    Problem with creating keyframes for tags and object propertries
    Scheduled Pinned Locked Moved General Talk
    learning-resource
    3 Posts 3 Posters 1.7k Views 1 Watching
    • P Offline
      phil_bronte
      While editing tags or object properties, no new keyframes appear on the video track. If you create them manually, all settings except moving, scaling and rotation are not applied.
      Also, if you select a tag separately from an object - there is no possibility to make a keyframe at all
      2024-05-05 18-39-15.mp4
      Prolly a stupid question, but I haven't found any help. It looks like I have disabled something. What to do?
      • R Offline
        Retopo01
        I think you need to check the toggle buttons for those to the right of the timeline controls.
        though I'm not sure if this is the right place to ask as this is was on the plug-in café forum support and guidelines page:
        "Please note that Plugin Café is intended for Cinema 4D and Cineware developer support only. For end-user Cinema 4D support requests please use Maxon's customer support."
          ferdinand @phil_bronte
          Hello @phil_bronte,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          Your question is off-topic even for our General Talk forum because this forum is about the APIs of Maxon products and coding in general. We will not delete such end-user questions but you will not get an answer from Maxon here, and likely also no community answer as must users are here developers or technical artists.
          Please visit our Support Center when you have a technical end-user question.
