    Multi-menu menu, how to
    sdkc++
    5 Posts 2 Posters 1.9k Views 1 Watching
    • WickedPW Offline
      WickedP
      Hi folks,
      How does one go about making a multi-menu menu, like the shortcuts in the viewport:
      Can I do this in my own dialog/UA?
      WP.
      wickedp.com
        ferdinand @WickedP
        Hello @WickedP,
        Thank you for reaching out to us. In short - radial menus or any form of "multi-menus" are not part of the public API. There is c4d.gui.ShowPopupDialog but it is blocking, so trying to open two or more menus at once will not work.
        So, you would have to use multiple GeDialog instances at once to do this. And for that you will need a handler for them, something like I did in the quick sketch below. The problem with this is, that you cannot have a dialog of type DLG_TYPE_ASYNC_POPUPEDIT, i.e., a borderless dialog, with a menu. Which then means that you also must (re)-implement menus.
        I personally would not go down that rabbit hole, there is a lot of work and only little reward. Just use a dialog with one menu or ShowPopupDialog.
        FYI: ShowPopupDialog is ShowPopupMenu in C++.
        Code:
        """Realizes a dialog handler which handles multiple dialogs, primarily with the feature that closing
        one dialog entails closing all of them.
        Must be run in the script manager.
        class DialogHandler:
            """Realizes the dialog handler object.
            def __init__(self, count=4) -> None:
                self._collection: dict[MyDialog, bool] = {MyDialog(self): True for i in range(count)}
            def Open(self):
                for i, dlg in enumerate(self._collection):
                    dlg.Open(c4d.DLG_TYPE_ASYNC, xpos=400+i*100, ypos=400, defaultw=100, defaulth=24)
            def OnClose(self, sender: "MyDialog") -> None:
                self._collection[sender] = False
                for dlg, isOpen in self._collection.items():
                    if isOpen:
                        dlg.Close()
        class MyDialog(c4d.gui.GeDialog):
            """Realizes the handled dialog.
            def __init__(self, handler: DialogHandler) -> None:
                self._handler: DialogHandler = handler
            def CreateLayout(self) -> bool:
                self.MenuSubBegin("Test")
                self.MenuAddString(1000, f"Foo&i{c4d.Ocube}&")
                self.MenuAddString(1001, f"Bar&i{c4d.Osphere}&")
                self.MenuSubEnd()
            def InitValues(self) -> bool:
            def Command(self, id: int, msg: c4d.BaseContainer) -> bool:
                self.Close()
            def AskClose(self) -> bool:
                self._handler.OnClose(self)
                return False
        handler: DialogHandler = DialogHandler(count=4)
            handler. Open()
        WickedPW 1 Reply Last reply Reply Quote 0
        • WickedPW Offline
          WickedP @ferdinand
          Thanks @ferdinand,
          I've made a mock-up of a multi-menu system using dialogs as you suggested. Work-in-progress question:
          When I close my menu system (destroy the dialogs), how can I set another dialog/window as the main focus again? Currently, if I open up my dialogs, and say, go and type something in Notepad, then come back to CInema and close the menus/dialogs, Windows switches back to Notepad as the main focus window. How can I avoid this?
          WP.
          wickedp.com
            ferdinand @WickedP
            Hello @WickedP,
            hm, good question, you can grab the HWND of a dialog with GeDialog::GetWindowHandle, but there is neither a way to determine the focused CDialog (not a typo, the underlying type of GeDialog) nor set the focused dialog. With ::GetWindowHandle and tracking the active window handle via OS functions, you probably could fiddle things into place. But just as GUI stuff, I personally also would avoid OS backend stuff at all costs.
            But my main question would be: When you use DLG_TYPE_ASYNC_POPUPEDIT will such dialogs actually 'steal' the focus from another dialog/window? My gut feeling would be no, but I did not try.
            • WickedPW Offline
              WickedP @ferdinand
              Thanks @ferdinand,
              Agree. I've avoided using OS-specific calls up until now. But for this one I've had to make an exception. Not an ideal solution, but it seems to work:
              To get around the lost window focus issue, I'm using the first dialog's Timer() to poll and check if any dialog in the menu has window focus. If none do, e.g., a user has clicked away, the system self-destructs. If a menu selection is made, it sends a Message() back to the calling object with details, and then self-destructs.
              It's all a bit of a hack. But it works. 🤷
              WP.
              Update: I'll mark this thread as solved. If I have any further questions I'll pop back in.
              wickedp.com
              • ferdinandF ferdinand referenced this topic on
