    Adding object properties in .res-file
    14 Posts 0 Posters 1.2k Views
      On 05/06/2008 at 03:14, xxxxxxxx wrote:
      Ah, ok, I didn't know about c4d_strings.str and c4d_symbols.h. Thanks a lot!
        On 05/06/2008 at 03:29, xxxxxxxx wrote:
        Hm, still I got the error...
          On 05/06/2008 at 03:48, xxxxxxxx wrote:
          I would need some source code to help you further.
            On 05/06/2008 at 04:13, xxxxxxxx wrote:
            Oh, of course. Sorry.
            My *.res-file still is unchanged.
            Baum.h:
            > \> #ifndef \_OBaum_H\_ \> #define \_OBaum_H\_ \> \> enum \> { \>      ECHTZEIT = 1000 \> }; \> \> #endif \>
            obaum.str:
            > \> STRINGTABLE OBaum \> { \>      OBaum "Baum Objekt"; \>       \>      ECHTZEIT     "Echtzeitaktualisierung"; \> } \>
            c4d_strings.str:
            > \> STRINGTABLE \> { \>      IDS_BAUM     "Baum"; \>      IDS_SDK_VORLAGE               "SDK-Vorlage"; \>       \> } \>
            c4d_symbols.h:
            > \> enum \> { \> \>      IDS_SDK_VORLAGE, \>      IDS_BAUM     = 10000, \> \> }; \>
              On 05/06/2008 at 04:59, xxxxxxxx wrote:
              please make sure that header, ressource and string file have the same name, for example "obaum.h", "obaum.res" and "obaum.str".
                On 05/06/2008 at 05:05, xxxxxxxx wrote:
                Changed that, still the same error.
                Maybe it helps to see my Init-Method:
                > \> Bool Baum::Init(GeListNode \*node) \> { \>      BaseObject          \*op          = (BaseObject\* )node; \>      BaseContainer \*data = op->GetDataInstance(); \> \>      data->SetBool(ECHTZEIT,FALSE); \> \>      return TRUE; \> } \>
                  On 05/06/2008 at 05:24, xxxxxxxx wrote:
                  What does your register function look like? Something like this
                  > \> Bool RegisterAtomObject(void) \> { \>      // decide by name if the plugin shall be registered - just for user convenience \>      String name=GeLoadString(IDS_ATOM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_ATOMOBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,AtomObject::Alloc,"Oatom","atom.tif",0); \> } \>
                    On 05/06/2008 at 06:00, xxxxxxxx wrote:
                    There it is:
                    > \> Bool RegisterBaum(void) \> { \>      String name=GeLoadString(IDS_BAUM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_BAUMOBJECT,"Baum",OBJECT_GENERATOR,Baum::Alloc,"oBaum",NULL,0); \> } \>
                      On 05/06/2008 at 06:11, xxxxxxxx wrote:
                      Does the "oBaum" in the RegisterObjectPlugin() function exactly match with the file names? Usally it's best to avoid upper case completly.
                        On 05/06/2008 at 07:19, xxxxxxxx wrote:
                        Yes, that's the exact filename (without file type extension of course).
                          On 05/06/2008 at 08:09, xxxxxxxx wrote:
                          Could you send me the source code? You can send it to [email protected] , it will kept confidential of course.
                            On 06/06/2008 at 02:20, xxxxxxxx wrote:
                            Oh, thanks a lot for the offer, but I found the error! Stupid little me put the *.h-file into the wrong folder!
