    Adding image to GeDialog - Python Plugin/Script
    8 Posts 3 Posters 2.2k Views 2 Watching
    • E Offline
      ezeuz
      Is it possible to add image to the dialog/window from python plugin/script?
      The closest thing I find is Bitmap button, but you can only use pre-defined icons: https://developers.maxon.net/forum/topic/15365/gui-bitmap-button-properties/4
      • DunhouD Online
        Dunhou
        You can use BitmapButtonCustomGui.SetImage for a bitmap button, you can Init a bitmap with disk file, or use c4d.bitmaps.InitResourceBitmap for icons witch registed with a uniqe id.
        Cheers~
        DunHou
        https://boghma.com
        https://github.com/DunHouGo
        • E Offline
          ezeuz
          @Dunhou Thanks a lot! I checked a bit more after that and I also found out that you are indeed able to put custom image, using GeUserArea:
          https://developers.maxon.net/forum/topic/7155/8153_bitmap-in-userarea/22?_=1721638654806
          Btw, checked out your plugins, and it made me realize I can do a lot more on the GUI side using C4D Python API.
            Hello @ezeuz,
            Getting Started
            It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
            About your First Question
            The answer to your question depends a bit on the context, what you want to do. One solution can be to use a bitmap button as pointed out by yourself and @Dunhou. And you can indeed set there an image which is not a resource as pointed out by @Dunhou.
            The broader answer is that we never needed internally an image gadget, which is why there is none. Or viewed from the opposite side: When we need an image-like gadget, we tend to write specialized UIs like a bitmap button, a shader view or a image file view. The good news is that you can quite easily implement your own UI with GeUserArea, including an image control.
            Result
            Drawing an image using a bitmap button and user area side by side. While we can disable button behaviour like mouse over fading, we cannot truly control the scaling behaviour of the image in such button. With the bitmap button settings we can force a specific size which is smaller or larger than the original size, but we cannot make the image scale with the button or control its alignment within the button. In a GeUserArea we can control all that with very little code.
            """Demonstrates how to display an image in a dialog using both a bitmap button and a custom image
            gadget.
            import itertools
            from mxutils import CheckType
            class ImageArea(c4d.gui.GeUserArea):
                """Realizes a custom image gadget that displays a bitmap.
                This would have to be customized to do exactly what you want. Here I just realized an image
                gadget that both scales up and down the image to fit the user area. WHich is different from
                what the bitmap button does.
                MIN_SIZE_DEFAULT: tuple[int, int] = (50, 50)
                def __init__(self, bmp: c4d.bitmaps.BaseBitmap, label: str):
                    """Initializes the image gadget with the given bitmap and label.
                    self._bitmap: c4d.bitmaps.BaseBitmap = CheckType(bmp, c4d.bitmaps.BaseBitmap)
                    self._label: str = CheckType(label, str)
                def DrawMsg(self, x1: int, y1: int, x2: int, y2: int, msg: c4d.BaseContainer) -> None:
                    """Called by Cinema 4D to draw the content of the user area.
                    bmp: c4d.bitmaps.BaseBitmap = self._bitmap
                    self.DrawBitmap(bmp, # The image to draw.
                                    x1, y1, x2, y2, # The area in the user area to draw the image.
                                    0, 0, bmp.GetBw(), bmp.GetBh(), # The area  in the image to draw.
                                    mode=c4d.BMP_NORMAL) # The drawing flags, we signal here just fast scaling.
                    # Draw a label on top of the image.
                    textHeight: int = self.DrawGetFontHeight()
                    self.DrawSetTextCol(fg=c4d.Vector(1), bg=c4d.Vector(0.25))
                    self.DrawText(self._label, x1 + 5, y2 - textHeight - 5, flags=c4d.DRAWTEXT_HALIGN_LEFT)
                def MinSize(self, msg: c4d.BaseContainer) -> c4d.Vector:
                    """Called by Cinema 4D to determine the minimum size of the user area.
                    # Here we could also implement that the user area cannot scale below the size of the image
                    # it wraps.
                    return c4d.Vector(*self.MIN_SIZE_DEFAULT, 0)
            class ImageDialog(c4d.gui.GeDialog):
                """Realizes a dialog that displays an image using both a bitmap button and a custom image
                gadget."""
                # The IDs of the dialog elements.
                ID_BITMAP_BUTTON: int = 1000
                ID_IMAGE_AREA: int = 1001
                def __init__(self):
                    """Initializes the dialog's member variables.
                    self._imageArea: ImageArea | None = None
                @staticmethod
                def GetExampleImage(height: int, width: int) -> c4d.bitmaps.BaseBitmap:
                    """Renders a gradient into a bitmap of the given #height and #width.
                    bitmap: c4d.bitmaps.BaseBitmap = CheckType(c4d.bitmaps.BaseBitmap())
                    if not bitmap.Init(width, height) == c4d.IMAGERESULT_OK:
                        raise RuntimeError("Failed to initialize the bitmap.")
                    for y, x in itertools.product(range(height), range(width)):
                        bitmap.SetPixel(x, y, int(x / width * 254.99),
                                              int(y / height * 254.99),
                                              255)
                    return bitmap
                def CreateLayout(self):
                    """Called by Cinema 4D to let the user populate the dialog with GUI elements.
                    # Set the title of the dialog, the margin of the implicitly defined outmost group ("border
                    # space"), and the padding between elements ("space") in that outmost group.
                    self.SetTitle("Image Dialog")
                    self.GroupBorderSpace(10, 10, 10, 10)
                    self.GroupSpace(5, 5)
                    bmp: c4d.bitmaps.BaseBitmap = self.GetExampleImage(128, 256)
                    # Add a bitmap button to display the image. It is important here to either disable fading
                    # in the button or not to use SCALEFIT as a layout flag for the button, as the button
                    # background not covered by the bitmap will otherwise be tinted when hovered. What we cannot
                    # influence very well is how the image is scaled. We can enforce a specific scaling size but
                    # we cannot dynamically fit the image to the button size, as that is not the purpose of a
                    # bitmap button.
                    bc: c4d.BaseContainer = c4d.BaseContainer()
                    bc[c4d.BITMAPBUTTON_DISABLE_FADING] = True
                    gui: c4d.gui.BitmapButtonCustomGui = CheckType(self.AddCustomGui(
                        self.ID_BITMAP_BUTTON, c4d.CUSTOMGUI_BITMAPBUTTON, "",
                        c4d.BFH_SCALEFIT | c4d.BFV_TOP, 0, 0, bc), c4d.gui.BitmapButtonCustomGui)
                    gui.SetImage(bmp)
                    # Add a custom image gadget to display the image. Here we can do pretty much what we want
                    # without any restrictions. We can scale the image to fit the user area, or super impose
                    # text as I did here. It is important to make sure that the user area is not destroyed
                    # by storing it in the dialog instance as I did here with self._imageArea.
                    self._imageArea: ImageArea = ImageArea(bmp, "Example Image")
                    self.AddUserArea(self.ID_IMAGE_AREA, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT,
                                     *ImageArea.MIN_SIZE_DEFAULT)
                    self.AttachUserArea(self._imageArea, self.ID_IMAGE_AREA)
                dlg: ImageDialog = ImageDialog()
                dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=400, defaulth=400)
            DunhouD 1 Reply Last reply Reply Quote 2
            • E Offline
              ezeuz
              @ferdinand Thanks a lot for the reply (and all of your example codes throughout the years)! Yeah I managed to make one using UserArea, I def think this is a crucial feature to be added in the sample code in GitHub (tbh a ton of your codes are just too useful to be left alone in forums). Especially since it's a multi-step process unlike PySide (used by Maya plugin), for example.
              • DunhouD Online
                Dunhou @ferdinand
                @ferdinand just a quick question, how can we draw the _label text perfect above the image with alpha but not with a bg color?
                https://boghma.com
                  ferdinand @Dunhou
                  Hey @Dunhou,
                  I do not think that this is possible. At least not in a sane way, as there is no way to control the opacity of the text drawing background color alone. What you probably could do is:
                  1. Scale your image to draw down to the size of your GeUserArea drawing region, using something like BaseBitmap.ScaleBicubic.
                  2. Now init a GeClipMap canvas with that bitmap.
                  3. Draw the text.
                  4. Finalize and get the bitmap for the canvas and draw that result into your GeUserArea.
                  Which is a bit "ehh" performance-wise (could be mitigated by caching the underlying GeClipMap result) but will then also force you to do really everything in the GeClipMap, loosing access to things like GeUserArea.DrawCustomButton.
                  DunhouD 1 Reply Last reply Reply Quote 0
                  • DunhouD Online
                    Dunhou @ferdinand
                    @ferdinand fine for that, like I think, this is not perfect solution for this, thanks for your confirm!
                    Cheers~
                    DunHou
                    https://boghma.com
