    Command line Rendering Takes
    Scheduled Pinned Locked Moved General Talk
    2 Posts 2 Posters 759 Views 1 Watching
    • E Offline
      emlcpfx
      I can get the command line renderer to render a specific Take from a file by using the -take flag.
      How can I get that one subprocess to render all Takes from a given file? I don't want to have to load, unload, load, unload the commandline renderer for every take.
      Something like
      ... -take Take1, Take2, Take3
      • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
        ferdinand @emlcpfx
        Hello @emlcpfx,
        Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
        Getting Started
        Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
        • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
        • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
        • Forum Structure and Features: Lines out how the forum works.
        • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you follow the idea of keeping things short and mentioning your primary question in a clear manner.
        About your First Question
        Since your question is not related to any of the Cinema 4D APIs, it is unfortunately out of scope of support for Plugin Café. I therefore have moved your question to our off-topic forum. The SDK group of Maxon which runs this forum cannot provide an answer in this case, although you might receive a community answer.
        To receive an answer from Maxon, you should reach out to our support team via a Support Request. When you want to solve the problem programmatically, you are welcome to open a new topic here. This would then however not happen via the commandline app but either the c4dpy or Cinema 4D app. Note that there is no direct solution in our APIs either, likely because Cinema 4D itself does not offer that feature out of the the box. But it should be solvable with ~300 lines of code script. One approach could be to save (temporary) variants of a file for each take in it and launch them then with the render queue as sperate renders.
        Please also note that we cannot write your script(s) for you, but we are more than happy to help you along the way. So
