SetLife at n-collision for tp
On 21/05/2012 at 09:53, xxxxxxxx wrote:
Hello to all
I have problem with understanding of how to catch/detect and kill at n-collision tp(id).
scene(from my colleague) - link
and code(at tag) :import c4d from c4d.modules import thinkingparticles as tp def main() : curframe = doc.GetTime().GetFrame(doc.GetFps()) N = tp.NumParticles() ids = range(N) if curframe == 0 : ids = range(N) life = [c4d.BaseTime(0.0)]*N map(tp.SetLife,ids,life) else : ids = range(N) for i in ids : if tp.Alive(i) : col = tp.SetCollision(i, 10) print col if col : ids = range(N) life = [c4d.BaseTime(0.0)]*N map(tp.SetLife,ids,life)
On 22/05/2012 at 07:38, xxxxxxxx wrote:
it does not documented in help, but seems works:
tp.CheckCollision(0, i, curframe, tp.Position(i), tp.Velocity(i), tp.Spin(i)["axis"], tp.Spin(i)["speed"], dt, ct)
how to catch dt and ct?
up.
dt = curframe - 1ct?
On 22/05/2012 at 23:48, xxxxxxxx wrote:
i guess dt stands for deltatime und ct for currenttime.
On 23/05/2012 at 12:04, xxxxxxxx wrote:
Thanks Ferdinand.
So, that boolean function works for sequences with GetVirtualObjects(...) and gv-interface. -
On 24/05/2012 at 11:10, xxxxxxxx wrote:
I downloaded new documentation of pyDocs, expecting explanation that function will be
Sebastian, please, will be it? -
On 25/05/2012 at 01:21, xxxxxxxx wrote:
It's intended that TP_MasterSystem.CheckCollision() isn't documented. This function is private.
On 25/05/2012 at 07:40, xxxxxxxx wrote:
Muchas gracies. Thank you.
Hope it will be more public.Also thanks for docs to Maxon's devs
