    Updating Attributes Question
    21 Posts 0 Posters 12.8k Views
      On 31/12/2009 at 05:15, xxxxxxxx wrote:
      I did not had the time to look at it yet. There are holidays over here in Germany. Will post back after the weekend.
        On 01/01/2010 at 15:42, xxxxxxxx wrote:
        Thank you .  I appreciate your help very much.
        ~Shawn
          On 04/01/2010 at 12:56, xxxxxxxx wrote:
          Any info on this?    Thanks,
          ~Shawn
            On 05/01/2010 at 05:38, xxxxxxxx wrote:
            Here is the complete code of a simple example of a generator (doing nothing) with a dynamic description similar to what you want. The elements for each dynamic decription group are saved in a respective sub-subcontainer. Please check the comments within the sorce code for more details.
            // CINEMA 4D SDK                                           //
            // (c) 1989-2004 MAXON Computer GmbH, all rights reserved  //
            // generator object example (with no input objects)
            #include "c4d.h"
            #include "c4d_symbols.h"
            #include "oroundedtube.h"
            #define MY_SUBCONTAINER 1024882        //unique ID for the main-subcontaioner
            #define MY_SUBCONTAINER_CNT 1024883    //unique ID for storing the IDs of the sub-subcontainers
            class RoundedTube : public ObjectData
              INSTANCEOF(RoundedTube,ObjectData)
                  virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                  virtual Bool Message(GeListNode *node, LONG type, void *data);
                  virtual Bool GetDDescription(GeListNode *node, Description *description, LONG &flags);
                  static NodeData *Alloc(void) { return gNew RoundedTube; }
            Bool RoundedTube::Init(GeListNode *node)
              BaseContainer *data = ((BaseList2D* )node)->GetDataInstance(); if (!data) return FALSE;
              BaseContainer main;
              data->InsData(MY_SUBCONTAINER, main);        //insert the main-subcontainer
              data->SetLong(MY_SUBCONTAINER_CNT, 1000);    //store the intial ID for the sub-subcontainers
            Bool RoundedTube::Message(GeListNode *node, LONG type, void *data)
              switch (type)
                  case MSG_DESCRIPTION_COMMAND:
                      DescriptionCommand *dc = (DescriptionCommand* )data;
                      if (dc->id[0].id == MY_BUTTON)
                          BaseList2D *op = (BaseList2D* )node;
                          BaseDocument *doc = op->GetDocument(); if (!doc) return FALSE;
                          BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance(); if (!bc) return FALSE;
                          BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return FALSE;
                          doc->StartUndo();
                          BaseContainer object;
                          object.SetLink(MY_LINK, NULL);
                          object.SetReal(MY_VALUE, 0.0);
                          doc->AddUndo(UNDO_CHANGE_SMALL, node);
                          main->InsData(bc->GetLong(MY_SUBCONTAINER_CNT), object);    //insert the sub-subcontainer
                          bc->SetLong(MY_SUBCONTAINER_CNT, bc->GetLong(MY_SUBCONTAINER_CNT)+1);    //increase the sub-subcontainer ID
                          doc->EndUndo();
              return     SUPER::Message(node,type,data);
            Bool RoundedTube::GetDDescription(GeListNode *node, Description *description, LONG &flags)
              if (!description->LoadDescription(node->GetType())) return FALSE;
              // important to check for speedup c4d!
              const DescID *singleid = description->GetSingleDescID();
              BaseDocument *doc = ((BaseList2D* )node)->GetDocument();
              Bool initbc1 = FALSE;
              Bool initbc2 = FALSE;
              Bool initbc3 = FALSE;
              BaseContainer bc1, bc2, bc3;
              BrowseContainer brw(main);
              GeData *data = NULL;
              LONG id;
              while (brw.GetNext(&id,&data))    //browse through the main-subcontainer
                  if (data->GetType() != DA_CONTAINER) continue;
                  BaseContainer *object = data->GetContainer(); if (!object) continue;    //get the sub-subcontainer
                  //read out the sub-subcontainer and accordingly add the elements to the description
                  //MY_LINK, MY_VALUE and MY_SEPARATOR are defined along with the button ID (MY_BUTTON) in the header file
                  DescID cid = DescID(DescLevel(MY_LINK,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_BASELISTLINK,0));
                  if (!singleid || cid.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
                      if (!initbc1)
                          initbc1 = TRUE;
                          bc1 = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                          bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_LINKBOX);
                          bc1.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                          bc1.SetBool(DESC_REMOVEABLE, FALSE);
                      bc1.SetString(DESC_NAME, "Link");
                      bc1.SetString(DESC_SHORT_NAME, "Link");
                      if (!description->SetParameter(cid,bc1,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                  cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                      if (!initbc2)
                          initbc2 = TRUE;
                          bc2 = GetCustomDataTypeDefault(DTYPE_REAL);
                          bc2.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                          bc2.SetReal(DESC_MIN,0.0);
                          bc2.SetReal(DESC_MAX,1.0);
                          bc2.SetReal(DESC_STEP,0.01);
                          bc2.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                          bc2.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                          bc2.SetBool(DESC_REMOVEABLE, FALSE);
                      bc2.SetString(DESC_NAME, "Value");
                      bc2.SetString(DESC_SHORT_NAME, "Value");
                      if (!description->SetParameter(cid,bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                  cid = DescID(DescLevel(MY_SEPARATOR,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_SEPARATOR,0));
                      if (!initbc3)
                          initbc3 = TRUE;
                          bc3 = GetCustomDataTypeDefault(DTYPE_SEPARATOR);
                          bc3.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_SEPARATOR);
                          bc3.SetBool(DESC_SEPARATORLINE, TRUE);
                          bc3.SetLong(DESC_ANIMATE, DESC_ANIMATE_OFF);
                          bc3.SetBool(DESC_REMOVEABLE, FALSE);
                      bc3.SetString(DESC_NAME, "");
                      bc3.SetString(DESC_SHORT_NAME, "");
                      if (!description->SetParameter(cid,bc3,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
              return SUPER::GetDDescription(node,description,flags);
            BaseObject *RoundedTube::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
              return NULL;
            #define ID_ROUNDEDTUBEOBJECT 1001157
            Bool RegisterRoundedTube(void)
              // decide by name if the plugin shall be registered - just for user convenience
              String name=GeLoadString(IDS_ROUNDED_TUBE); if (!name.Content()) return TRUE;
              return RegisterObjectPlugin(ID_ROUNDEDTUBEOBJECT,name,OBJECT_GENERATOR,RoundedTube::Alloc,"Oroundedtube","roundedtube.tif",0);
            hope that helps
              On 17/01/2010 at 17:16, xxxxxxxx wrote:
              Thanks for your help Matthias .   I have another question about this.   I am able to add the new dynamic decription elements to my attributes manager,   Now how do I access the data from these new elements?  I would like to be able to draw from the new links and sliders..
              THanks,
              ~Shawn
                On 17/05/2010 at 05:54, xxxxxxxx wrote:
                sorry for digging out this old thread.
                I'm also using the example above and changed it slightly to fit my puropse. Now I also don't understand where the new values (in my case just the REAL value) are stored and how I can access them?
                In GetDDescription I tried:
                object->GetReal(MY_VALUE);
                main->GetReal(MY_VALUE);
                bc2.GetReal(MY_VALUE);
                bc->GetReal(MY_VALUE);
                a.s.o.
                so far it's try and error hoping to get the correct value by chance 😕
                Would be nice if someone could help out and explain where the values are stored and how I could access the new REAL value set in the attributes manager.
                Thanks.
                  On 19/05/2010 at 08:13, xxxxxxxx wrote:
                  Hey, no one here who could give me a hint?
                  I'm not an experienced programmer I'm doing this plugin for a students project and I spent hours trying to figur out this problem. Any help would be appreciated.
                  What I got so far:
                  If I press the Button
                  in Message ()
                  I create an new (Sub-Sub-) BaseContainer and insert it in the main SubContainer.
                  then in GetDDescription()
                  the main SubContainer ist fetched and with it a BrowseContainer is created.
                  With the BrowseContainer I browse through all the BaseContainer in the main Container and a new BaseContainer (bc2) with the Decription of the Parameters is created and added to the Description.
                   DescID cid = scID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                              if (!initbc2)
                                  initbc2 = TRUE;
                  Now I'm able to access the the Values stored in the SubContainer (the DESC_NAME...)
                  But unfortuntaly I can't get the values I enter in the REAL Box in the C4D Parameter Dialog. It seems that they are not stored in my object Sub-Sub- Container as I would've expected .
                  I just can't figure out where there are stored and how I'm able to access them.
                  Thanks for taking the time.
                    On 19/05/2010 at 09:27, xxxxxxxx wrote:
                    I will look into this tomorrow.
                      On 20/05/2010 at 23:48, xxxxxxxx wrote:
                      thanks that would be ace.
                        On 25/05/2010 at 12:08, xxxxxxxx wrote:
                        Hi Matthias, did you had the chance to look into it?
                        I don't want to bug you but I'm really desperate 😉
                          On 26/05/2010 at 02:11, xxxxxxxx wrote:
                          There was some small but important thing missing in my example. You have to overload the SetD/GetDParameter methods because we are storing dynamic elements in sub-containers.
                          Here is the complete code for a example with dynamic slider elements. In the overloaded GetVirtualObjects method you can see how to read out the values.
                          // CINEMA 4D SDK                                           //
                          #include "c4d.h"
                                virtual Bool GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags);
                                virtual Bool SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags);
                            BaseContainer main;
                            switch (type)
                                        doc->StartUndo();
                                        doc->EndUndo();
                            BaseContainer bc1;
                            LONG id;
                                DescID cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                    if (!initbc1)
                                        initbc1 = TRUE;
                                        bc1 = GetCustomDataTypeDefault(DTYPE_REAL);
                                        bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                                        bc1.SetReal(DESC_MIN,0.0);
                                        bc1.SetReal(DESC_MAX,1.0);
                                        bc1.SetReal(DESC_STEP,0.01);
                                        bc1.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                                    bc1.SetString(DESC_NAME, "Value");
                                    bc1.SetString(DESC_SHORT_NAME, "Value");
                          static BaseContainer *GetPose(GeListNode *node, LONG id)
                            BaseContainer *bc = ((BaseObject* )node)->GetDataInstance(); if (!bc) return NULL;
                            BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return NULL;
                            if (main->GetType(id)!=DA_CONTAINER) return NULL;
                            return main->GetContainerInstance(id);
                          Bool RoundedTube::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags)
                            BaseContainer *pose=NULL;
                            switch (id[0].id)
                                case MY_VALUE:
                                    pose = GetPose(node,id[1].id); if (!pose) return FALSE;
                                    t_data = pose->GetReal(MY_VALUE); flags |= DESCFLAGS_PARAM_GET;
                                break;
                            return SUPER::GetDParameter(node,id,t_data,flags);
                          Bool RoundedTube::SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags)
                            switch (id[0].id)
                                case MY_VALUE:
                                    pose->SetReal(MY_VALUE,t_data.GetReal()); flags |= DESCFLAGS_PARAM_SET;
                                break;
                            return SUPER::SetDParameter(node,id,t_data,flags);
                            BaseContainer *bc = op->GetDataInstance(); if (!bc) return FALSE;
                            LONG id;
                                GePrint("Value "+RealToString(object->GetReal(MY_VALUE)));        //print the value of each dynamic description element
                            return NULL;
                          hope this helps
                            On 26/05/2010 at 02:37, xxxxxxxx wrote:
                            Thank you so much! I just ran the example and it looks very promising 🙂
                            Now I'm gonna try to apply it to my plugin. You really helped me out here.
