Sample & Absolute Paths?
On 08/07/2005 at 09:07, xxxxxxxx wrote:
Cinema 4D Version: 8.503
Language(s) : C++ ;---------
Hello all, here is my problem:I am sampling the channel of a material. It's working perfectly except when the channel has an image file specified (with a relative path) and that image file is in the document path.
So for example, if I have an scene here: "c: est\untitled 1.c4d" and an image here: "c: est\image1.jpg", if I load "image1.jpg" into the color channel of a material with a relative path "image1.jpg" it will not work.
If I manualy specify an absolute path "c: est\image1.jpg" it works fine.Here's my code:
InitRenderStruct irs; irs.version = GetC4DVersion(); irs.fps = cdoc->GetFps(); irs.time = cdoc->GetTime(); irs.doc = cdoc; irs.docpath = const_cast<Filename*>(&cdoc-;>GetDocumentPath()); irs.flags = INITRENDERFLAG_TEXTURES; if (basechan->InitTexture(&irs;) == LOAD_OK) { ... sample = basechan->Sample(NULL, &uvw;, &dlt;, &nn;, sec, 0, 0.0, 0.0); }
InitTexture is returning LOAD_OK
Any ideas?
-Chris
On 10/07/2005 at 01:37, xxxxxxxx wrote:
I'm surprised the compiler doesn't complain about "irs.docpath = const_cast<Filename*>(&cdoc->GetDocumentPath());", since it looks very dubious to me. You're getting the address to a temporary Filename object, which will be destructed before the next line, if I get the language rules right.
Try changing this line to:Filename docpath = cdoc->GetDocumentPath(); irs.docpath = &docpath;
On 10/07/2005 at 04:41, xxxxxxxx wrote:
Thanks Mikael, that worked great. And VC6 did not complain about it one bit.
> Quote: __
> I'm surprised the compiler doesn't complain about "irs.docpath = const_cast<Filename*>(&cdoc-;>GetDocumentPath());", since it looks very dubious to me.
> * * *I actually got that straight from one of your posts.
Examples of GetBitmapThanks again,
-Chris
