    GraphModelInterface.GetNode not worked
    pythonwindows2025
    3 Posts 2 Posters 949 Views 2 Watching
    • DunhouD Offline
      Dunhou
      Hi community,
      I notice GraphModelInterface.GetNode method seems broken in R2025.0.2, and also the ToString() seems broken too. Is my usage incorrect?
      Cheers~
      DunHou
      btw: R2025 tag is missing in forum
      import maxon
      import typing
      doc: c4d.documents.BaseDocument # The active document.
          for material in doc.GetMaterials():
              nodeMaterial: c4d.NodeMaterial = material.GetNodeMaterialReference()
              if not nodeMaterial.HasSpace("com.redshift3d.redshift4c4d.class.nodespace"):
                  continue
              graph: maxon.GraphModelRef = nodeMaterial.GetGraph("com.redshift3d.redshift4c4d.class.nodespace")
              root: maxon.GraphNode = graph.GetViewRoot()
              spaceContext = root.GetValue(maxon.nodes.NODESPACE.NodeSpaceContext)
              nodeSpaceId = spaceContext.Get(maxon.nodes.NODESPACE.SPACEID)
              spaceData = maxon.NodeSpaceHelpersInterface.GetNodeSpaceData(nodeSpaceId)
              assetId = spaceData.Get(maxon.nodes.NODESPACE.IMAGENODEASSETID)
              inTexturePortId = spaceData.Get(maxon.nodes.NODESPACE.IMAGENODEPORTS)[1]
              for node in root.GetInnerNodes(maxon.NODE_KIND.NODE, False):
                  assetId: maxon.Id = node.GetValue("net.maxon.node.attribute.assetid")[0]
                  if assetId != maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler"):
                      continue
                  pathPort: maxon.GraphNode = graph.GetNode(node.GetPath() + '>' + str(inTexturePortId))
                  url: str | None = pathPort.GetPortValue()
                  print (f"{pathPort}: {url}")
      https://boghma.com
      https://github.com/DunHouGo
      • M Offline
        m_adam
        Hi thanks for contacting us, since you are calling node.GetPath() then use the + operator. This will use the + operator from the NodePath which add \ at the beginning so its not a bug but the expected behavior since it add a new folder.
        In your case if you really want to build the string then you need to first build a string and then construct a NodePath from this string like so:
        pathPort: maxon.GraphNode = graph.GetNode(maxon.NodePath(str(node.GetPath()) + '<' + str(inTexturePortId)))
        DunhouD 1 Reply Last reply Reply Quote 0
        • DunhouD Offline
          Dunhou @m_adam
          Hi @m_adam ,
          Thanks for your reply, it worked well.
          But I still have some doubts about the usage of Node Path, such as how to calculate the port through NodePath instead of concatenating strings (which can easily lead to misoperation).
          There are few examples and answers for NodePath on the forum, and it seems that people rarely use it. Do you have any insights on this, or in other words, what usage scenarios do you think NodePath is more suitable for.
          Cheers~
          DunHou
          https://boghma.com
