Limiting user data entries
On 24/06/2011 at 21:18, xxxxxxxx wrote:
Hello fine Gents and ladies!
I was hoping to find out If there is a way to dynamically limit the Maximum limit for a user data entry.for example....
i have a user data value, a float.
width = op[c4d.ID_USERDATA,6]
and another
bevRadius = op[c4d.ID_USERDATA,5]
and i want to dynamically set the limit of the bevRadius based on the width. i have been able to get it to hapen within the code, but i was hoping there might be a way to just stop the value from exceeding a certain limit while the user is sliding the control.
thanks for the help! ... again.
On 25/06/2011 at 03:53, xxxxxxxx wrote:
Try this.
import c4d myUserDataId = 1 myNewMaxLimitValue = 2 myObject = doc.GetFirstObject() allUserdatas = myObject.GetUserDataContainer() for descId, container in allUserdatas: # get the UserData id from 'descId' id = descId[1].id if id == myUserDataId: # the id for the maximum value is 6 container[6] = myNewMaxLimitValue myObject.SetUserDataContainer(descId, container)Cheers,
On 25/06/2011 at 15:44, xxxxxxxx wrote:
perfection
! thanks nux!EDIT: not only did you help me with this, but that simple loop through User data containers is awesome! thanks so much man!
