    Storage issues with plugin settings
    2023pythonwindows
    3 Posts 2 Posters 814 Views 1 Watching
    • N Offline
      Neekoe
      Hello everyone, I have encountered a problem. When I select a folder through the button, it will update the. c4d type files in the folder to TREELIST, including the path in an EDITNEXT that I set. However, after I restart the plugin or C4D, these contents are missing. Do you have any methods or documentation to refer to? be deeply grateful
      • DunhouD Offline
        Dunhou
        Hi @Neekoe ,
        There are many ways to save data, like c4d.storage.HyperFile or json-like stuff, or you can use WorldContainer, I like to use json for my plugins, but for more "c4d-like", you can use WorldContainer.
        Cheers~
        DunHou
        YOUR_UID: int = 123456789
        # Setting id, better to use a unique id, but not necessary
        SETTING1: int = 1000
        SETTING2: int = 1001
            # Create a new BaseContainer for storing the plugin data
            bcWorld: c4d.BaseContainer = c4d.GetWorldContainerInstance()
            bcPlug: c4d.BaseContainer = c4d.BaseContainer()
            bcPlug.SetBool(SETTING1, True)
            bcPlug.SetInt32(SETTING2, 10)
            bcWorld.SetContainer(YOUR_UID, bcPlug)
            # Get the BaseContainer from the world container
            bcPlug: c4d.BaseContainer = bcWorld.GetContainerInstance(YOUR_UID)
            print(bcPlug.GetBool(SETTING1))
            print(bcPlug[SETTING2])
        if __name__=='__main__':
        https://boghma.com
        https://github.com/DunHouGo
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          Neekoe @Dunhou
          Thank you for @Dunhou answer. It was ultimately completed in JSON format
