    Updating Attributes Question
    21 Posts 0 Posters 12.6k Views
      On 30/12/2009 at 07:06, xxxxxxxx wrote:
      Here is a pic of what I mean.   The elements between the red lines were added again in photoshop to show what I would like to happen when the user presses the button.   ..  minus the Add button..    I accidentally included it in the copy but I don't want the button to be added again.   I am going to throw a sperator in there to block that off..
      ~Shawn
        On 30/12/2009 at 15:40, xxxxxxxx wrote:
        Does that make sense?
          On 31/12/2009 at 05:15, xxxxxxxx wrote:
          I did not had the time to look at it yet. There are holidays over here in Germany. Will post back after the weekend.
            On 01/01/2010 at 15:42, xxxxxxxx wrote:
            Thank you .  I appreciate your help very much.
            ~Shawn
              On 04/01/2010 at 12:56, xxxxxxxx wrote:
              Any info on this?    Thanks,
              ~Shawn
                On 05/01/2010 at 05:38, xxxxxxxx wrote:
                Here is the complete code of a simple example of a generator (doing nothing) with a dynamic description similar to what you want. The elements for each dynamic decription group are saved in a respective sub-subcontainer. Please check the comments within the sorce code for more details.
                // CINEMA 4D SDK                                           //
                // (c) 1989-2004 MAXON Computer GmbH, all rights reserved  //
                // generator object example (with no input objects)
                #include "c4d.h"
                #include "c4d_symbols.h"
                #include "oroundedtube.h"
                #define MY_SUBCONTAINER 1024882        //unique ID for the main-subcontaioner
                #define MY_SUBCONTAINER_CNT 1024883    //unique ID for storing the IDs of the sub-subcontainers
                class RoundedTube : public ObjectData
                  INSTANCEOF(RoundedTube,ObjectData)
                      virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh);
                      virtual Bool Message(GeListNode *node, LONG type, void *data);
                      virtual Bool GetDDescription(GeListNode *node, Description *description, LONG &flags);
                      static NodeData *Alloc(void) { return gNew RoundedTube; }
                Bool RoundedTube::Init(GeListNode *node)
                  BaseContainer *data = ((BaseList2D* )node)->GetDataInstance(); if (!data) return FALSE;
                  BaseContainer main;
                  data->InsData(MY_SUBCONTAINER, main);        //insert the main-subcontainer
                  data->SetLong(MY_SUBCONTAINER_CNT, 1000);    //store the intial ID for the sub-subcontainers
                Bool RoundedTube::Message(GeListNode *node, LONG type, void *data)
                  switch (type)
                      case MSG_DESCRIPTION_COMMAND:
                          DescriptionCommand *dc = (DescriptionCommand* )data;
                          if (dc->id[0].id == MY_BUTTON)
                              BaseList2D *op = (BaseList2D* )node;
                              BaseDocument *doc = op->GetDocument(); if (!doc) return FALSE;
                              BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance(); if (!bc) return FALSE;
                              BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return FALSE;
                              doc->StartUndo();
                              BaseContainer object;
                              object.SetLink(MY_LINK, NULL);
                              object.SetReal(MY_VALUE, 0.0);
                              doc->AddUndo(UNDO_CHANGE_SMALL, node);
                              main->InsData(bc->GetLong(MY_SUBCONTAINER_CNT), object);    //insert the sub-subcontainer
                              bc->SetLong(MY_SUBCONTAINER_CNT, bc->GetLong(MY_SUBCONTAINER_CNT)+1);    //increase the sub-subcontainer ID
                              doc->EndUndo();
                  return     SUPER::Message(node,type,data);
                Bool RoundedTube::GetDDescription(GeListNode *node, Description *description, LONG &flags)
                  if (!description->LoadDescription(node->GetType())) return FALSE;
                  // important to check for speedup c4d!
                  const DescID *singleid = description->GetSingleDescID();
                  BaseDocument *doc = ((BaseList2D* )node)->GetDocument();
                  Bool initbc1 = FALSE;
                  Bool initbc2 = FALSE;
                  Bool initbc3 = FALSE;
                  BaseContainer bc1, bc2, bc3;
                  BrowseContainer brw(main);
                  GeData *data = NULL;
                  LONG id;
                  while (brw.GetNext(&id,&data))    //browse through the main-subcontainer
                      if (data->GetType() != DA_CONTAINER) continue;
                      BaseContainer *object = data->GetContainer(); if (!object) continue;    //get the sub-subcontainer
                      //read out the sub-subcontainer and accordingly add the elements to the description
                      //MY_LINK, MY_VALUE and MY_SEPARATOR are defined along with the button ID (MY_BUTTON) in the header file
                      DescID cid = DescID(DescLevel(MY_LINK,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_BASELISTLINK,0));
                      if (!singleid || cid.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
                          if (!initbc1)
                              initbc1 = TRUE;
                              bc1 = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                              bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_LINKBOX);
                              bc1.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                              bc1.SetBool(DESC_REMOVEABLE, FALSE);
                          bc1.SetString(DESC_NAME, "Link");
                          bc1.SetString(DESC_SHORT_NAME, "Link");
                          if (!description->SetParameter(cid,bc1,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                      cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                          if (!initbc2)
                              initbc2 = TRUE;
                              bc2 = GetCustomDataTypeDefault(DTYPE_REAL);
                              bc2.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                              bc2.SetReal(DESC_MIN,0.0);
                              bc2.SetReal(DESC_MAX,1.0);
                              bc2.SetReal(DESC_STEP,0.01);
                              bc2.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                              bc2.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON);
                              bc2.SetBool(DESC_REMOVEABLE, FALSE);
                          bc2.SetString(DESC_NAME, "Value");
                          bc2.SetString(DESC_SHORT_NAME, "Value");
                          if (!description->SetParameter(cid,bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                      cid = DescID(DescLevel(MY_SEPARATOR,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_SEPARATOR,0));
                          if (!initbc3)
                              initbc3 = TRUE;
                              bc3 = GetCustomDataTypeDefault(DTYPE_SEPARATOR);
                              bc3.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_SEPARATOR);
                              bc3.SetBool(DESC_SEPARATORLINE, TRUE);
                              bc3.SetLong(DESC_ANIMATE, DESC_ANIMATE_OFF);
                              bc3.SetBool(DESC_REMOVEABLE, FALSE);
                          bc3.SetString(DESC_NAME, "");
                          bc3.SetString(DESC_SHORT_NAME, "");
                          if (!description->SetParameter(cid,bc3,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
                  return SUPER::GetDDescription(node,description,flags);
                BaseObject *RoundedTube::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                  return NULL;
                #define ID_ROUNDEDTUBEOBJECT 1001157
                Bool RegisterRoundedTube(void)
                  // decide by name if the plugin shall be registered - just for user convenience
                  String name=GeLoadString(IDS_ROUNDED_TUBE); if (!name.Content()) return TRUE;
                  return RegisterObjectPlugin(ID_ROUNDEDTUBEOBJECT,name,OBJECT_GENERATOR,RoundedTube::Alloc,"Oroundedtube","roundedtube.tif",0);
                hope that helps
                  On 17/01/2010 at 17:16, xxxxxxxx wrote:
                  Thanks for your help Matthias .   I have another question about this.   I am able to add the new dynamic decription elements to my attributes manager,   Now how do I access the data from these new elements?  I would like to be able to draw from the new links and sliders..
                  THanks,
                  ~Shawn
                    On 17/05/2010 at 05:54, xxxxxxxx wrote:
                    sorry for digging out this old thread.
                    I'm also using the example above and changed it slightly to fit my puropse. Now I also don't understand where the new values (in my case just the REAL value) are stored and how I can access them?
                    In GetDDescription I tried:
                    object->GetReal(MY_VALUE);
                    main->GetReal(MY_VALUE);
                    bc2.GetReal(MY_VALUE);
                    bc->GetReal(MY_VALUE);
                    a.s.o.
                    so far it's try and error hoping to get the correct value by chance 😕
                    Would be nice if someone could help out and explain where the values are stored and how I could access the new REAL value set in the attributes manager.
                    Thanks.
                      On 19/05/2010 at 08:13, xxxxxxxx wrote:
                      Hey, no one here who could give me a hint?
                      I'm not an experienced programmer I'm doing this plugin for a students project and I spent hours trying to figur out this problem. Any help would be appreciated.
                      What I got so far:
                      If I press the Button
                      in Message ()
                      I create an new (Sub-Sub-) BaseContainer and insert it in the main SubContainer.
                      then in GetDDescription()
                      the main SubContainer ist fetched and with it a BrowseContainer is created.
                      With the BrowseContainer I browse through all the BaseContainer in the main Container and a new BaseContainer (bc2) with the Decription of the Parameters is created and added to the Description.
                       DescID cid = scID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                  if (!initbc2)
                                      initbc2 = TRUE;
                      Now I'm able to access the the Values stored in the SubContainer (the DESC_NAME...)
                      But unfortuntaly I can't get the values I enter in the REAL Box in the C4D Parameter Dialog. It seems that they are not stored in my object Sub-Sub- Container as I would've expected .
                      I just can't figure out where there are stored and how I'm able to access them.
                      Thanks for taking the time.
                        On 19/05/2010 at 09:27, xxxxxxxx wrote:
                        I will look into this tomorrow.
                          On 20/05/2010 at 23:48, xxxxxxxx wrote:
                          thanks that would be ace.
                            On 25/05/2010 at 12:08, xxxxxxxx wrote:
                            Hi Matthias, did you had the chance to look into it?
                            I don't want to bug you but I'm really desperate 😉
                              On 26/05/2010 at 02:11, xxxxxxxx wrote:
                              There was some small but important thing missing in my example. You have to overload the SetD/GetDParameter methods because we are storing dynamic elements in sub-containers.
                              Here is the complete code for a example with dynamic slider elements. In the overloaded GetVirtualObjects method you can see how to read out the values.
                              // CINEMA 4D SDK                                           //
                              #include "c4d.h"
                                    virtual Bool GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags);
                                    virtual Bool SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags);
                                BaseContainer main;
                                switch (type)
                                            doc->StartUndo();
                                            doc->EndUndo();
                                BaseContainer bc1;
                                LONG id;
                                    DescID cid = DescID(DescLevel(MY_VALUE,DTYPE_SUBCONTAINER,0), DescLevel(id,DTYPE_REAL,0));
                                        if (!initbc1)
                                            initbc1 = TRUE;
                                            bc1 = GetCustomDataTypeDefault(DTYPE_REAL);
                                            bc1.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_REALSLIDER);
                                            bc1.SetReal(DESC_MIN,0.0);
                                            bc1.SetReal(DESC_MAX,1.0);
                                            bc1.SetReal(DESC_STEP,0.01);
                                            bc1.SetLong(DESC_UNIT,DESC_UNIT_PERCENT);
                                        bc1.SetString(DESC_NAME, "Value");
                                        bc1.SetString(DESC_SHORT_NAME, "Value");
                              static BaseContainer *GetPose(GeListNode *node, LONG id)
                                BaseContainer *bc = ((BaseObject* )node)->GetDataInstance(); if (!bc) return NULL;
                                BaseContainer *main  = bc->GetContainerInstance(MY_SUBCONTAINER); if (!main) return NULL;
                                if (main->GetType(id)!=DA_CONTAINER) return NULL;
                                return main->GetContainerInstance(id);
                              Bool RoundedTube::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags)
                                BaseContainer *pose=NULL;
                                switch (id[0].id)
                                    case MY_VALUE:
                                        pose = GetPose(node,id[1].id); if (!pose) return FALSE;
                                        t_data = pose->GetReal(MY_VALUE); flags |= DESCFLAGS_PARAM_GET;
                                    break;
                                return SUPER::GetDParameter(node,id,t_data,flags);
                              Bool RoundedTube::SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, LONG &flags)
                                switch (id[0].id)
                                    case MY_VALUE:
                                        pose->SetReal(MY_VALUE,t_data.GetReal()); flags |= DESCFLAGS_PARAM_SET;
                                    break;
                                return SUPER::SetDParameter(node,id,t_data,flags);
                                BaseContainer *bc = op->GetDataInstance(); if (!bc) return FALSE;
                                LONG id;
                                    GePrint("Value "+RealToString(object->GetReal(MY_VALUE)));        //print the value of each dynamic description element
                                return NULL;
                              hope this helps
                                On 26/05/2010 at 02:37, xxxxxxxx wrote:
                                Thank you so much! I just ran the example and it looks very promising 🙂
                                Now I'm gonna try to apply it to my plugin. You really helped me out here.
