    Easier Way to Offset an Animation of an Object?
    pythonr25windowsr21
    4 Posts 2 Posters 2.3k Views 1 Watching
    • B Offline
      bentraje
      Is there an easy way to offset an animation of an object?
      For example, I have a position.x track keyframe to from 5 to 10.
      I just want to offset it by 2 frames through python.
      Is there a one liner to do it? c4d.MoveTrack(frame=2) or something?
      Haven't tried it but there is CCurve.MoveKey or something.
      So it woud be like. Get Track. Get Curve. Get Key shenanigan. Loop through those keys. Loop through those curves etc.
      I just really want to offset it Track.
      Is there an easier of doing that?
      P.S. And I think there's no sample code on how to do it in the forum or in the documentation.
      • B Offline
        bentraje
        Okay. Manage it figure moving it without using the MoveKey. Still verbose though šŸ˜ž
            obj = doc.GetActiveObject()
            desc_x = c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0),
                            c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0))
            track = obj.FindCTrack(desc_x)
            curve = track.GetCurve()
            key_count = curve.GetKeyCount()
            fps = 24
            offset_frame = 2
            for index, value in enumerate(range(key_count)):
                key = curve.GetKey(index)
                time = key.GetTime()
                frame =  (time.GetFrame(fps))
                new_frame = frame + offset_frame
                new_time = c4d.BaseTime(new_frame/fps)
                key.SetTime(curve, new_time)
          ferdinand @bentraje
          Hey @bentraje,
          Thank you for reaching out to us. That is the only way to do it as far as I know. APIs tend to require much more verboseness than user interfaces. And the Python Cinema 4D API is there quite harmless, try C++ šŸ˜‰
          • B Offline
            bentraje
            yea python is much more forgiving than C++. i was just wondering if there was an already existing API for such task. šŸ‘
