    Updating Attributes Question
    21 Posts 0 Posters 12.5k Views
      On 30/12/2009 at 06:30, xxxxxxxx wrote:
      With each button click you have to add a new link item to the object's subcontainer. Then in GetDDescription() iterate through the subcontainer and display the elements accordingly. How is your interface supposed to look like? If you have several elements per dynamic inteface line I would recommend to add for each interface line an own subcontainer to the object's subcontainer.
        On 30/12/2009 at 06:48, xxxxxxxx wrote:
        This is what I have so far...    with this code I am able to insert two link elements but they are inserted separate from one another so all of the "OBJECT" links stay together and all the "PATH" links stay together.  I would like for the final interface to insert 2 links, 2 reals, a bool, and a long..     which will amount to 2 link boxes, to sliders, a check box, and a drop down menu with 2 elements inside of that.    I would like all of these elements to be inserted between 2 spearators so as to show that they are all a group.   Right now I am experimenting with the link elements but I am not getting the desired results.
        Could you possibly give me a little snippet example of how I would created an entire group of the elements I just mentioned.
        Here's what I have:
        Bool Planet::Message(GeListNode *node, LONG type, void *t_data)
          BaseObject* op = static_cast<BaseTag*>(node)->GetObject();
           if (!node)     return FALSE;
          DescriptionCommand *dc = (DescriptionCommand* ) t_data;
          switch (type)
              case MSG_DESCRIPTION_COMMAND:
                  if (dc->id[0].id==ADD_ORBIT_OBJECT)
                      GePrint("Adding an OBJECT");
                      BaseList2D *op = (BaseList2D* ) node;
                      BaseDocument *doc = op->GetDocument(); if (!doc) return FALSE;
                      BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance(); if (!bc) return FALSE;
                      BaseContainer *main = bc->GetContainerInstance(ID_PLANET_OBJECT); if (!main) return FALSE;
                      doc->StartUndo();
                      doc->AddUndo(UNDO_CHANGE_SMALL,node);
                      GePrint("Insert OBJ");
                      main->SetLong(ORBIT_OBJ_CNT, main->GetLong(ORBIT_OBJ_CNT,0)+1);
                      GePrint("Insert PTH");
                      main->SetLong(ORBIT_PTH_CNT, main->GetLong(ORBIT_PTH_CNT,0)+1);
                      doc->EndUndo();
                      op->Message(MSG_CHANGE);
              case MSG_DESCRIPTION_CHECKUPDATE:
                  //Update Planet
                  GePrint("UPDATED");
                  return UpdatePlanet(static_cast<BaseObject*>(node), static_cast<GeListNode*>(node));
           if (planetCreated <1)
               CreatePlanet(op,node);
        Bool Planet::GetDDescription(GeListNode *node, Description *description,LONG &flags)
           if (!description->LoadDescription(node->GetType())) return FALSE;
          // important to check for speedup c4d!
          const DescID *singleid = description->GetSingleDescID();
          LONG index1 = ORBIT_INDEX1;
          LONG index2 = ORBIT_INDEX2;
          BaseObject *op = (BaseObject* )node;
          BaseContainer *data = op->GetDataInstance();
          BaseContainer *main = data->GetContainerInstance(ID_PLANET_OBJECT);
          LONG i,cnt = main->GetLong(ORBIT_OBJ_CNT,0);
          LONG j,cnt1 = main->GetLong(ORBIT_PTH_CNT,0);
          Bool initbc2 = FALSE;
          Bool initbc3 = FALSE;
          BaseContainer bc2;
          BaseContainer bc3;
          for (i=0; i<cnt; i++)
              DescID cid = DescLevel(index1,DTYPE_BASELISTLINK,0);
              if (!singleid || cid.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
                  if (!initbc2)
                      GePrint("OBJ 1");
                      initbc2 = TRUE;
                      bc2 = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                      bc2.SetLong(DESC_ANIMATE,DESC_ANIMATE_ON);
                      bc2.SetBool(DESC_REMOVEABLE,TRUE);
                  GePrint("OBJ 2");
                  bc2.SetString(DESC_NAME,"Orbiting Object " +LongToString(i));
                  bc2.SetString(DESC_SHORT_NAME,"Orbiting Object "+LongToString(i));
                  if (!description->SetParameter(cid,bc2,DescLevel(ID_ORBITOPTIONS_TAB))) return FALSE;
              GePrint("OBJ 3");
              index1++;
              GePrint("Index 1 = " + LongToString(index1));
              for (j=0; j<cnt1; j++)
              DescID cid1 = DescLevel(index2,DTYPE_BASELISTLINK,0);
              if (!singleid || cid1.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
                  if (!initbc3)
                      GePrint("PTH 1");
                      initbc3 = TRUE;
                  GePrint("PTH 2");
                  bc2.SetString(DESC_NAME,"Orbit Path " +LongToString(j));
                  bc2.SetString(DESC_SHORT_NAME,"Orbit Path "+LongToString(j));
                  if (!description->SetParameter(cid1,bc2,DescLevel(ID_ORBITOPTIONS_TAB))) return FALSE;
              GePrint("PTH 3");
              index2++;
              GePrint("Index 2 = " + LongToString(index2));
          //return Planet::GetDDescription(node,description,flags);
        ~Shawn
          On 30/12/2009 at 06:53, xxxxxxxx wrote:
          Maybe you can post a screenshot of how it should look like?
            On 30/12/2009 at 06:57, xxxxxxxx wrote:
            I'll grab one now.
              On 30/12/2009 at 07:06, xxxxxxxx wrote:
              Here is a pic of what I mean.   The elements between the red lines were added again in photoshop to show what I would like to happen when the user presses the button.   ..  minus the Add button..    I accidentally included it in the copy but I don't want the button to be added again.   I am going to throw a sperator in there to block that off..
              ~Shawn
                On 30/12/2009 at 15:40, xxxxxxxx wrote:
                Does that make sense?
                  On 31/12/2009 at 05:15, xxxxxxxx wrote:
                  I did not had the time to look at it yet. There are holidays over here in Germany. Will post back after the weekend.
                    On 01/01/2010 at 15:42, xxxxxxxx wrote:
                    Thank you .  I appreciate your help very much.
                    ~Shawn
                      On 04/01/2010 at 12:56, xxxxxxxx wrote:
                      Any info on this?    Thanks,
                      ~Shawn
                        On 05/01/2010 at 05:38, xxxxxxxx wrote:
                        Here is the complete code of a simple example of a generator (doing nothing) with a dynamic description similar to what you want. The elements for each dynamic decription group are saved in a respective sub-subcontainer. Please check the comments within the sorce code for more details.
                        // CINEMA 4D SDK                                           //
                        // (c) 1989-2004 MAXON Computer GmbH, all rights reserved  //
                        // generator object example (with no input objects)
                        #include "c4d.h"
                        #include "c4d_symbols.h"
                        #include "oroundedtube.h"
                        #define MY_SUBCONTAINER 1024882        //unique ID for the main-subcontaioner
                        #define MY_SUBCONTAINER_CNT 1024883    //unique ID for storing the IDs of the sub-subcontainers
                        class RoundedTube : public ObjectData
                          INSTANCEOF(RoundedTube,ObjectData)
                              virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                              virtual Bool Message(GeListNode *node, LONG type, void *data);
                              virtual Bool GetDDescription(GeListNode *node, Description *description, LONG &flags);
                              static NodeData *Alloc(void) { return gNew RoundedTube; }
                        Bool RoundedTube::Init(GeListNode *node)
                          BaseContainer *data = ((BaseList2D* )node)->GetDataInstance(); if (!data) return FALSE;
                          BaseContainer main;
                          data->InsData(MY_SUBCONTAINER, main);        //insert the main-subcontainer
                          data->SetLong(MY_SUBCONTAINER_CNT, 1000);    //store the intial ID for the sub-subcontainers
                        Bool RoundedTube::Message(GeListNode *node, LONG type, void *data)
                          switch (type)
                                  DescriptionCommand *dc = (DescriptionCommand* )data;
                                  if (dc->id[0].id == MY_BUTTON)
                                      BaseList2D *op = (BaseList2D* )node;
                                      BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return FALSE;
                                      doc->StartUndo();
                                      BaseContainer object;
                                      object.SetLink(MY_LINK, NULL);
                                      object.SetReal(MY_VALUE, 0.0);
                                      doc->AddUndo(UNDO_CHANGE_SMALL, node);
                                      main->InsData(bc->GetLong(MY_SUBCONTAINER_CNT), object);    //insert the sub-subcontainer
                                      bc->SetLong(MY_SUBCONTAINER_CNT, bc->GetLong(MY_SUBCONTAINER_CNT)+1);    //increase the sub-subcontainer ID
                                      doc->EndUndo();
                          return     SUPER::Message(node,type,data);
                        Bool RoundedTube::GetDDescription(GeListNode *node, Description *description, LONG &flags)
                          BaseDocument *doc = ((BaseList2D* )node)->GetDocument();
                          Bool initbc1 = FALSE;
                          BaseContainer bc1, bc2, bc3;
                          BrowseContainer brw(main);
                          GeData *data = NULL;
                          LONG id;
                          while (brw.GetNext(&id,&data))    //browse through the main-subcontainer
                              if (data->GetType() != DA_CONTAINER) continue;
                              BaseContainer *object = data->GetContainer(); if (!object) continue;    //get the sub-subcontainer
                              //read out the sub-subcontainer and accordingly add the elements to the description
                              //MY_LINK, MY_VALUE and MY_SEPARATOR are defined along with the button ID (MY_BUTTON) in the header file
                              DescID cid = DescID(DescLevel(MY_LINK,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_BASELISTLINK,0));
                                  if (!initbc1)
                                      initbc1 = TRUE;
                                      bc1 = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                                      bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_LINKBOX);
                                      bc1.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                                      bc1.SetBool(DESC_REMOVEABLE, FALSE);
                                  bc1.SetString(DESC_NAME, "Link");
                                  bc1.SetString(DESC_SHORT_NAME, "Link");
                                  if (!description->SetParameter(cid,bc1,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                              cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                  if (!initbc2)
                                      initbc2 = TRUE;
                                      bc2 = GetCustomDataTypeDefault(DTYPE_REAL);
                                      bc2.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                                      bc2.SetReal(DESC_MIN,0.0);
                                      bc2.SetReal(DESC_MAX,1.0);
                                      bc2.SetReal(DESC_STEP,0.01);
                                      bc2.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                                      bc2.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                                      bc2.SetBool(DESC_REMOVEABLE, FALSE);
                                  bc2.SetString(DESC_NAME, "Value");
                                  bc2.SetString(DESC_SHORT_NAME, "Value");
                                  if (!description->SetParameter(cid,bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                              cid = DescID(DescLevel(MY_SEPARATOR,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_SEPARATOR,0));
                                  if (!initbc3)
                                      initbc3 = TRUE;
                                      bc3 = GetCustomDataTypeDefault(DTYPE_SEPARATOR);
                                      bc3.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_SEPARATOR);
                                      bc3.SetBool(DESC_SEPARATORLINE, TRUE);
                                      bc3.SetLong(DESC_ANIMATE, DESC_ANIMATE_OFF);
                                      bc3.SetBool(DESC_REMOVEABLE, FALSE);
                                  bc3.SetString(DESC_NAME, "");
                                  bc3.SetString(DESC_SHORT_NAME, "");
                                  if (!description->SetParameter(cid,bc3,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                          return SUPER::GetDDescription(node,description,flags);
                        BaseObject *RoundedTube::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                          return NULL;
                        #define ID_ROUNDEDTUBEOBJECT 1001157
                        Bool RegisterRoundedTube(void)
                          // decide by name if the plugin shall be registered - just for user convenience
                          String name=GeLoadString(IDS_ROUNDED_TUBE); if (!name.Content()) return TRUE;
                          return RegisterObjectPlugin(ID_ROUNDEDTUBEOBJECT,name,OBJECT_GENERATOR,RoundedTube::Alloc,"Oroundedtube","roundedtube.tif",0);
                        hope that helps
                          On 17/01/2010 at 17:16, xxxxxxxx wrote:
                          Thanks for your help Matthias .   I have another question about this.   I am able to add the new dynamic decription elements to my attributes manager,   Now how do I access the data from these new elements?  I would like to be able to draw from the new links and sliders..
                          THanks,
                          ~Shawn
                            On 17/05/2010 at 05:54, xxxxxxxx wrote:
                            sorry for digging out this old thread.
                            I'm also using the example above and changed it slightly to fit my puropse. Now I also don't understand where the new values (in my case just the REAL value) are stored and how I can access them?
                            In GetDDescription I tried:
                            object->GetReal(MY_VALUE);
                            main->GetReal(MY_VALUE);
                            bc2.GetReal(MY_VALUE);
                            bc->GetReal(MY_VALUE);
                            a.s.o.
                            so far it's try and error hoping to get the correct value by chance 😕
                            Would be nice if someone could help out and explain where the values are stored and how I could access the new REAL value set in the attributes manager.
                            Thanks.
                              On 19/05/2010 at 08:13, xxxxxxxx wrote:
                              Hey, no one here who could give me a hint?
                              I'm not an experienced programmer I'm doing this plugin for a students project and I spent hours trying to figur out this problem. Any help would be appreciated.
                              What I got so far:
                              If I press the Button
                              in Message ()
                              I create an new (Sub-Sub-) BaseContainer and insert it in the main SubContainer.
                              then in GetDDescription()
                              the main SubContainer ist fetched and with it a BrowseContainer is created.
                              With the BrowseContainer I browse through all the BaseContainer in the main Container and a new BaseContainer (bc2) with the Decription of the Parameters is created and added to the Description.
                               DescID cid = scID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                          if (!initbc2)
                                              initbc2 = TRUE;
                              Now I'm able to access the the Values stored in the SubContainer (the DESC_NAME...)
                              But unfortuntaly I can't get the values I enter in the REAL Box in the C4D Parameter Dialog. It seems that they are not stored in my object Sub-Sub- Container as I would've expected .
                              I just can't figure out where there are stored and how I'm able to access them.
                              Thanks for taking the time.
                                On 19/05/2010 at 09:27, xxxxxxxx wrote:
                                I will look into this tomorrow.
                                  On 20/05/2010 at 23:48, xxxxxxxx wrote:
                                  thanks that would be ace.
                                    On 25/05/2010 at 12:08, xxxxxxxx wrote:
                                    Hi Matthias, did you had the chance to look into it?
                                    I don't want to bug you but I'm really desperate 😉
                                      On 26/05/2010 at 02:11, xxxxxxxx wrote:
                                      There was some small but important thing missing in my example. You have to overload the SetD/GetDParameter methods because we are storing dynamic elements in sub-containers.
                                      Here is the complete code for a example with dynamic slider elements. In the overloaded GetVirtualObjects method you can see how to read out the values.
                                      // CINEMA 4D SDK                                           //
                                      #include "c4d.h"
                                            virtual Bool GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags);
                                            virtual Bool SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags);
                                        BaseContainer main;
                                        switch (type)
                                                    doc->StartUndo();
                                                    doc->EndUndo();
                                        BaseContainer bc1;
                                        LONG id;
                                            DescID cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                                if (!initbc1)
                                                    initbc1 = TRUE;
                                                    bc1 = GetCustomDataTypeDefault(DTYPE_REAL);
                                                    bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                                                    bc1.SetReal(DESC_MIN,0.0);
                                                    bc1.SetReal(DESC_MAX,1.0);
                                                    bc1.SetReal(DESC_STEP,0.01);
                                                    bc1.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                                                bc1.SetString(DESC_NAME, "Value");
                                                bc1.SetString(DESC_SHORT_NAME, "Value");
                                      static BaseContainer *GetPose(GeListNode *node, LONG id)
                                        BaseContainer *bc = ((BaseObject* )node)->GetDataInstance(); if (!bc) return NULL;
                                        BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return NULL;
                                        if (main->GetType(id)!=DA_CONTAINER) return NULL;
                                        return main->GetContainerInstance(id);
                                      Bool RoundedTube::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags)
                                        BaseContainer *pose=NULL;
                                        switch (id[0].id)
                                            case MY_VALUE:
                                                pose = GetPose(node,id[1].id); if (!pose) return FALSE;
                                                t_data = pose->GetReal(MY_VALUE); flags |= DESCFLAGS_PARAM_GET;
                                            break;
                                        return SUPER::GetDParameter(node,id,t_data,flags);
                                      Bool RoundedTube::SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags)
                                        switch (id[0].id)
                                            case MY_VALUE:
                                                pose->SetReal(MY_VALUE,t_data.GetReal()); flags |= DESCFLAGS_PARAM_SET;
                                            break;
                                        return SUPER::SetDParameter(node,id,t_data,flags);
                                        BaseContainer *bc = op->GetDataInstance(); if (!bc) return FALSE;
                                        LONG id;
                                            GePrint("Value "+RealToString(object->GetReal(MY_VALUE)));        //print the value of each dynamic description element
                                        return NULL;
                                      hope this helps
                                        On 26/05/2010 at 02:37, xxxxxxxx wrote:
                                        Thank you so much! I just ran the example and it looks very promising 🙂
                                        Now I'm gonna try to apply it to my plugin. You really helped me out here.
