    SetLife at n-collision for tp
    Scheduled Pinned Locked Moved PYTHON Development
    7 Posts 0 Posters 766 Views
    • H Offline
      Helper
      On 21/05/2012 at 09:53, xxxxxxxx wrote:
      Hello to all
      I have problem with understanding of how to catch/detect and kill at n-collision tp(id).
      scene(from my colleague) - link
      and code(at tag) :
          from c4d.modules import thinkingparticles as tp
          def main() :
              curframe = doc.GetTime().GetFrame(doc.GetFps())
              N = tp.NumParticles()
              ids = range(N)
              if curframe == 0 :
                  ids = range(N)
                  life = [c4d.BaseTime(0.0)]*N
                  map(tp.SetLife,ids,life)
              else :
                  ids = range(N)
                  for i in ids :
                      if tp.Alive(i) :
                          col = tp.SetCollision(i, 10)
                          print col
                          if col :
                              ids = range(N)
      • H Offline
        Helper
        On 22/05/2012 at 07:38, xxxxxxxx wrote:
        it does not documented in help, but seems works:
        tp.CheckCollision(0, i, curframe, tp.Position(i), tp.Velocity(i), tp.Spin(i)["axis"], tp.Spin(i)["speed"], dt, ct)
        how to catch dt and ct?
        up.
        dt = curframe - 1
        ct?
        • H Offline
          Helper
          On 22/05/2012 at 23:48, xxxxxxxx wrote:
          i guess dt stands for deltatime und ct for currenttime.
          • H Offline
            Helper
            On 23/05/2012 at 12:04, xxxxxxxx wrote:
            Thanks Ferdinand.
            So, that boolean function works for sequences with GetVirtualObjects(...) and gv-interface.
            • H Offline
              Helper
              On 24/05/2012 at 11:10, xxxxxxxx wrote:
              I downloaded new documentation of pyDocs, expecting explanation that function will be 😉
              Sebastian, please, will be it?
              • H Offline
                Helper
                On 25/05/2012 at 01:21, xxxxxxxx wrote:
                It's intended that TP_MasterSystem.CheckCollision() isn't documented. This function is private.
                • H Offline
                  Helper
                  On 25/05/2012 at 07:40, xxxxxxxx wrote:
                  Muchas gracies. Thank you.
                  Hope it will be more public. 😉
                  Also thanks for docs to Maxon's devs
