    SDK Compile (using CodeWarrior)
    10 Posts 0 Posters 1.1k Views
    • H Offline
      Helper
      On 24/08/2005 at 20:10, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      Platform:      Mac OSX  ;
      When I tried to open SDK workspace using CodeWarrior V9 under Mac OSX V10.4, I'm getting following error message and couldn't able to continue from here:
      "Error importing XML file 'cinema4dsdk.dsw' near line 6
      Found tag '4' where tag 'MWIDEWORKSPACE' was expected"
      And idea why it happens? Sorry, I'm a new swimmer under Mac Development.
      • H Offline
        Helper
        On 25/08/2005 at 01:08, xxxxxxxx wrote:
        .DSW is for VC on Windows, you want to use the .prj file.
        • H Offline
          Helper
          On 25/08/2005 at 01:39, xxxxxxxx wrote:
          I couldn't able to open cinema4dsdk.prj which is disabled when I went thro' File->Open Workspace. That's the reason why I tried to open .dsw file. But I dont know why .prj is disabled.
          • H Offline
            Helper
            On 25/08/2005 at 16:55, xxxxxxxx wrote:
            What targets does your CodeWarrior have? You need MacOS Classic target to create Cinema 4D plugins for MacOS.
            • H Offline
              Helper
              On 25/08/2005 at 19:31, xxxxxxxx wrote:
              When I check under "Target Settings Panels" in CodeWarrior, the "Linker" got following items:
              None
              MacOS Merger
              Macintosh PowerPC
              Mac OS X PowerPC Mach-O
              Is that what you are referring to? If so, I don't see MacOS Classic over here. Please advice me what should I do to proceed further.
              • H Offline
                Helper
                On 25/08/2005 at 19:36, xxxxxxxx wrote:
                Just checked this out on my Mac. Don't use 'Open Workspace' as the .prj file is not a workspace - it's a project. Use 'Open...' instead.
                Added: Looks like you have the Classic target (MacOS PowerPC).
                HTH,
                • H Offline
                  Helper
                  On 25/08/2005 at 20:59, xxxxxxxx wrote:
                  Thanks.
                  • H Offline
                    Helper
                    On 28/08/2005 at 19:41, xxxxxxxx wrote:
                    After I open C4D SDK prj file, I tried to build it which throws out a huge list of errors and warnings. I just wanna check with you, before I compile the SDK in CodeWarrior am I supposed to do any settings? If so, can any one tell me how should I compile SDK using CW in Mac platform? Is there any tutorial available? I found few for VC++ but not for CW 😞
                    • H Offline
                      Helper
                      On 28/08/2005 at 21:22, xxxxxxxx wrote:
                      Most of these should be 'void delete' and 'void delete[]' errors. You'll need to fix "c4d_memory.cpp" in your MacOS C4D SDK as follows:
                      void operator delete(void *p)
                           if (p)
                                void *temp=p;
                                C4DOS.Ge->Free(temp);
                      void operator delete[](void *p)
                           if (p)
                                void *temp=p;
                      To:
                      void operator delete(void *p) throw()
                           if (p)
                                void *temp=p;
                      void operator delete[](void *p) throw()
                           if (p)
                                void *temp=p;
                      And these in "c4d_memory.h"
                      void operator delete(void *p);
                      void operator delete[](void *p);
                      To:
                      void operator delete(void *p) throw();
                      void operator delete[](void *p) throw();
                      • H Offline
                        Helper
                        On 28/08/2005 at 22:36, xxxxxxxx wrote:
                        Yes, exactly thats what I'm facing.
                        Thanks Robert, I'll try to change and build again.
