    How to scale(/rotate/move) a parent object without affecting its children?
    pythonwindowss26
    4 Posts 2 Posters 1.6k Views
    • O Offline
      ops
      Hi everyone,
      How can I set the scale of a parent object without affecting its children? I've tried using SetAbsScale() on the parent, but it also scaled all its children. I have seen a tutorial where you can press key '7' to do this interactively in the viewport, and I imagine there is a way to do this programmatically in python script?
      Any insight would be appreciated!
      • i_mazlovI Offline
        i_mazlov @ops
        Hi @ops,
        There's no built-in function, which does this for you, so you'd need to implement this on your own. Namely, you'd need to iterate through the object's children and adjust their transforms to the inverse change of the parents transform. Please check the code example below.
        There're two important things to mention:
        1. The SetMl() function won't make any effect if the object has "Protection tag" (or other restricting means, e.g. "Constraint" tag etc). This will behave basically the same as if you were to use "7" shortcut. If you actually want to work around this, you'd need to disable the restriction before using SetMl() yourself.
        2. Generally speaking the GetMg()/SetMg() functions are inefficient to use (because it's value is calculated from the chain of local transformation matrices Ml). This is unlikely to be noticeable in python, because python api is pretty slow by itself. However, if you were to use Mg in C++ API (especially in some tight place like e.g. GetVirtualObjects()), it could negatively affect the performance. Hence, it's highly recommended to use GetMl()/SetMl() instead, if possible.
        Ilia
        The code example:
        def SomehowMoveObject(obj: c4d.BaseObject) -> None:
            obj.SetAbsPos(obj.GetAbsPos() + c4d.Vector(100, 0, 0))
            opMlOriginal: c4d.Matrix = op.GetMl()  # Keep the original matrix before moving the object
            SomehowMoveObject(op)  # Somehow transform the parent object
            opMChangeInv: c4d.Matrix = opMlOriginal * ~op.GetMl()  # Calculate the inverse matrix for the children
            for child in op.GetChildren():
                child.SetMl(child.GetMl() * opMChangeInv)  # Apply the inverse transform to the children
        • O Offline
          ops
          Thanks Illia, for the exmple code!
          Too bad that there's no built-in function for it, but I understand now that I'll have to inverse-matrix the children myself.
          • O Offline
            ops
            And that's good to know about using GetMl() over Get Mg(), mainly for the performance reasons if I understood correctly.
