as if it's not fully affecting each point.  I would like the ripples and bumps to be on a smaller scale.     Hopefully that makes sense.
            Can you provide an example of layering the noise functions?  I have tried to do this but don't seem to be getting success.
            ~Shawn
              On 06/06/2010 at 11:08, xxxxxxxx wrote:
              does using the subdivide command actually add more polygons to the image?
                On 06/06/2010 at 19:50, xxxxxxxx wrote:
                okay so I'm getting some good results now but I want to add some bulges throughout the rock.   Take a look at this image.
                you can see that this particular spacerock is a bit too perfect.  I want to use the noise functions to create som random buldges to the overall shape of the rock.  Is it possible to apply noise to the whole rock?   Does anyone have any thoughts on how I could accomplish these random bulges?
                Would it work to create a random function and then iterate through the rock's points again and only apply noise to random points this time?
                Thanks in advance.
                ~Shawn
                  On 06/06/2010 at 21:46, xxxxxxxx wrote:
                  you could use another noise and do something like if (noise>0.8) add certain ammount to point offset
                  plus, you should add different results to the x, y and z part of the points.. like
                                    Real rmf1 = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                                    Real rmf2 = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                                    Real rmf3 = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                                    points[i] += Vector(rmf1,rmf2,rmf3);
                  hope this helps
                  edit: plus you really should use bools for the noise types so to make a mix off all of them 🙂
                    On 07/06/2010 at 05:14, xxxxxxxx wrote:
                    I'm not sure what you mean by factor.x is factor a vector?   and is strength a vector?   or should the .x .y and .z be on the points _?
                    ~Shawn
                      On 07/06/2010 at 05:30, xxxxxxxx wrote:
                      those are vectors you can let the user change, to adjust the size (factor) and the strength of the noise..
                      btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                        On 08/06/2010 at 17:56, xxxxxxxx wrote:
                        can someone provide me an example of layering noise functions.  many resources mention that it is important to layer noise functions.  I am not entirely sure what is exactly meant by that.  Could someone elaborate?
                        ~Shawn
                          On 08/06/2010 at 21:42, xxxxxxxx wrote:
                          there are many ways how you can mix some noises. for example:
                          Vector someNoise = 0;
                          someNoise.x = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                          someNoise.y = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                          someNoise.z = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                          Vector anotherNoise = 0;
                          anotherNoise.x = Turbulence(points[i]*anotherFactor.x,20, false) * anotherStrength.x; anotherNoise.y = Turbulence(points[i]*anotherFactor.y,20, false) * anotherStrength.y; anotherNoise.z = Turbulence(points[i]*anotherFactor.z,20, false) * anotherStrength.z;
                          Vector myNoise = Mix (someNoise,anotherNoise,mix);
                          where mix is a user value or jet another noise...
                          or you could multiply
                          Vector myNoise = someNoise * anotherNoise;
                          or add
                          Vector myNoise = someNoise + anotherNoise;
                          or just try anything out.. there are just too many things you can do 🙂
                          hope it helps..
                            On 09/06/2010 at 15:51, xxxxxxxx wrote:
                            Okay that's easy enough.,. thanks a lot. ello!
                            ~Shawn
                              On 11/06/2010 at 04:16, xxxxxxxx wrote:
                              ..btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                              As an aside, here is some Normal info...
                              For faces, you can simply do:
                                   Vector *padr = ToPoly(op)->GetPointW();
                                   CPolygon *polys = ToPoly(op)->GetPolygonW();
                                   Vector vNorm = CalcFaceNormal(padr, polys[poly_of_interest]);
                              For Point Normals, I created a helper structure, similar to how the UVWStruct is used...
                              struct NormalStruct
                                   NormalStruct(_DONTCONSTRUCT dc) : a(DC), b(DC), c(DC), d(DC) { }
                                   NormalStruct(void) {}
                                   NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c, const Vector &t;_d) { a=t_a; b=t_b; c=t_c; d=t_d; }
                                   NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c) { a=t_a; b=t_b; c=t_c; }
                                   Vector a,b,c,d;
                              ...for Point Normals, you want "a normal for every vertex/point of every polygon" (ie. not just one per point) - this allows for Phong Edge-Breaks in the shading. So, assuming that the mesh _has_ a Phong Tag, you can just do:
                                   NormalStruct *pNorms = (NormalStruct * )ToPoly(op)->CreatePhongNormals();
                              ...the CreatePhongNormals() routine will return a pointer to an array of Point Normals - **4** normals for every polygon in the mesh (just like the UVW Tag returns 4 uv coordinates per polygon). This is the same as the NormalStruct I list above, so you can use that structure to access the (a,b,c,d) normals.
                              If the mesh doesn't have a Phong Tag (ie. CreatePhongNormals() returns a Null), you can either skip it, or generate normals based on averaging the face normals (I'd suggest writing your own routine that does this, allocating, filling in and returning the same NormalStruct pointer/array).
                              Be sure to GeFree(pNorms) when done.
                                On 11/06/2010 at 04:36, xxxxxxxx wrote:
                                thanks giblet for your input.. at the moment i am averaging the neighbouring polygon normals and it works like this on a standard sphere for example:
                                this is how i calculate it:
                                              neighbor.GetPointPolys(i, &dadr, &dcnt);
                                              polyNormal=0;
                                              for (int j=0;j<dcnt;j++)
                                                  if (dadr[j]<maxcount)
                                                      polyNormal += polygonNormal(nCalc1,nCalc2,padr,pol,dadr[j]);
                                              polyNormal /= dcnt;
                                where polygonNormal(...) is returning the correct mormal for each polygon as it is working in my plugin.
                                it seems to me that there is an invisible cut going thru the mesh which results in wrong or no neighbour
                                any ideas?
                                ello
                                btw: sorry for the hijacking here...
                                  On 11/06/2010 at 05:01, xxxxxxxx wrote:
                                  Hmmm.. not sure. Are you calling neighbor.Init() before trying to use it?
                                  Here's some code I've been using (several class member variables are set up elsewhere, but it should be self-explanitory)...
                                  Bool MeshMap::GetSrcVertexNormals(void)
                                       LONG i, j, faceCnt, *pFaces = NULL;
                                       Vector vNorm, *pNorm;
                                       // initialize neighbor class... this is used to compute m_SrcvNorms
                                       if( !m_Neighbor.Init(m_numSrcVerts, m_SrcPolys, m_numSrcPolys, NULL) )
                                            return false;
                                       StatusSetText("Computing Vertex Normals...");
                                       pNorm = &m;_pSrcvNorms[0];
                                       for(i=0; i<m_numSrcVerts; i++)
                                            vNorm = Vector();          // (re)intitialize
                                            m_Neighbor.GetPointPolys(i, &pFaces;, &faceCnt;);
                                            if( faceCnt )
                                                 for(j=0; j<faceCnt; j++)
                                                      Vector n = CalcFaceNormal(m_pxfSrcVerts, m_SrcPolys[pFaces[j]]);
                                                      vNorm += !n;
                                                 vNorm /= faceCnt;     // average the normal(s)
                                                 *pNorm = !vNorm;     // normalize and store
                                            else
                                                 *pNorm = Vector(0.0,1.0,0.0);
                                            pNorm++;
                                       return true;
                                  EDIT: Note... this code only generates a normal-per-vertex, which is contrary to my suggestion in my previous reply (this particular implementation didn't need to concern itself with phong-edge-breaks).
                                    On 11/06/2010 at 05:59, xxxxxxxx wrote:
                                    thank you very much. i'll see if i can fix it with this input. i remember i didnt normalize it so maybe that coul cause it...
                                      On 26/06/2010 at 18:25, xxxxxxxx wrote:
                                      Hi Giblet,
                                      Thank you for offering your struct for us to see.   After I add your struct to my code and then use
                                      NormalStruct \*pNorms = (NormalStruct \* )ToPoly(op)->CreatePhongNormals()
                                      how do I use the NormalStruct pNorms?
                                      could you give me an example of how I would then move a point along the normal that I found?
                                      ~Shawn
                                        On 26/06/2010 at 22:51, xxxxxxxx wrote:
                                        Hi Shawn,
                                        The pNorms pointer will point to 'an array' of NormalStruct(s) - one for each polygon of the mesh.
                                        A 'Normal' (call it vNorm) is a 'Unit Vector' (a vector who's length == 1.0) and the x/y/z values define a 'direction'.
                                        So, given the above, if you multiply a float (Real rDist) distance value times a Normal (who's length is 1.0), you get a new Vector/Vertex that is rDist distance in vNorm direction.
                                        I often use the following macro:
                                        #define ray_project(vStart, vDir, rDist)     ((vStart) + ((vDir) * (rDist))) //given the start point of a line, the direction and a distance, return end point
                                        ...where:
                                        vStart - is any Vector/Point/Vertex that defines the start position
                                        vDir - is any Normal Vector
                                        vDist - is the floating point (Real) distance value that I want to travel/project.
                                        ...so example code might look something like so:
                                        Vector *pPoints = op->GetPointW();
                                        CPolygon *pPolys = op->GetPolygonW();
                                        LONG pNdx = 0; // poly index
                                        CPolygon *pPoly = &pPolys;[pNdx];
                                        Vector vStart = pPoints[pPoly->a];
                                        Vector vDir = pNorms[pNdx].a;
                                        Real rDist = 5.0;
                                        Vector vEnd = ray_project(vStart, vDir, rDist);
                                        ...so, vEnd would be a Point that is 5.0 distance from the first Point in the first Polygon of the mesh, along (in the direction of) the Normal of that Point.
                                          On 26/06/2010 at 23:04, xxxxxxxx wrote:
                                          ...or something like that :).
                                          Basically, anywhere you get a poly reference, you can also get the NormalStruct the same way - the difference between a CPolygon and a NormalStruct is that the elements (a,b,c,d) of the CPolygon are 'indices' into the points array and the elements of the NormalStruct are the actual Normal Vectors themselves, so:
                                          NormalStruct ns = pNorms[x]; // x == whatever polygon you are interested in
                                          Vector vNormA = ns.a; // Normal for Point a of Polygon
                                          Vector vNormB = ns.b; // Normal for Point b of Polygon
                                          Vector vNormC = ns.c; // Normal for Point c of Polygon
                                          Vector vNormD = ns.d; // Normal for Point d of Polygon
                                          Cheers.
                                            On 27/06/2010 at 03:40, xxxxxxxx wrote:
                                            BTW, I also remembered this topic (Normals / NormalStruct) comming up before, so I went back and found this thread, that has a lot of the same info in it (including a routine I used to generate a NormalStruct array if CreatePhongNormals() fails).
