    Moving keyframes
    14 Posts 0 Posters 1.4k Views
      On 14/11/2008 at 13:21, xxxxxxxx wrote:
      Ah OK... thanks for all the help Robert. So how would I go about doing that in R11? I'd like to have a crack on the demo.
        On 14/11/2008 at 14:10, xxxxxxxx wrote:
        Good question. 🙂 I haven't used any new R11 COFFEE features yet. As that post you linked pointed out, there are a new set of classes for the new animation system - but no COFFEE docs yet to explain the innards. I'd suspect some similarities to the same C++ classes but then... (and Matthias points that out)
        The problem is how to get at the object's animation tracks. It may be as simple as op->GetFirstTrack() or it may be the new C++ way as in op->GetFirst C Track().
          On 14/11/2008 at 14:23, xxxxxxxx wrote:
          Thanks again. I'll have a play when I get a chance, and let you know of any findings if I have any luck (with my limited experience I wouldn't hold your breath though 😉
          Some official documentation would be very welcome.
          Jon
            On 17/11/2008 at 11:13, xxxxxxxx wrote:
            OK... with R11 I've managed to change the key frame values:
            main(doc,op)
            var obj = doc->FindObject("Cube");
            var track = obj->GetFirstCTrack();
            var myKey = track->GetCurve()->GetKey(0); // key 0 is first key frame
            myKey->SetValue(track->GetCurve(),70); // in this case, changes x pos to 70 m
            That's all good, but I can't figure out how to move the keyframe positions in the timeline. This doesn't work (an attempt to move the key frame to frame 10:
            myKey->SetTime(10,doc->GetFps());
            Does anyone know how to achieve this?
            Jon
              On 17/11/2008 at 11:32, xxxxxxxx wrote:
              In C++, it is: key->SetTime(CCurve, BaseTime);
              So, you might want to try it like this:
              var time = BaseTime();
              myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps()));
                On 17/11/2008 at 11:53, xxxxxxxx wrote:
                Hey Robert,
                thanks for the super quick reply!
                An error is thrown at BaseTime() ... 'CLASS is not a function'.
                I tried swapping with:
                var time = myKey->GetTime();
                ... but nothing happens.
                Any thoughts?
                  On 17/11/2008 at 12:58, xxxxxxxx wrote:
                  That's interesting considering there is a function in the BaseTime class BaseTime(). 🙂
                  You could try:
                  var time = doc->GetTime();
                  and go from there.
                    On 17/11/2008 at 15:25, xxxxxxxx wrote:
                    Thanks again, but no joy. I've tried all manner of nonsense, but I'm shooting in the dark.
                    Is this to be unknown until official documentation?
                      On 17/11/2008 at 15:56, xxxxxxxx wrote:
                      I think you must fill the BaseTime with a value.
                      var bt = new(BaseTime);
                      bt->SetData(/*the time you want*/);
                      You then use bt as your time to set a key (or anything else).
                      Lennart
                        On 18/11/2008 at 02:50, xxxxxxxx wrote:
                        Blimey what a palaver that was!
                        Thanks so much Robert and Lennart for helping to steer me in the right direction.
                        This seems to work:
                        > \> main(doc,op) \> { \> \> var obj = doc->FindObject("Cube"); \> var track = obj->GetFirstCTrack(); \> var myKey = track->GetCurve()->GetKey()); // key 0 is first key \> var time = new(BaseTime); \> time = doc->GetTime(); \> myKey->SetTime(track->GetCurve(), time->SetFrame(10,doc->GetFps())); // move key frame to frame 10 \> \> } \>
                          On 18/11/2008 at 04:38, xxxxxxxx wrote:
                          Apologies, major balls-up!
                          Above code doesn't work (aside from typo 'GetKey(0)') - don't know what's going on - I did get it to work, but not with above code. Aaah!
                            On 18/11/2008 at 05:14, xxxxxxxx wrote:
                            Phew! I'm able to wipe that ostrich egg off my face...
                            main(doc,op)
                            var myKey = track->GetCurve()->GetKey(0)); // key 0 is first key
                            time->SetFrame(10, doc->GetFps()); // move key frame to frame 10
                            myKey->SetTime(track->GetCurve(), time);
