    Realtime Slider Update
    3 Posts 2 Posters 479 Views
    • S Offline
      shurkan
      Dear community,
      I'm trying to scale a cube with a Slider in realtime. But I don't get it.
      The cube is only scaled after the mouse is released and not in realtime.
      class SliderDialog(c4d.gui.GeDialog):
          def __init__(self):
              super().__init__()
              self.slider_id = 1001
              self.last_value = None
          def CreateLayout(self):
              self.SetTitle("Slider")
              self.AddEditSlider(self.slider_id, c4d.BFH_SCALEFIT, initw=200)
              self.SetFloat(self.slider_id, 0.0, min=0.0, max=1.0, step=0.01)
          def Command(self, id, msg):
              if id == self.slider_id:
                  value = self.GetFloat(self.slider_id)
                  print(f"Real-time slider value: {value}")
                  self.UpdateScene(value)
          def Message(self, msg, result):
              if msg.GetId() == c4d.BFM_ACTION_INDRAG:
                  if value != self.last_value:
                      self.last_value = value
                      print(f"Dragging slider value: {value}")
              return super().Message(msg, result)
          def UpdateScene(self, value):
              obj = doc.SearchObject("Cube")
              if obj:
                  obj[c4d.ID_BASEOBJECT_REL_SCALE, c4d.VECTOR_X] = value
          if not obj:
              obj = c4d.BaseObject(c4d.Ocube)
              doc.InsertObject(obj)
          dlg = SliderDialog()
          dlg.Open(c4d.DLG_TYPE_ASYNC)
      Thank you in advance for your assistance.
      S 1 Reply Last reply Reply Quote 0
      • S Offline
        shurkan @shurkan
        SOLVED!
        I got it, instead of using c4d.EventAdd(),
        what I was searching for is c4d.DrawViews().
        Now the Slider works interactive. 🙂
            def __init__(self):
                super().__init__()
                if obj:
                    #c4d.EventAdd()
                    c4d.DrawViews() # That's it
            if not obj:
        • i_mazlovI Offline
          i_mazlov @shurkan
          Hi @shurkan,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          Great that you've managed to find the solution yourself! Thank you in advance for sharing it with the community!
          Just a short note about your solution is to be careful with threading, namely, in your case it's expected to execute DrawViewes in the following way:
          c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW | c4d.DRAWFLAGS_NO_THREAD | c4d.DRAWFLAGS_STATICBREAK)
          Something similar to this topic here: Troubleshooting Safe Frame Calculations Across Different Takes in Cinema 4D
          Ilia
