    Adding object properties in .res-file
    14 Posts 0 Posters 1.4k Views
      On 05/06/2008 at 02:56, xxxxxxxx wrote:
      Seems ok to me. Be aware that you need five ressource/header/string files for your plugin. They should look something like this
      c4d_symbols.h
      > \> enum \> { \>      // string table definitions \>      IDS_BAUM     = 10000, \> \> // End of symbol definition \> \_DUMMY_ELEMENT\_ \> }; \>
      c4d_strings.str
      > \> // C4D-StringResource \> // Identifier     Text \> \> STRINGTABLE \> { \>      IDS_BAUM     "Baum"; \> } \>
      obaum.res
      > \> CONTAINER OBaum \> { \>      NAME OBaum; \>      INCLUDE Obase; \> \>      GROUP ID_OBJECTPROPERTIES \>      { \>           BOOL ECHTZEIT     { } \>      } \> } \>
      obaum.h
      > \> #ifndef \_OBaum_H\_ \> #define \_OBaum_H\_ \> \> enum \> { \>      ECHTZEIT = 1000 \> }; \> \> #endif \>
      obaum.str
      > \> STRINGTABLE OBaum \> { \>      OBaum          "Baum Objekt"; \> \>      ECHTZEIT     "Echtzeit"; \> } \>
      Maybe there is something wrong in your plugin registration code?
        On 05/06/2008 at 03:14, xxxxxxxx wrote:
        Ah, ok, I didn't know about c4d_strings.str and c4d_symbols.h. Thanks a lot!
          On 05/06/2008 at 03:29, xxxxxxxx wrote:
          Hm, still I got the error...
            On 05/06/2008 at 03:48, xxxxxxxx wrote:
            I would need some source code to help you further.
              On 05/06/2008 at 04:13, xxxxxxxx wrote:
              Oh, of course. Sorry.
              My *.res-file still is unchanged.
              Baum.h:
              obaum.str:
              > \> STRINGTABLE OBaum \> { \>      OBaum "Baum Objekt"; \>       \>      ECHTZEIT     "Echtzeitaktualisierung"; \> } \>
              c4d_strings.str:
              > \> STRINGTABLE \> { \>      IDS_BAUM     "Baum"; \>      IDS_SDK_VORLAGE               "SDK-Vorlage"; \>       \> } \>
              c4d_symbols.h:
              > \> enum \> { \> \>      IDS_SDK_VORLAGE, \>      IDS_BAUM     = 10000, \> \> }; \>
                On 05/06/2008 at 04:59, xxxxxxxx wrote:
                please make sure that header, ressource and string file have the same name, for example "obaum.h", "obaum.res" and "obaum.str".
                  On 05/06/2008 at 05:05, xxxxxxxx wrote:
                  Changed that, still the same error.
                  Maybe it helps to see my Init-Method:
                  > \> Bool Baum::Init(GeListNode \*node) \> { \>      BaseObject          \*op          = (BaseObject\* )node; \>      BaseContainer \*data = op->GetDataInstance(); \> \>      data->SetBool(ECHTZEIT,FALSE); \> \>      return TRUE; \> } \>
                    On 05/06/2008 at 05:24, xxxxxxxx wrote:
                    What does your register function look like? Something like this
                    > \> Bool RegisterAtomObject(void) \> { \>      // decide by name if the plugin shall be registered - just for user convenience \>      String name=GeLoadString(IDS_ATOM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_ATOMOBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,AtomObject::Alloc,"Oatom","atom.tif",0); \> } \>
                      On 05/06/2008 at 06:00, xxxxxxxx wrote:
                      There it is:
                      > \> Bool RegisterBaum(void) \> { \>      String name=GeLoadString(IDS_BAUM); if (!name.Content()) return TRUE; \>      return RegisterObjectPlugin(ID_BAUMOBJECT,"Baum",OBJECT_GENERATOR,Baum::Alloc,"oBaum",NULL,0); \> } \>
                        On 05/06/2008 at 06:11, xxxxxxxx wrote:
                        Does the "oBaum" in the RegisterObjectPlugin() function exactly match with the file names? Usally it's best to avoid upper case completly.
                          On 05/06/2008 at 07:19, xxxxxxxx wrote:
                          Yes, that's the exact filename (without file type extension of course).
                            On 05/06/2008 at 08:09, xxxxxxxx wrote:
                            Could you send me the source code? You can send it to [email protected] , it will kept confidential of course.
                              On 06/06/2008 at 02:20, xxxxxxxx wrote:
                              Oh, thanks a lot for the offer, but I found the error! Stupid little me put the *.h-file into the wrong folder!
