    • Unread
    Script Request: Multiple STL file Export
    General Talk
    • P
      Prowl
      So am looking for a script / plugin to
      1. Export Multiple selected resolved Hierarchy objects to STL files.
      2. Has to process Volume Builder and Mesher.
      3. export All files in one go to a selected folder.
      Select n go was my go-to for this
      https://fcstudios.gumroad.com/l/SelectNGo
      But it doesn't work properly post r21 ( I am stuck on elect n go v2 on r21 ) as it seems to ignore Volume Builder/Mesher - I've tried to speak with them but with no joy - I know they are very busy on other projects. and does a lot more than I need.
      This is specifically to export sculpted / Volume built models for 3d printing hence the STL file.
      Generally, I have 10-20 parts in a file like this and select the Topmost of each and export -
      Part1(Null)
      Volume Mesher
      Volume Builder
      object1
      object2
      object3
      Part2(Null)
      Volume Mesher
      Volume Builder
      object1
      object2
      object3
      What is the best way to go about this?
      Thanks in advance.
      • ferdinandF
        ferdinand @Prowl
        Hello @prowl,
        Welcome to the forum and thank you for reaching out to us.
        I am not sure how your posting is meant. Are you looking for a developer or are you looking for support for developing a solution yourself? If the latter is the case, then you are posting in the wrong sub-forum. When you are indeed looking for a developer, then you are in the right forum.
        If this is a task which you could solve on your own depends on the details of what you want to achieve, but the principal logic is not that hard to realize. Assuming that you want to implement your idea in Python:
        1. Use c4d.utils.SendModelingCommand and the command identifiers for Current State to Object and Connect and Delete to collapse some geometry as you would do it manually in Cinema 4D.
        2. Use c4d.documents.SaveDocument with c4d.FORMAT_STL_EXPORT to export the output of the modelling commands.
        As lined out in the forum guidelines, we cannot design applications for users. There can be things which complicate this simple task (like for example collecting dependencies in a scene). If you do not want to take the risk of being overwhelmed by your task, you should hire a developer. In general, I would say this is a manageable task for a beginner.
        The Maxon SDK Team will be happy to answer further questions when you decide to implement this yourself. But you must provide code and specific questions related to our APIs.
