    Moving keyframes
    14 Posts 0 Posters 1.2k Views
      On 14/11/2008 at 12:13, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      Platform:      Mac OSX  ;
      is it possible to move the keyframes of an object? I get the impression that these commands (bottom post) may hold the answer, but I don't know where to start. With R11 is it possible to shift Motion Clips along the timeline?
      Jon
        On 14/11/2008 at 13:12, xxxxxxxx wrote:
        You can move keyframes in R11 but not R10 and there is no access to R11 Motion Clips (not even in C++ afaict). The COFFEE in R10 was still R9.5-related but the entire animation system changed in R10.
          On 14/11/2008 at 13:21, xxxxxxxx wrote:
          Ah OK... thanks for all the help Robert. So how would I go about doing that in R11? I'd like to have a crack on the demo.
            On 14/11/2008 at 14:10, xxxxxxxx wrote:
            Good question. 🙂 I haven't used any new R11 COFFEE features yet. As that post you linked pointed out, there are a new set of classes for the new animation system - but no COFFEE docs yet to explain the innards. I'd suspect some similarities to the same C++ classes but then... (and Matthias points that out)
            The problem is how to get at the object's animation tracks. It may be as simple as op->GetFirstTrack() or it may be the new C++ way as in op->GetFirst C Track().
              On 14/11/2008 at 14:23, xxxxxxxx wrote:
              Thanks again. I'll have a play when I get a chance, and let you know of any findings if I have any luck (with my limited experience I wouldn't hold your breath though 😉
              Some official documentation would be very welcome.
              Jon
                On 17/11/2008 at 11:13, xxxxxxxx wrote:
                OK... with R11 I've managed to change the key frame values:
                main(doc,op)
                var obj = doc->FindObject("Cube");
                var track = obj->GetFirstCTrack();
                var myKey = track->GetCurve()->GetKey(0); // key 0 is first key frame
                myKey->SetValue(track->GetCurve(),70); // in this case, changes x pos to 70 m
                That's all good, but I can't figure out how to move the keyframe positions in the timeline. This doesn't work (an attempt to move the key frame to frame 10:
                myKey->SetTime(10,doc->GetFps());
                Does anyone know how to achieve this?
                Jon
                  On 17/11/2008 at 11:32, xxxxxxxx wrote:
                  In C++, it is: key->SetTime(CCurve, BaseTime);
                  So, you might want to try it like this:
                  var time = BaseTime();
                  myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps()));
                    On 17/11/2008 at 11:53, xxxxxxxx wrote:
                    Hey Robert,
                    thanks for the super quick reply!
                    An error is thrown at BaseTime() ... 'CLASS is not a function'.
                    I tried swapping with:
                    var time = myKey->GetTime();
                    ... but nothing happens.
                    Any thoughts?
                      On 17/11/2008 at 12:58, xxxxxxxx wrote:
                      That's interesting considering there is a function in the BaseTime class BaseTime(). 🙂
                      You could try:
                      var time = doc->GetTime();
                      and go from there.
                        On 17/11/2008 at 15:25, xxxxxxxx wrote:
                        Thanks again, but no joy. I've tried all manner of nonsense, but I'm shooting in the dark.
                        Is this to be unknown until official documentation?
                          On 17/11/2008 at 15:56, xxxxxxxx wrote:
                          I think you must fill the BaseTime with a value.
                          var bt = new(BaseTime);
                          bt->SetData(/*the time you want*/);
                          You then use bt as your time to set a key (or anything else).
                          Lennart
                            On 18/11/2008 at 02:50, xxxxxxxx wrote:
                            Blimey what a palaver that was!
                            Thanks so much Robert and Lennart for helping to steer me in the right direction.
                            This seems to work:
                            > \> main(doc,op) \> { \> \> var obj = doc->FindObject("Cube"); \> var track = obj->GetFirstCTrack(); \> var myKey = track->GetCurve()->GetKey()); // key 0 is first key \> var time = new(BaseTime); \> time = doc->GetTime(); \> myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps())); // move key frame to frame 10 \> \> } \>
                              On 18/11/2008 at 04:38, xxxxxxxx wrote:
                              Apologies, major balls-up!
                              Above code doesn't work (aside from typo 'GetKey(0)') - don't know what's going on - I did get it to work, but not with above code. Aaah!
                                On 18/11/2008 at 05:14, xxxxxxxx wrote:
                                Phew! I'm able to wipe that ostrich egg off my face...
                                main(doc,op)
                                var myKey = track->GetCurve()->GetKey(0)); // key 0 is first key
                                time->SetFrame(10, doc->GetFps()); // move key frame to frame 10
                                myKey->SetTime(track->GetCurve(), time);
