    Set VERTEXCOLOR in PaintTool
    pythonr25windows
    3 Posts 2 Posters 773 Views 1 Watching
    • R Offline
      randymills
      I'm working on a python script that will assign vertex color tags with random colors to each mesh in my object to prep my models for working in Substance Painter. I have a sample script that is getting me close to what I need, but I can't for the life of me figure out what I'm doing wrong with the c4d.DescID(c4d.DescLevel) setup. I continue to get the following error, which suggests the DescLevel is reading c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DTYPE_VECTOR as an integer, even though I'm defining it as a vector (unless I'm misinterpreting this):
      Traceback (most recent call last):
        File "scriptmanager", line 43, in <module>
        File "scriptmanager", line 22, in main
      TypeError: 'c4d.Vector' object cannot be interpreted as an integer
      Current code sample (simplified but w/ test code included to show what I've tried already):
          if op is None:
              raise RuntimeError("No object selected")
          c4d.CallCommand(431000045) # Create Vertex Color Tag
          doc.SetAction(1021286)  #Makes the paint tool active
          tool = doc.GetAction()
          tool = c4d.plugins.FindPlugin(tool, c4d.PLUGINTYPE_TOOL)
          if not tool:
              print("Vertex Paint tool not found!")
              return False
          # Set the vertex color parameter
          myVertexColor = c4d.Vector(0.0,1.0,0.0) # Green
          # myVertexColor = c4d.DescLevel(c4d.Vector(0.0,1.0,0.0)) # Green
          desc_level = c4d.DescLevel(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DTYPE_VECTOR, 0)
          # Debug: Verify the DescID
          print(f"DescID: {desc_level}")
          vertexColorSuccess = tool.SetParameter(desc_level, myVertexColor)
          if not vertexColorSuccess:
              print("Failed to set vertex color parameter!")
              return False
          # Debug: Verify the parameter was set
          current_value = tool.GetParameter(desc_level, c4d.DESCFLAGS_GET_0)
          print(f"Set color: {current_value}")
          # tool[c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR]=myVertexColor
          # myVertexColorTag = c4d.DescID(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DTYPE_VECTOR, 0)
          # tool.SetParameter(myVertexColorTag, myVertexColor, c4d.DESCFLAGS_SET_0)
          c4d.CallButton(tool, c4d.ID_CA_PAINT_TOOL_APPLY_ALL) # Applies the color to all vertices
      Am I thinking about this all wrong...should I be accessing/setting the vertex color a different way?
      • M Offline
        m_adam
        Hey @randymills Python provide helper to directly call SetParameter on the correct parameter just with the integer value.
        With that's said internally we construct a DescID which is constructed from one or multiples DescLevel. SetParameter usually only deal DescID, since only DescID are able to identify a given parameter.
        With that's said here is you code working as expected demonstrating you both way.
            if op is None:
            if not tool:
                return False
            # Use SetParameter directly
            if True:
                vertexColorSuccess = tool.SetParameter(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, myVertexColor, c4d.DESCFLAGS_SET_NONE)
                    return False
                current_value = tool.GetParameter(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DESCFLAGS_GET_NONE)
            # Use DescID and DescLevel
            if True:
                myVertexColor = c4d.Vector(1.0,0.0,0.0) # Red
                descLevel = c4d.DescID(c4d.DescLevel(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DTYPE_VECTOR, 0))
                vertexColorSuccess = tool.SetParameter(descLevel, myVertexColor, c4d.DESCFLAGS_SET_NONE)
                    return False
                current_value = tool.GetParameter(descLevel, c4d.DESCFLAGS_GET_NONE)
                desc_level = c4d.DescID(c4d.DescLevel(c4d.ID_CA_PAINT_TOOL_VERTEXCOLOR, c4d.DTYPE_VECTOR, 0))
        • R Offline
          randymills
          @m_adam Thank you so much for the help, that works perfectly and thank you for showing me both methods, that's very helpful and appreciated!
