    how to track if the document has changed?
    4 Posts 2 Posters 1.2k Views 1 Watching
    • D Offline
      datamilch
      hi there,
      i have a command plugin that is dependent on the state of the active document. so i want to track if the document has changed.
      there seems to be no dedicated core message. so i tried the following. but it gives me "basedocument is not alive", which makes senes in a way. but how can i make it work?
      class MyDialog( ...
         doc_old = None
         def CoreMessage(self, cid, msg):
              if cid == c4d.EVMSG_CHANGE:
                  if doc != self.doc_old:
                      print ("doc changed")
                      self.doc_old = doc
      thanks,
      sebastian
      • M Offline
        m_adam
        Hi @datamilch when you see the error message "XXX is not alive" this means the actual C++ object that represent your python object does not exist anymore. E.g. in a case of a document the python object just hold a pointer (a memory address pointing to the BaseDocument), so if you close the document, the memory address will not point anymore on a BaseDocument, so to avoid any crash this error is raised.
        The best way to do what you want to achieve is to use a timer, as EVMSG_CHANGE is normally sent to notify that something changed in a scene, so the scene need to be re-evaluated but there is no way to be sure when switching to a new document, this one will be executed (as it may already be). So Find bellow an example dialog using timer
        class MyDialog(c4d.gui.GeDialog):
            def __init__(self):
                self.activeDoc = c4d.documents.GetActiveDocument()
            def CreateLayout(self):
                self.SetTimer(500)
            @property
            def activeDoc(self):
                doc = getattr(self, '_activeDoc', None)
                if doc is None:
                    return None
                if not doc.IsAlive():
                    return None
                return doc
            @activeDoc.setter
            def activeDoc(self, value):
                if not isinstance(value, c4d.documents.BaseDocument):
                    raise TypeError("value is not a c4d.documents.BaseDocument.")
                self._activeDoc = value
            def Timer(self, msg):
                if activeDoc is None:
                if activeDoc != self.activeDoc:
                    oldDoc = self.activeDoc
                    self.activeDoc = activeDoc
                    print("doc changed")
            global diag
            diag = MyDialog()
            diag.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=960, defaulth=600)
        # Execute main()
        • D Offline
          datamilch
          hi maxime,
          thankt you! that works 🙂
          one question:
          you left the 'oldDoc' in there. I suppose because you didn't know if i use it anywhere else - i dont.
          But isn't there the chance, that the value/pointer stored in oldDoc might become not alive at some point? so if i would want to call oldDoc again i'd have to check isAlive() beforehand?
          • M Offline
            m_adam
            Hi correct, if you look at my code I do
            This means oldDoc will call the activeDoc property getter. And within it I already check for IsAlive and return None if the saved document is not alive.
                @property
                    if doc is None:
                        return None
                        return None
                    return doc
            So for my use case it's fine enough, but you are right, if you store somewhere this oldDoc variable and use it latter then yes you need to check for IsAlive.
