    Serial Numbers
    20 Posts 0 Posters 2.5k Views
      On 20/01/2010 at 11:20, xxxxxxxx wrote:
      There is no 'recommended' way. It's really up to you. Currently there are two serialization methods supported directly through the SDK. One is to use the SNHookClass and the other to use the WritePluginInfo/ReadPluginInfo WriteRegInfo/ReadRegInfo function to write/read private data for your plugin serialization.
        On 20/01/2010 at 13:05, xxxxxxxx wrote:
        OK, that's very useful, thank you.
          On 20/01/2010 at 13:07, xxxxxxxx wrote:
          Thanks spedler and Matthias for the info.  I will put it to good use as soon as I get home tonight.
          ~Shawn
            On 20/01/2010 at 17:44, xxxxxxxx wrote:
            Okay so This is the code I have in my .cpp file now for the serial number..
            //const ID_PLANET_OBJECT_SERIAL  = 1024924;
            class PlanetXSerial : public SNHookClass
              String name;
              PlanetXSerial()
                  name = GeLoadString(IDS_SERIAL_HOOK);
                  if(!name.Content())
                      name = "C++ SDK - Example Serial Hook";
              virtual LONG SNCheck(const String &c4dsn,const String &sn,LONG regdate,LONG curdate)
                  return sn == String("123456789-abcdef") ? SN_OKAY : SN_WRONGNUMBER;
              virtual const String& GetTitle()
                  return name;
            PlanetXSerial *snhook = NULL;
            Bool RegisterPlanetXSerial()
              snhook = gNew PlanetXSerial;
              if (!snhook->Register(450000241, SNFLAG_OWN))
                  return FALSE;
            void FreePlanetXSerial()
              if (snhook)
                  gDelete(snhook);
            My question is, what am I supposed to do to prompt the user to put in their serial number, and where do I determine the algorithm for the serial number.    When I finally do determine that,  I will of course not post it on this forum .  LOL
            Also, shouldn't I see another serial field when I go to the personalize dialog box with the code I have?
            Once again I am new to this whole part of it so any help you can offer would be greatly appreciated.
            ~Shawn
              On 21/01/2010 at 01:23, xxxxxxxx wrote:
              Did you call RegisterPlanetXSerial() during C4DPL_INIT_SYS to register the plugin with Cinema?
                On 21/01/2010 at 02:40, xxxxxxxx wrote:
                Yes, I did,
                Here's my main.cpp
                // Planet
                // Starts the plugin registration
                #include "c4d.h"
                #include <string.h>
                // forward declarations
                Bool RegisterPlanet(void);
                Bool RegisterSun(void);
                Bool RegisterPlanetXSerial();
                void FreePlanetXSerial();
                C4D_CrashHandler old_handler;
                void SDKCrashHandler(CHAR *crashinfo)
                  // don't forget to call the original handler!!!
                  if (old_handler) (*old_handler)(crashinfo);
                void EnhanceMainMenu(void)
                  // do this only if necessary - otherwise the user will end up with dozens of menus!
                  if (!(GeGetVersionType()&VERSION_CINEMA4D)) // only if C4D is loaded
                      return;
                  BaseContainer *bc = GetMenuResource(String("M_EDITOR"));
                  if (!bc) return;
                  // search for the most important menu entry. if present, the user has customized the settings
                  // -> don't add menu again
                  if (SearchMenuResource(bc,String("PLUGIN_CMD_1000472")))
                      return;
                  GeData *last = SearchPluginMenuResource();
                  BaseContainer sc;
                  sc.InsData(MENURESOURCE_SUBTITLE,String("SDK Test"));
                  sc.InsData(MENURESOURCE_COMMAND,String("IDM_NEU")); // add C4D's new scene command to menu
                  sc.InsData(MENURESOURCE_SEPERATOR,TRUE);
                  sc.InsData(MENURESOURCE_COMMAND,String("PLUGIN_CMD_1000472")); // add ActiveObject dialog to menu
                  if (last)
                      bc->InsDataAfter(MENURESOURCE_STRING,sc,last);
                  else // user killed plugin menu - add as last overall entry
                      bc->InsData(MENURESOURCE_STRING,sc);
                Bool PluginStart(void)
                  // example of installing a crashhandler
                  old_handler = C4DOS.CrashHandler; // backup the original handler (must be called!)
                  C4DOS.CrashHandler = SDKCrashHandler; // insert the own handler
                  // Planet Object
                  if (!RegisterPlanet()) return FALSE;
                  // Sun Object
                  if (!RegisterSun()) return FALSE;
                void PluginEnd(void)
                Bool PluginMessage(LONG id, void *data)
                  //use the following lines to set a plugin priority
                  switch (id)
                      case C4DPL_INIT_SYS:
                          if (!resource.Init()) return FALSE; // don't start plugin without resource
                          if (!RegisterPlanetXSerial()) return FALSE;
                      case C4DPL_ENDACTIVITY:
                          FreePlanetXSerial(); return TRUE;
                      case C4DMSG_PRIORITY:
                      case C4DPL_BUILDMENU:
                          //EnhanceMainMenu();
                          break;
                      case C4DPL_COMMANDLINEARGS:
                              C4DPL_CommandLineArgs *args = (C4DPL_CommandLineArgs* )data;
                              LONG i;
                              for (i=0;i<args->argc;i++)
                                  if (!args->argv[i]) continue;
                                  if (!strcmp(args->argv[i],"--help") || !strcmp(args->argv[i],"-help"))
                                      // do not clear the entry so that other plugins can make their output!!!
                                      GePrint("\x01-SDK is here :-)");
                                  else if (!strcmp(args->argv[i],"-SDK"))
                                      args->argv[i] = NULL;
                                      GePrint("\x01-SDK executed:-)");
                                  else if (!strcmp(args->argv[i],"-plugincrash"))
                                      *((LONG* )0) = 1234;
                          break;
                      case C4DPL_EDITIMAGE:
                              GePrint("Something Changed");
                              C4DPL_EditImage *editimage = (C4DPL_EditImage* )data;
                              if (!data) break;
                              if (editimage->return_processed) break;
                              GePrint("C4DSDK - Edit Image Hook: "+editimage->imagefn->GetString());
                              // editimage->return_processed = TRUE; if image was processed
                          return FALSE;
                  return FALSE;
                  On 21/01/2010 at 03:34, xxxxxxxx wrote:
                  Instead of
                  do this
                  Otherwise RegisterPlanetXSerial() will never be called.
                    On 21/01/2010 at 03:36, xxxxxxxx wrote:
                    LOL...  woops.  thanks Matthias
                      On 21/01/2010 at 17:56, xxxxxxxx wrote:
                      okay so here's the code I am using right now.   Just the code to get me started.
                      //SERIAL CODE/////////////////////////////////
                      #define ID_PLANET_OBJECT_SERIAL  = 1024924
                        String name;
                        PlanetXSerial()
                            if(!name.Content())
                                name = "Planet X Generator";
                            return sn == String(name) ? SN_OKAY : SN_WRONGNUMBER;
                            return name;
                            return FALSE;
                        if (snhook)
                            gDelete(snhook);
                      Here's the result I get when I look in the personalize dialog box.
                      For some reason, it is saying "StrNotFound"  Where do I set the name.   And,  where do I check to see if the serial number they entered matches what they should enter?
                      Thanks,  Shawn
                      _<_img src="http://www.c4davenue.com/mag/wrong.jpg" height="291" width="703" border="0" /_>_
                        On 22/01/2010 at 08:50, xxxxxxxx wrote:
                        Any thoughts on this?
                          On 23/01/2010 at 08:59, xxxxxxxx wrote:
                          figured it out..  Thanks,
                          ~Shawn
                            On 23/01/2010 at 09:26, xxxxxxxx wrote:
                            I am trying to use StringToLong()   to convert the serial number to a long so that I can perform an algorithm on it.
                            For some reason, even though I have included c4d_string.h,   I am getting the error.
                            'StringToLong': identifier not found
                            Can anyone tell me why this is?
                            ~Shawn
                              On 23/01/2010 at 19:56, xxxxxxxx wrote:
                              lol..  figured this one out too..    had to do
                              LONG lngMyLONG =  myString.StringToLong(&err);
