    Sample & Absolute Paths?
    3 Posts 0 Posters 632 Views
    • H Offline
      Helper
      On 08/07/2005 at 09:07, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      Platform:
      Hello all, here is my problem:
      I am sampling the channel of a material. It's working perfectly except when the channel has an image file specified (with a relative path) and that image file is in the document path.
      So for example, if I have an scene here: "c: est\untitled 1.c4d" and an image here: "c: est\image1.jpg", if I load "image1.jpg" into the color channel of a material with a relative path "image1.jpg" it will not work.
      If I manualy specify an absolute path "c: est\image1.jpg" it works fine.
      Here's my code:
      InitRenderStruct irs;
      irs.version = GetC4DVersion();
      irs.fps = cdoc->GetFps();
      irs.time = cdoc->GetTime();
      irs.doc = cdoc;
      irs.docpath = const_cast<Filename*>(&cdoc-;>GetDocumentPath());
      irs.flags = INITRENDERFLAG_TEXTURES;
      if (basechan->InitTexture(&irs;) == LOAD_OK) {
           sample = basechan->Sample(NULL, &uvw;, &dlt;, &nn;, sec, 0, 0.0, 0.0);
      InitTexture is returning LOAD_OK
      Any ideas?
      -Chris
      • H Offline
        Helper
        On 10/07/2005 at 01:37, xxxxxxxx wrote:
        I'm surprised the compiler doesn't complain about "irs.docpath = const_cast<Filename*>(&cdoc->GetDocumentPath());", since it looks very dubious to me. You're getting the address to a temporary Filename object, which will be destructed before the next line, if I get the language rules right.
        Try changing this line to:
            Filename docpath = cdoc->GetDocumentPath();
            irs.docpath = &docpath;
        • H Offline
          Helper
          On 10/07/2005 at 04:41, xxxxxxxx wrote:
          Thanks Mikael, that worked great. And VC6 did not complain about it one bit.
          > Quote: __
          > I'm surprised the compiler doesn't complain about "irs.docpath = const_cast<Filename*>(&cdoc-;>GetDocumentPath());", since it looks very dubious to me.
          I actually got that straight from one of your posts. 😃
          Examples of GetBitmap
          Thanks again,
          -Chris
