    Python - How to insert knots in c4d.Gradient
    3 Posts 2 Posters 839 Views
    • V Offline
      Vladislav Borovikov
      Hello everyone!
      I'm trying to add knots to the c4d.Gradient object, in GvNode. But the changes are not applied to the parameter, maybe I missed something, and this parameter needs to be updated?
      import redshift
      knots = [
          (c4d.Vector(1,0,1), 0.25, 0.25, 0.25),
          (c4d.Vector(0,1,1), 0.5, 0.5, 0.5),
          (c4d.Vector(1,1,0), 0.75, 0.75, 0.75),
          rs_material = doc.GetActiveMaterial()
          if not rs_material.GetTypeName() == "RS Shader Graph":
              print(rs_material.GetTypeName())
          # Get node master and root
          nm = redshift.GetRSMaterialNodeMaster(rs_material)
          root = nm.GetRoot()
          # Create RSRamp gvNode
          ramp_node = nm.CreateNode(root, 1036227)
          ramp_node[c4d.GV_REDSHIFT_SHADER_META_CLASSNAME] = 'RSRamp'
          # Get Gradient
          gradient = ramp_node[c4d.REDSHIFT_SHADER_RSRAMP_RAMP]
          gradient.FlushKnots()
          for i, knot in enumerate(knots):
              gradient.InsertKnot(knot[0], knot[1], knot[2], knot[3], i )
          #  Check values
          for i in range(gradient.GetKnotCount()):
              knot = gradient.GetKnot(i)
              col = knot.get("col")
              pos = knot.get("pos")
              br = knot.get('brightness')
              print(f"col = {col}, pos = {pos}, brightness = {br} ")
      • i_mazlovI Offline
        i_mazlov @Vladislav Borovikov
        Hi @Vladislav-Borovikov,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Custom datatypes implement copy constructor, which effectively means that at the line
        you copy c4d.Gradient from the node and store it in variable 'gradient'. All further interactions are performed with this local copy of the gradient. In order to apply them back to the node you need to assign your local variable after modifications back to the node:
        ramp_node[c4d.REDSHIFT_SHADER_RSRAMP_RAMP] = gradient
        Ilia
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          Vladislav Borovikov @i_mazlov
          Thank you very much, @i_mazlov! This is what I needed!
