    Moving keyframes
    14 Posts 0 Posters 1.4k Views
      On 14/11/2008 at 14:23, xxxxxxxx wrote:
      Thanks again. I'll have a play when I get a chance, and let you know of any findings if I have any luck (with my limited experience I wouldn't hold your breath though 😉
      Some official documentation would be very welcome.
      Jon
        On 17/11/2008 at 11:13, xxxxxxxx wrote:
        OK... with R11 I've managed to change the key frame values:
        main(doc,op)
        var obj = doc->FindObject("Cube");
        var track = obj->GetFirstCTrack();
        var myKey = track->GetCurve()->GetKey(0); // key 0 is first key frame
        myKey->SetValue(track->GetCurve(),70); // in this case, changes x pos to 70 m
        That's all good, but I can't figure out how to move the keyframe positions in the timeline. This doesn't work (an attempt to move the key frame to frame 10:
        myKey->SetTime(10,doc->GetFps());
        Does anyone know how to achieve this?
        Jon
          On 17/11/2008 at 11:32, xxxxxxxx wrote:
          In C++, it is: key->SetTime(CCurve, BaseTime);
          So, you might want to try it like this:
          var time = BaseTime();
          myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps()));
            On 17/11/2008 at 11:53, xxxxxxxx wrote:
            Hey Robert,
            thanks for the super quick reply!
            An error is thrown at BaseTime() ... 'CLASS is not a function'.
            I tried swapping with:
            var time = myKey->GetTime();
            ... but nothing happens.
            Any thoughts?
              On 17/11/2008 at 12:58, xxxxxxxx wrote:
              That's interesting considering there is a function in the BaseTime class BaseTime(). 🙂
              You could try:
              var time = doc->GetTime();
              and go from there.
                On 17/11/2008 at 15:25, xxxxxxxx wrote:
                Thanks again, but no joy. I've tried all manner of nonsense, but I'm shooting in the dark.
                Is this to be unknown until official documentation?
                  On 17/11/2008 at 15:56, xxxxxxxx wrote:
                  I think you must fill the BaseTime with a value.
                  var bt = new(BaseTime);
                  bt->SetData(/*the time you want*/);
                  You then use bt as your time to set a key (or anything else).
                  Lennart
                    On 18/11/2008 at 02:50, xxxxxxxx wrote:
                    Blimey what a palaver that was!
                    Thanks so much Robert and Lennart for helping to steer me in the right direction.
                    This seems to work:
                    > \> main(doc,op) \> { \> \> var obj = doc->FindObject("Cube"); \> var track = obj->GetFirstCTrack(); \> var myKey = track->GetCurve()->GetKey()); // key 0 is first key \> var time = new(BaseTime); \> time = doc->GetTime(); \> myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps())); // move key frame to frame 10 \> \> } \>
                      On 18/11/2008 at 04:38, xxxxxxxx wrote:
                      Apologies, major balls-up!
                      Above code doesn't work (aside from typo 'GetKey(0)') - don't know what's going on - I did get it to work, but not with above code. Aaah!
                        On 18/11/2008 at 05:14, xxxxxxxx wrote:
                        Phew! I'm able to wipe that ostrich egg off my face...
                        main(doc,op)
                        var myKey = track->GetCurve()->GetKey(0)); // key 0 is first key
                        time->SetFrame(10, doc->GetFps()); // move key frame to frame 10
                        myKey->SetTime(track->GetCurve(), time);
