    save/keep cache of generator plugin
    2025pythonwindows
    5 Posts 3 Posters 1.2k Views 2 Watching
    • D Offline
      datamilch
      hi there,
      i've built a python generator, where i use its cache unless some parameters are dirty. when close and reopen the scene, the cache is gone and has to be rebuild. in principal, is there (not too complicated) way to keep/save these caches inside the scene?
      would this be possible with a python generator or a proper plugin?
      i'm using python.
      to be a bit more specific: by clicking a checkbox on the python generator, i do a cloth simulation in a temp doc. the result of the sim is convertet to polygons and returned by the python generator. the simulation is not super heavy, but it woud be nice if i could avoid the recalculation. so i'd like to store the point data in the scene/generator. i'd like to avoid external files too, if possible.
      my code is a bit long at the moment, i would post a shorter version, if you say it should be possible ...
      best, sebastian
      • P Offline
        pyr
        I would also be interested.
        I cache all kinds of things, but not the mesh at the end.
        #         check if any dependency changed
            def CacheCheck(self, op, doc):
                :param op:
                :param doc:
                :return:
                if op[res.GRIDDER_CACHE] is not None:
                    preOption = op[res.GRIDDER_CACHE].GetString(1001)
                    preNoise = op[res.GRIDDER_CACHE].GetFloat(1002)
                    preField = op[res.GRIDDER_CACHE].GetFloat(1003)
                    preFrame = op[res.GRIDDER_CACHE].GetFloat(1004)
                    rd = doc.GetActiveRenderData()
                    self.rs.SetStartFrame(rd[c4d.RDATA_FRAMEFROM].GetFrame(doc.GetFps()))
                    force = op[res.GRIDDER_EVERYFRAME]
                    frame = doc.GetTime().GetFrame(doc.GetFps())
                    noise, shaderAnimated = self.CacheShader(op, doc)
                    if force is 1 and preFrame != frame:
                        return False
                    if preOption != self.HelperGetOptions(op):
                        return False
                    if preNoise != noise:
                        return False
                    field = self.CacheField(op, doc)
                    if preField != field:
                        return False
                return False
        # after everything is calculated:
                bc = c4d.BaseContainer()
                bc.SetData(1001, self.HelperGetOptions(op))
                bc.SetData(1002, self.CacheShader(op, doc)[0])
                bc.SetData(1003, self.CacheField(op, doc))
                if doc != None:
                    bc.SetData(1004, frame)
                op[res.GRIDDER_CACHE] = bc
        • i_mazlovI Offline
          i_mazlov
          Hi Sebastian,
          FYI I'll get to answer your posting beginning next week.
          Ilia
          • i_mazlovI Offline
            i_mazlov @i_mazlov
            Hi Sebastian,
            Sorry for the delay.
            I'm afraid you're quite limited with the python generator, when it comes to storing your data, so the general suggestion would be switching to using the plugin. This way you could just override the NodeData.Read, NodeData.Write and NodeData.CopyTo to store and load your data using the HyperFile. For the more information on the NodeData.Read/Write function you could check the C++ manual.
            Let me know you have any other questions!
            Ilia
            • P Offline
              pyr
              Could you provide an snipped where you show how to cache it in a plugin?
