    How to obtain all vertices of an object in C++.
    s26c++sdk
    3 Posts 2 Posters 788 Views 1 Watching
    • P Offline
      pchg
      Hello colleagues,
      I used C++ to write the C4D S26 plugin on Windows 10,Get all vertices of an object,but There are no GetAllPoints in the document。
      maxon::BaseArray<maxon::Vector >objectPoints = obj->GetAllPoints();
      GetAllPoints included in Python documentation,but not in C++.
      Thanks in advance!
      • M Offline
        m_adam
        Hi this can be done via PointObject::GetPointR or GetPointW. GetPointW is if you want to modify the position otherwise use GetPointR if you only need to read them.
        So this will give use something like that where obj is a PointObject:
        iferr_scope_handler
        return false;
        maxon::BaseArray<maxon::Vector>> pts;
        const Vector* const objPts = obj->GetPointR();
        const Int32 objPtCount = obj->GetPointCount();
          for (Int i = 0; i < objPtCount; ++i)
            pts.Append(objPts[i]) iferr_return;
        P 1 Reply Last reply Reply Quote 0
        • P Offline
          pchg @m_adam
          @m_adam Thanks
