    fieldlayer with variable tag
    windowspython2023
    2 Posts 1 Posters 686 Views 1 Watching
    • D Offline
      datamilch
      hi there,
      I'm trying to achieve the following:
      A python generator that creates an object with a vertex map (A). vertex map (A) is then inserted in a second vertex map (B) to be able to blur (A) with the mode 'average'. (If there is another way to blur a vertex map directly in (A) this would be great, too) You can see my test-setup without the python generator in the screenshot and it works so far.
      Now with python I have to create fieldlayers with the correct type to make it work. But it looks like the Variable Tag is missing in the list of types. I hope it's not a limitation of of the api.
      My test-file is attached. Here is the code of the generator:
      from typing import Optional
      doc: c4d.documents.BaseDocument # The document evaluating this python generator
      op: c4d.BaseObject # The python generator
      hh: Optional["PyCapsule"] # A HierarchyHelp object, only defined when main is executed
      def main() -> c4d.BaseObject:
          null = c4d.BaseObject( c4d.Onull )
          circle = c4d.BaseObject( c4d.Osplinecircle )
          circle[c4d.PRIM_CIRCLE_RADIUS] = 150
          cube = c4d.BaseObject( c4d.Ocube )
          cube[c4d.PRIM_CUBE_SUBX] = cube[c4d.PRIM_CUBE_SUBY] = cube[c4d.PRIM_CUBE_SUBZ] = 40
          vertex_tag = cube.MakeTag( c4d.Tvertexmap )
          vertex_tag[c4d.ID_TAGFIELD_ENABLE] = 1
          fields = c4d.FieldList()
          fields.Flush()
          f_layer_1 = c4d.modules.mograph.FieldLayer( c4d.FLspline )
          f_layer_1.SetLinkedObject( circle )
          f_layer_1[1009] = 1  # distance mode = radius
          f_layer_1[1003] = 50 # radius
          f_layer_1[1005007] = 99 # inner offset
          fields.InsertLayer( f_layer_1 )
          vertex_tag[c4d.ID_TAGFIELDS] = fields
          displacer = c4d.BaseObject( c4d.Odisplacer )
          shader = c4d.BaseShader( c4d.Xcolor )
          displacer.InsertShader( shader )
          displacer[c4d.ID_MG_SHADER_SHADER] = shader
          fields_displace = c4d.FieldList()
          fields_displace.Flush()
          f_layer_2 = c4d.modules.mograph.FieldLayer( c4d.FLpolygonobject ) # should be type variable tag
          f_layer_2.SetLinkedObject( vertex_tag )
          fields_displace.InsertLayer( f_layer_2 )
          displacer[c4d.FIELDS] = fields_displace
          circle.InsertUnderLast( null )
          cube.InsertUnderLast( null )
          displacer.InsertUnder( cube )
          return null
      test - py_generator displacer 01.c4d
      • D Offline
        datamilch
        found the solution ... the corresponding type is called: FLweight
