    Limiting user data entries
    3 Posts 0 Posters 694 Views
      On 24/06/2011 at 21:18, xxxxxxxx wrote:
      Hello fine Gents and ladies! 🙂I was hoping to find out If there is a way to dynamically limit the Maximum limit for a user data entry.
      for example....
      i have a user data value, a float.
      width     = op[c4d.ID_USERDATA,6]
      and another
      bevRadius  = op[c4d.ID_USERDATA,5]
      and i want to dynamically set the limit of the bevRadius based on the width. i have been able to get it to hapen within the code, but i was hoping there might be a way to just stop the value from exceeding a certain limit while the user is sliding the control.
      thanks for the help! ... again. 😕
        On 25/06/2011 at 03:53, xxxxxxxx wrote:
        Try this.
        import      c4d
        myUserDataId        = 1
        myNewMaxLimitValue  = 2
        myObject            = doc.GetFirstObject()
        allUserdatas        = myObject.GetUserDataContainer()
        for descId, container in allUserdatas:
          # get the UserData id from 'descId'
          id              = descId[1].id
          if id == myUserDataId:
              # the id for the maximum value is 6
              container[6]    = myNewMaxLimitValue
              myObject.SetUserDataContainer(descId, container)
          On 25/06/2011 at 15:44, xxxxxxxx wrote:
          perfection😄! thanks nux!
          EDIT: not only did you help me with this, but that simple loop through User data containers is awesome! thanks so much man!
