    • Unread
    Can't generate Plugin ID
    General Talk
    • merkvilsonM
      merkvilson
      Hello!
      I need to generate a new Plugin ID for Cinema 4D's plugin ASAP. But I can't log in to my account on the plugincafe forum.
      I tried to change the password but it changed only the current account password.
      • ferdinandF
        ferdinand @merkvilson
        Hello @merkvilson,
        Thank you for reaching out to us. This topic is not Cinema 4D SDK related I therefore moved it.
        But I can't log in to my account on the plugin cafe forum. I tried to change the password but it changed only the current account password.
        I assume this means that the reason for not being able to login is that you lost your password. But I am not quite sure what you mean by "current account" password. While this forum cloned the user settings and data from the old forum (Plugin Café), they are still two separate forums. So, if you want to reset your Plugin Café account, you would have to do it on https://plugincafe.maxon.net/. There is no need to keep passwords of both forums 'in sync'.
        I have forcibly logged you out from Plugin Café and manually sent you a password reset e-mail. I also sent you five plugin IDs you can use via PM.
        • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
