    Lasso Selection Tool MDATA_SELECTION_VISIBLE Setting Doesn't Work
    Scheduled Pinned Locked Moved Bugs
    pythons26windows
    2 Posts 2 Posters 885 Views
    • G Offline
      Gaal Dornik
      Hello, i'm trying to make a popup menu with selection modes and for some reason lasso selection Visible option which is set by MDATA_SELECTION_VISIBLE isn't working. Live and Rectangle Selection are working fine...
      Cinema 4D R26.
      from typing import Optional
      from c4d import gui
      def tool():
          return doc.GetActiveToolData()
          # Set IDs
          ID_LIVE_SELECTION              = c4d.FIRST_POPUP_ID
          ID_LIVE_SELECTION_THROUGH      = c4d.FIRST_POPUP_ID + 1
          ID_LASSO_SELECTION             = c4d.FIRST_POPUP_ID + 2
          ID_LASSO_SELECTION_THROUGH     = c4d.FIRST_POPUP_ID + 3
          ID_RECTANGLE_SELECTION         = c4d.FIRST_POPUP_ID + 4
          ID_RECTANGLE_SELECTION_THROUGH = c4d.FIRST_POPUP_ID + 5
          # Create container for Popup
          popup = c4d.BaseContainer()
          popup.SetString(ID_LIVE_SELECTION,              "Live Selection")
          popup.SetString(ID_LIVE_SELECTION_THROUGH,      "Live Selection Through")
          popup.SetString(ID_LASSO_SELECTION,             "Lasso Selection")
          popup.SetString(ID_LASSO_SELECTION_THROUGH,     "Lasso Selection Through")
          popup.SetString(ID_RECTANGLE_SELECTION,         "Rectangle Selection")
          popup.SetString(ID_RECTANGLE_SELECTION_THROUGH, "Rectangle Selection Through")
          # Display Popup
          result = gui.ShowPopupDialog(cd=None, bc=popup, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS)
          print("result: %s" % result)
          # Process
          if result == ID_LIVE_SELECTION:
              c4d.CallCommand(200000083) # Live Selection
              tool()[c4d.MDATA_SELECTLIVE_VISIBLE] = True
              tool()[c4d.MDATA_SELECTLIVE_RADIUS] = 3
          elif result == ID_LIVE_SELECTION_THROUGH:
              tool()[c4d.MDATA_SELECTLIVE_VISIBLE] = False
          elif result == ID_LASSO_SELECTION:
              c4d.CallCommand(200000085) # Lasso Selection
              tool()[c4d.MDATA_SELECTION_VISIBLE] = True
          elif result == ID_LASSO_SELECTION_THROUGH:
              tool()[c4d.MDATA_SELECTION_VISIBLE] = False
          elif result == ID_RECTANGLE_SELECTION:
              c4d.CallCommand(200000084) # Rectangle Selection
          elif result == ID_RECTANGLE_SELECTION_THROUGH:
      def state():
          # Defines the state of the command in a menu. Similar to CommandData.GetState.
          return c4d.CMD_ENABLED
      • i_mazlovI Offline
        i_mazlov
        Hi @Gaal-Dornik ,
        Thanks for reaching out to us. Please excuse the delay.
        This issue is now tracked via internal bug tracking system. Thread is tagged to_fix, so that the thread can be tracked more closely.
        Ilia
        • maxonM maxon moved this topic from Cinema 4D SDK on
