    Set Texture by script
    14 Posts 0 Posters 3.0k Views
      On 26/10/2011 at 22:49, xxxxxxxx wrote:
      If I read this correctly then you create a new material first.
      Is there also a way to change the texture in an already exsisting material?
      Greets Ronnie
      Thanks, you understood my problem. The texture groups are existing. I have to assign the files to the existing texture groups.
        On 27/10/2011 at 06:32, xxxxxxxx wrote:
        Use
        doc.SearchMaterial(name)
        to find a material by name.
          On 28/10/2011 at 01:41, xxxxxxxx wrote:
          Thanks to all. I solved the problem. Here is my final script:
          from c4d import gui
          from c4d import storage
          import  os
          myMaterials       = doc.GetMaterials()
          fileExtension   = ".jpg"
            pathToTextures = c4d.storage.LoadDialog(0,"Texturpfad wählen",2)
            for mat in myMaterials:
                name        = mat.GetName()
                # arrange the new name by replacing
                # every `_group` with just nothing ``.
                textureName = name
                textureName = name.replace( "material_", "texture_" )
                # concetenate the path to textures with the name
                # of the texture
                # we use `os.path` because it adapts the operating
                # systems way to deal with pathnames
                fullPath    = os.path.join( pathToTextures, textureName )
                # we need the original texturename, so we add the
                # file extension now
                fullPath    = fullPath + fileExtension
                # check if the texture exists
                if not os.path.exists( fullPath ) :
                    # tell that the object could not be associated
                    # with a texture
                    print "Texture could not be found:", fullPath
                    # create a shader for the material
                    sha     = c4d.BaseList2D(c4d.Xbitmap)
                    sha[c4d.BITMAPSHADER_FILENAME]  = fullPath
                    mat.InsertShader( sha )
                    mat[c4d.MATERIAL_COLOR_SHADER]  = sha
                    # update the material
                    mat.Message( c4d.MSG_UPDATE )
                    mat.Update( True, True )
            # update the Cinema 4D UI
            # tell that the processing was finished
            print "Finished processing."
            gui.MessageDialog("Finished processing.")
          But there are two new questions.
          1. If I look into the documentation the function GetMaterials is in the namespace c4d.documents.BaseDocument. But if I use this namespace the command could not be found. Why and from where I can know the namespace doc? I got it from the script above.
          2. In the documentation for the command LoadDialog is written about constants like FILESELECT_DIRECTORY. But it isn't known by the interpreter. Where are they defined and what I have to import that it works?
            On 28/10/2011 at 02:43, xxxxxxxx wrote:
            1. c4d.documents.BaseDocument isn't a namespace, it's a class representing a C4D document. To get the current document as doc:
            from c4d import documents
            2. FILESELECT_DIRECTORY and all the constants are defined in the c4d namespace : for example c4d.FILESELECT_DIRECTORY.
              On 28/10/2011 at 04:46, xxxxxxxx wrote:
              As you see in my sourcecode I have never declared doc but it works. Is it declared implicit? I've found nothing in the documentation about it.
                Yes, everywhere in the code, 'doc' is the current document and 'op' is the current activate object. I'll add this to the docs.
                  On 28/10/2011 at 05:18, xxxxxxxx wrote:
                  You don't seem to understand that I have written the code above just for you, and not just because I'm so bored. I don't think many other people would have done this for you.
                  At least some sort of thank you in your second post would have been appropriate rather than to complain it is not exactly the way you need it.
                    I think you posted the code in the wrong topic...
                    The topic about finding a material by name is this one : https://developers.maxon.net/forum/topic/6087/6267_texture-change-python
                      As you can see I used the most of your script in my solution. The only difference is that I had already materials and would like to edit them and the dynamic selection of the texture path.
                      Many thanks for your script👏 Without it I wasn't able to solve the problem.
                      I'm sorry, if it seems that I'm not thankful to you.😊
                        Sorry, I didn't understand your previous post but the code you posted later was quite confusing Confused:
                        https://developers.maxon.net/forum/topic/6085/6265_set-texture-by-script
                          On 01/11/2011 at 23:41, xxxxxxxx wrote:
                          I'm sorry. My reply applies to the post from nux95.
