    RenderDocument/PythonCallBack : how to display progress prints during the render
    pythons26windows
    4 Posts 2 Posters 1.8k Views 1 Watching
    • B Offline
      bioquet
      hello,
      when I run from script manager the maxon script below to launch a render and display the progress in the console, all the prints of line 44 in "def PythonCallBack"
      print("ProgressHook called [{0} / p: {1}]".format(text, progress * 100.0))
      are not displayed as the render progresses but all at once at the end of the render.
      What should I do to see these prints during the render ?
      Thanks in advance
      Here is the link to the script :
      https://developers.maxon.net/docs/py/26_107/modules/c4d.documents/index.html?highlight=renderdocument#c4d.documents.RenderDocument"
      And the maxon script :
      Copyright: MAXON Computer GmbH
      Author: Maxime Adam
      Description:
          - Render the current document with a progress hook to get notified about the current rendering progress.
      Class/method highlighted:
          - c4d.bitmaps.MultipassBitmap
          - c4d.documents.RenderDocument()
      def PythonCallBack(progress, progress_type):
          """Function passed in RenderDocument. It will be called automatically by Cinema 4D with the current render progress.
          Args:
              progress (float): The percent of the progress for the current step
              progress_type (c4d.RENDERPROGRESSTYPE): The Main part of the current rendering step
          text = str()
          if progress_type == c4d.RENDERPROGRESSTYPE_BEFORERENDERING:
              text = "Before Rendering"
          elif progress_type == c4d.RENDERPROGRESSTYPE_DURINGRENDERING:
              text = "During Rendering"
          elif progress_type == c4d.RENDERPROGRESSTYPE_AFTERRENDERING:
              text = "After Rendering"
          elif progress_type == c4d.RENDERPROGRESSTYPE_GLOBALILLUMINATION:
              text = "GI"
          elif progress_type == c4d.RENDERPROGRESSTYPE_QUICK_PREVIEW:
              text = "Quick Preview"
          elif progress_type == c4d.RENDERPROGRESSTYPE_AMBIENTOCCLUSION:
              text = "AO"
          # Prints to the console the current progress
      def PythonWriteCallBack(mode, bmp, fn, mainImage, frame, renderTime, streamnum, streamname):
          It will be called automatically by Cinema 4D when the file rendered file should be saved.
          Args:
              mode (c4d.WRITEMODE): The write mode.
              bmp (c4d.bitmaps.BaseBitmap): The bitmap written to.
              fn (str): The path where the file should be saved.
              mainImage (bool): True for main image, otherwise False.
              frame (int): The frame number.
              renderTime (int): The bitmap frame time.
              streamnum (int): The stream number.
              streamname (streamname: str): The stream name.
          text = str()
          if mode == c4d.WRITEMODE_STANDARD:
              text = "Standard"
          elif mode == c4d.WRITEMODE_ASSEMBLE_MOVIE:
              text = "Assemble Movie"
          elif mode == c4d.WRITEMODE_ASSEMBLE_SINGLEIMAGE:
              text = "Assemble single image"
          print("ProgressWriteHook called [{0} / p: {1}]".format(text, renderTime))
          # Retrieves the current active render settings
          rd = doc.GetActiveRenderData()
          # Creates a Multi Pass Bitmaps that will store the render result
          bmp = c4d.bitmaps.MultipassBitmap(int(rd[c4d.RDATA_XRES]), int(rd[c4d.RDATA_YRES]), c4d.COLORMODE_RGB)
          if bmp is None:
              raise RuntimeError("Failed to create the bitmap.")
          # Adds an alpha channel
          bmp.AddChannel(True, True)
          # Renders the document
          if c4d.documents.RenderDocument(doc, rd.GetData(), bmp, c4d.RENDERFLAGS_EXTERNAL, prog=PythonCallBack,
                                          wprog=PythonWriteCallBack) != c4d.RENDERRESULT_OK:
              raise RuntimeError("Failed to render the temporary document.")
          # Displays the render in the Picture Viewer
          c4d.bitmaps.ShowBitmap(bmp)
        ferdinand @bioquet
        Hello @bioquet,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        The problem with what you are trying to do, is that there are multiple things which are blocking in this context. See my code example below for details.
        Result
        Code
        """Demonstrates how to render a document with RenderDocument while showing the progress in the UI.
        Okay, to do what you want to do, we have to overcome two hurdles:
        * Script Manager scripts are blocking. I.e., nothing can happen in the UI while the script is
          running. We can sidestep this with an asynchronous dialog but PLEASE DO NOT DO THIS IN PRODUCTION
          CODE as this results in a dangling dialog. Use a CommandData plugin instead.
        * The RenderDocument function is blocking. We can overcome this by running the rendering in a
          separate thread. The rendering already runs in a separate thread but we push here the render handling
          into a separate thread.
        import mxutils
        doc: c4d.documents.BaseDocument # The active document.
        class HandleRenderThread(c4d.threading.C4DThread):
            """Handles a #RenderDocument call in a separate thread.
            We need this to make the #RenderDocument call non-blocking.
            MAP_RENDER_PROGRESS_TYPE: dict[int, str] = {
                c4d.RENDERPROGRESSTYPE_BEFORERENDERING: "Before Rendering",
                c4d.RENDERPROGRESSTYPE_DURINGRENDERING: "During Rendering",
                c4d.RENDERPROGRESSTYPE_AFTERRENDERING: "After Rendering",
                c4d.RENDERPROGRESSTYPE_GLOBALILLUMINATION: "GI",
                c4d.RENDERPROGRESSTYPE_QUICK_PREVIEW: "Quick Preview",
                c4d.RENDERPROGRESSTYPE_AMBIENTOCCLUSION: "AO"
            def __init__(self, doc: c4d.documents.BaseDocument) -> None:
                """Initializes a new instance with the document to render.
                # The document to render, the result, and a semaphore like string to signal the progress.
                self._doc: c4d.documents.BaseDocument = mxutils.CheckType(doc, c4d.documents.BaseDocument)
                self._res: c4d.bitmaps.BaseBitmap | Exception | None = None
                self._msg: str = ""
            def Message(self, progress: float, progress_type: int) -> None:
                """Called when the rendering progress changes.
                Writes to the _msg attribute to signal the progress to the main thread.
                self._msg = f"Progress: {progress * 100:.2f}% " \
                            f"({self.MAP_RENDER_PROGRESS_TYPE.get(progress_type, 'Unknown')})"
            def Main(self) -> None:
                """Called when the thread is started.
                # Get the render data, create a multipass bitmap, add an alpha channel, and
                # render the document.
                doc: c4d.documents.BaseDocument = self._doc
                rData: c4d.documents.RenderData = doc.GetActiveRenderData()
                bmp: c4d.bitmaps.BaseBitmap = mxutils.CheckType(
                        int(rData[c4d.RDATA_XRES]),
                        int(rData[c4d.RDATA_YRES]),
                        c4d.COLORMODE_RGB
                res: int = c4d.documents.RenderDocument(
                    doc, rData.GetDataInstance(), bmp, c4d.RENDERFLAGS_EXTERNAL, prog=self.Message)
                self._res = (bmp
                             if res == c4d.RENDERRESULT_OK else
                             RuntimeError("Failed to render the document."))
        class RenderDialog(c4d.gui.GeDialog):
            """Realizes a dialog with a button to start a rendering.
            We need this to make the script manager script non-blocking. Or more precisely, to escape
            the execution context of the script manager script (which is also why this is a bad idea for
            production code).
            ID_BTN_RENDER: int = 1000
            def CreateLayout(self) -> bool:
                """Called to let the dialog populate its UI with gadgets.
                self.SetTitle("Render Dialog")
                self.AddButton(self.ID_BTN_RENDER, c4d.BFH_CENTER, name="Render")
            def Command(self, cid: int, msg: c4d.BaseContainer) -> bool:
                """Called when the user presses a gadget.
                # The user pressed the render button. We start the rendering in a separate
                # thread. And then keep updating the UI and status bar with the progress.
                if cid == self.ID_BTN_RENDER:
                    thread: HandleRenderThread = HandleRenderThread(doc)
                    thread.Start()
                    # We must print to the status bar, as the console will not update until the
                    # rendering is done.
                    while thread.IsRunning():
                        c4d.StatusSetText(thread._msg)
                    c4d.StatusClear()
                    thread.End()
                    if isinstance(thread._res, Exception):
                        raise thread._res
                    bmp: c4d.bitmaps.BaseBitmap = thread._res
            # We open a dialog to start the rendering. This is a dangling dialog because it is asynchronous.
            # This means it will persist beyond the lifetime of the script manager script module. Which is
            # why you should not do this in production code.
            dlg: RenderDialog = RenderDialog()
            dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=200, defaulth=100)
        • B Offline
          bioquet
          Thank you very much for your quick reply.
          It works perfectly now.
          I just removed the "mxutils" which was not compatible with my s26 version
            Oh,
            my bad, I did overlook that you flagged this as S26. Yes, mxutils is a 2024+ feature. I used it here to carry out type checks, e.g., that a document or bitmap are not null/none. The code will run without them, but it will fail more gracefully with these checks.
            You could replace these calls with manual checks:
            bmp: c4d.bitmaps.BaseBitmap = c4d.bitmaps.MultipassBitmap(
                c4d.COLORMODE_RGB))
            if bmp is None: # or more precise: if not isinstance(bmp, c4d.bitmaps.BaseBitmap) ...
                raise MemoryError("Failed to allocate bitmap.")
