    Get Spline Points Positions from PLA keyframes
    4 Posts 2 Posters 1.2k Views 1 Watching
    • J Offline
      Joel
      I am tasked with obtaining the position of spline points from the PLA keyframes of the set spline.
      From the SDK, I ended up at a <c4d.PLAData object at 0x000001B118B7F2C0>
      But I do not know how to extract the spline points' positions from this PLAData object.
      Code to get the PLAData object:
      def get_PLAData():
           spline = doc.SearchObject('Spline')
           track = None
           PLA = c4d.DescID(c4d.DescLevel(c4d.CTpla, c4d.CTpla))
           tracks = spline.GetCTracks()
           for t in tracks:
               tid = t.GetDescriptionID()
               if tid[0] == PLA[0] : track = t
           curve = track.GetCurve()
           for i in range(curve.GetKeyCount()):
               key = curve.GetKey(i)
               data = key.GetGeData()
               print(data[c4d.CK_PLA_DATA])
           get_PLAData()
      if __name__=='__main__':
      I also tried setting the document time with doc.SetTime(key.GetTime()) and then spline.GetAllPoints() but I am getting the same points' positions all the time.
      What am I doing wrong? Or how can I get the points' positions from the PLAData Object?
      Thank you for your time.
        ferdinand @Joel
        Hey @joel,
        Thank you for reaching out to us. You almost got it 🙂 You must unpack the c4d.PLAData which consists of a PointTag and a TangentTag. These hold then the raw data, but tangents are only yielded for spline objects. Find an example below.
        Result:
        frame = 0, points = [Vector(-100, 0, -100), Vector(-100, 0, 100), Vector(100, 0, -100), Vector(100, 0, 100)]
        frame = 30, points = [Vector(0, 0, -141.421), Vector(-141.421, 0, 0), Vector(141.421, 0, 0), Vector(0, 0, 141.421)]
        Code:
        """Showcases how to access the animation data of a PLA track.
        import typing
        op: typing.Optional[c4d.BaseObject] # The currently selected object, can be None.
        def GetPlaData(node: c4d.PointObject) -> typing.Generator[
            tuple[int, list[c4d.Vector], list[tuple[c4d.Vector, c4d.Vector]], None, None]]:
            """Yields all PLA data of #node as triples in the form (frame, points, tangents).
            Meaningful tangent data will only be yielded for spline objects.
            # Input validation.
            if not isinstance(node, c4d.PointObject):
                raise TypeError(f"{node = }")
            doc: typing.Optional[c4d.documents.BaseDocument] = node.GetDocument()
            if not isinstance(doc, c4d.documents.BaseDocument):
                raise IOError(f"{node} is not attached to a document.")
            # Check what kind of point object #node is.
            isSpline: bool = isinstance(node, c4d.SplineObject)
            # Iterate over all tracks.
            for track in node.GetCTracks():
                if track.GetType() != c4d.CTpla:
                    continue
                # This is a PLA track, iterate over its keys.
                curve: c4d.CCurve = track.GetCurve()
                for kid in range(curve.GetKeyCount()):
                    key: c4d.CKey = curve.GetKey(kid)
                    frame: int = key.GetTime().GetFrame(doc.GetFps())
                    # Get the PLA data and unpack it into the point and tangent tag storing the data.
                    plaData: c4d.PLAData = key.GetGeData()[c4d.CK_PLA_DATA]
                    data: typing.Optional[tuple[c4d.PointTag, c4d.TangentTag]] = plaData.GetVariableTags()
                    if not data or len(data) != 2:
                        print (f"Stepping over uninitialized PLA data for key {kid} in {node}.")
                        continue
                    # Both PointTag and TangentTag are instances of VariableTag, i.e., we can access their
                    # data with VariableTag::GetAllHighlevelData(). We could also use low level access, but
                    # it does not yield any benefits here. For point objects which are not splines, we
                    # return the empty list for the tangents.
                    points: list[c4d.Vector] = data[0].GetAllHighlevelData()
                    tangents: list[c4d.Vector] = data[1].GetAllHighlevelData() if isSpline else []
                    # Yield the data.
                    yield frame, points, tangents
            if not op:
                raise RuntimeError("Please select an object.")
            # Iterate over all data points in the PLA animations of #op.
            for frame, points, _ in GetPlaData(op):
                print(f"{frame = } - {points = }")
        • J Offline
          Joel
          I am trying your code however I am getting ReferenceError: the object 'c4d.PointTag' is not alive.
          What could be the issue?
            ferdinand @Joel
            Hey @joel,
            a 'dead' object means that Python tries to reference a node which does not exist in the C++ layer anymore, i.e., has been de- or reallocated. Since my function retrieves the tag on the spot and does not attempt to pass it outside of the function, it seems a bit unlikely that the tag is already dead, at least I am not experiencing any of this.
            Please provide the scene, code you are running, and the exact stack trace (do not forget to save your script first, so that the trace has the correct line numbers). Otherwise I will not be able to help you.
            • ferdinandF ferdinand forked this topic on
            • F facumh referenced this topic on
