    How to use Python to implement rendering with Octane in C4D and export as PNG
    Scheduled Pinned Locked Moved General Talk
    6 Posts 3 Posters 2.7k Views 1 Watching
    • T Offline
      tx3008
      DunhouD i_mazlovI 2 Replies Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @tx3008
        Hey @tx3008 ,
        You need check the Octane BaseVideoPost to get the data container.
        You can change the render settings and use RenderDocument to render images.
        In case if you didn't want to use my extra libs, the GetVideoPost is not complicated.
        Cheer~
        DunHou
        # 获取渲染器VideoPost
        def GetVideoPost(document: c4d.documents.BaseDocument = None, videopost: int = ID_REDSHIFT) -> Optional[c4d.documents.BaseVideoPost]:
            Get the videopost of given render engine of filled document.
            Args:
                document (c4d.documents.BaseDocument, optional): Fill None to check active documents. Defaults to None.
                videopost (int, optional): The id of the videopost. Defaults to ID_REDSHIFT.
            Returns:
                Optional[c4d.documents.BaseVideoPost]: The videopost we get.
            if not document:
                document = c4d.documents.GetActiveDocument()
            rdata: c4d.documents.RenderData = document.GetActiveRenderData()
            vpost: c4d.documents.BaseVideoPost = rdata.GetFirstVideoPost()
            theVp: c4d.documents.BaseVideoPost = None
            while vpost:
                if vpost.GetType() == int(videopost):
                    theVp = vpost
                vpost = vpost.GetNext()
            return theVp
        import Renderer
            OctaneRenderer = Renderer.GetVideoPost(c4d.documents.GetActiveDocument(),
                                                   Renderer.ID_OCTANE)
            OctaneRenderer[c4d.SET_PASSES_FILEFORMAT] = 10 # Octane PNG, 6 = PNG
            OctaneRenderer[c4d.SET_PASSES_SAVE_MAINPASS] = True
            OctaneRenderer[c4d.SET_PASSES_ENABLED] = True
            OctaneRenderer[c4d.SET_PASSES_SAVEPATH] = "Render/$prj/$prj"
        if __name__=='__main__':
        https://boghma.com
        https://github.com/DunHouGo
        T 1 Reply Last reply Reply Quote 1
        • T Offline
          tx3008 @Dunhou
          @Dunhou
          Thank you very much for answering my questions. I saw your library yesterday and tried to write like this
          from typing import Optional
          ID_OCTANE: int = 1029525 # Octane
          ID_REDSHIFT: int = 1036219 # Redshift
          ID_ARNOLD: int = 1029988 # Arnold
          ID_VRAY: int = 1053272
          ID_CORONA: int = 1030480
          ID_LOOKS: int = 1054755
          ID_CENTILEO: int = 1036821
          ID_OCTANE_VIDEO_POST = 1029525 # octane render
          file_path="C:/Users/admin/Documents/WXWork/1688858265477290/Cache/File/2024-09/OC_light/11.png"
          doc: c4d.documents.BaseDocument  # The active document
          op: Optional[c4d.BaseObject]  # The active object, None if unselected
              Args:
              Returns:
              if not document:
              while vpost:
                  print(vpost.GetType())
                  if vpost.GetType() == int(ID_OCTANE_VIDEO_POST):
                      theVp = vpost
              return theVp
              OctaneRenderer = GetVideoPost(c4d.documents.GetActiveDocument(),ID_OCTANE)
              OctaneRenderer[c4d.SET_PASSES_FILEFORMAT] = 6 # Octane PNG, 6 = PNG
              OctaneRenderer[c4d.SET_PASSES_SAVEPATH] = file_path
          But there are no images generated in the directory. What could be the reason?
          DunhouD 1 Reply Last reply Reply Quote 0
          • DunhouD Offline
            Dunhou @tx3008
            @tx3008 You just modify the rd but not rendering anythings.
            https://boghma.com
            T 1 Reply Last reply Reply Quote 0
            • T Offline
              tx3008 @Dunhou
              @Dunhou I understand now. I have tried it successfully. Thank you very much!
              • i_mazlovI Offline
                i_mazlov @tx3008
                Hi @tx3008,
                Getting Started
                It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
                About your First Question
                Third party software is out of scope of our Support Procedures, namely:
                We cannot provide support for third party libraries.
                Hence I've moved your thread to the "General Talk" forum.
                Many thanks to @Dunhou for taking an active role of our community! Much appreciated!
                Ilia
                • i_mazlovI i_mazlov moved this topic from Cinema 4D SDK on
