    Adding object properties in .res-file
    14 Posts 0 Posters 1.4k Views
      On 05/06/2008 at 02:32, xxxxxxxx wrote:
      Cinema 4D Version:   10
      it's me again with a new problem! If I see that right in the samples it is possible to add object properties which can be changed by users, just by writing them into the *res - and *.str-files. So I did that, but when I start the plugin Cinema 4D shows me an error in the *res-file.
      Here is my *.res-file:
      > \> CONTAINER OBaum \> { \>      NAME OBaum; \>      INCLUDE Obase; \>       \>      GROUP ID_OBJECTPROPERTIES \>      { \>           BOOL ECHTZEIT { } \>      } \> } \> \>
      The error is located in line 8, which is the BOOL...-line I think.
      I also added ECHTZEIT to the *.str-files and the *.h-file.
      Any idea about that?
      Basti
        On 05/06/2008 at 02:56, xxxxxxxx wrote:
        Seems ok to me. Be aware that you need five ressource/header/string files for your plugin. They should look something like this
        c4d_symbols.h
        > \> enum \> { \>      // string table definitions \>      IDS_BAUM     = 10000, \> \> // End of symbol definition \> \_DUMMY_ELEMENT\_ \> }; \>
        c4d_strings.str
        > \> // C4D-StringResource \> // Identifier     Text \> \> STRINGTABLE \> { \>      IDS_BAUM     "Baum"; \> } \>
        obaum.res
        obaum.h
        > \> #ifndef \_OBaum_H\_ \> #define \_OBaum_H\_ \> \> enum \> { \>      ECHTZEIT = 1000 \> }; \> \> #endif \>
        obaum.str
        > \> STRINGTABLE OBaum \> { \>      OBaum          "Baum Objekt"; \> \>      ECHTZEIT     "Echtzeit"; \> } \>
        Maybe there is something wrong in your plugin registration code?
          On 05/06/2008 at 03:14, xxxxxxxx wrote:
          Ah, ok, I didn't know about c4d_strings.str and c4d_symbols.h. Thanks a lot!
            On 05/06/2008 at 03:29, xxxxxxxx wrote:
            Hm, still I got the error...
              On 05/06/2008 at 03:48, xxxxxxxx wrote:
              I would need some source code to help you further.
                On 05/06/2008 at 04:13, xxxxxxxx wrote:
                Oh, of course. Sorry.
                My *.res-file still is unchanged.
                Baum.h:
                obaum.str:
                > \> STRINGTABLE OBaum \> { \>      OBaum "Baum Objekt"; \>       \>      ECHTZEIT     "Echtzeitaktualisierung"; \> } \>
                c4d_strings.str:
                > \> STRINGTABLE \> { \>      IDS_BAUM     "Baum"; \>      IDS_SDK_VORLAGE               "SDK-Vorlage"; \>       \> } \>
                c4d_symbols.h:
                > \> enum \> { \> \>      IDS_SDK_VORLAGE, \>      IDS_BAUM     = 10000, \> \> }; \>
                  On 05/06/2008 at 04:59, xxxxxxxx wrote:
                  please make sure that header, ressource and string file have the same name, for example "obaum.h", "obaum.res" and "obaum.str".
                    On 05/06/2008 at 05:05, xxxxxxxx wrote:
                    Changed that, still the same error.
                    Maybe it helps to see my Init-Method:
                    > \> Bool Baum::Init(GeListNode \*node) \> { \>      BaseObject          \*op          = (BaseObject\* )node; \>      BaseContainer \*data = op->GetDataInstance(); \> \>      data->SetBool(ECHTZEIT,FALSE); \> \>      return TRUE; \> } \>
                      On 05/06/2008 at 05:24, xxxxxxxx wrote:
                      What does your register function look like? Something like this
                      > \> Bool RegisterAtomObject(void) \> { \>      // decide by name if the plugin shall be registered - just for user convenience \>      String name=GeLoadString(IDS_ATOM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_ATOMOBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,AtomObject::Alloc,"Oatom","atom.tif",0); \> } \>
                        On 05/06/2008 at 06:00, xxxxxxxx wrote:
                        There it is:
                        > \> Bool RegisterBaum(void) \> { \>      String name=GeLoadString(IDS_BAUM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_BAUMOBJECT,"Baum",OBJECT_GENERATOR,Baum::Alloc,"oBaum",NULL,0); \> } \>
                          On 05/06/2008 at 06:11, xxxxxxxx wrote:
                          Does the "oBaum" in the RegisterObjectPlugin() function exactly match with the file names? Usally it's best to avoid upper case completly.
                            On 05/06/2008 at 07:19, xxxxxxxx wrote:
                            Yes, that's the exact filename (without file type extension of course).
                              On 05/06/2008 at 08:09, xxxxxxxx wrote:
                              Could you send me the source code? You can send it to [email protected] , it will kept confidential of course.
                                On 06/06/2008 at 02:20, xxxxxxxx wrote:
                                Oh, thanks a lot for the offer, but I found the error! Stupid little me put the *.h-file into the wrong folder!
