    • Unread
    Help with Modal Renderer
    12 Posts 0 Posters 1.3k Views
    • H Offline
      Helper
      On 21/06/2003 at 21:52, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:
      I found an example in the forum archive called Modal Renderer and it basically created a dialog box in which a preview of a render was shown while it rendered.  My question is if someone could help me convert it from a GeModalDialog to a GeDialog.  I have tried to convert it but I have been unsuccessful.  My goal is to make it render and show the preview while allowing the user to continue to do work in the background.  If I need to show the code I can, it is also in the forum Archives under the subject modal renderer.  I would really appreciate any help, thx!
      Nate
      • H Offline
        Helper
        On 22/06/2003 at 07:29, xxxxxxxx wrote:
        there aer non-modal examples in the project folder of the SDK. They might help you.
        • H Offline
          Helper
          On 22/06/2003 at 08:31, xxxxxxxx wrote:
          alright I will check them out
          • H Offline
            Helper
            On 22/06/2003 at 08:38, xxxxxxxx wrote:
            Thx for your help. The only thing though is that they don't have any examples of multiple dialog windows open at once, or one GeDialog calling the other.
            • H Offline
              Helper
              On 22/06/2003 at 08:44, xxxxxxxx wrote:
              Ok, here is the part of the code that I want to change to GeDialog in case it will help.
                BaseObject* null = doc->GetActiveObject();
                if (!null) return;
              CameraObject* cam = static_cast<CameraObject*>(AllocObject(Ocamera));
                doc->InsertObject(cam, NULL, NULL);
              cam->SetPos(null->GetMg().off); // Set pos. to global pos. of null
                cam->SetRot(Vector(0,0,0)); // Set rotation (radians, HPB)
              // Active the camera
                BaseObject* oldcam = doc->GetRenderBaseDraw()->GetSceneCamera(doc);
              doc->GetRenderBaseDraw()->SetSceneCamera(cam);
              // Create some temporaries for the render
                BaseContainer rdata = doc->GetActiveRenderData()->GetData();
                BaseBitmap* bmp = AllocBaseBitmap();
                bmp->Init(rdata.GetLong(RDATA_XRES),  rdata.GetLong(RDATA_YRES));
              // Set render settings
                rdata.SetFilename(RDATA_PATH, Filename(null->GetName()));
              // 3) delete cameras
              cam->Remove();
                FreeObject(cam);
              // Active the old camera
                doc->GetRenderBaseDraw()->SetSceneCamera(oldcam);
              // 4) display a progress bar showing rendering/view progress.
              ModalRenderer r;
                Bool success = r.Render(doc, rdata, null->GetName(), FALSE);
              class ModalRenderer : private GeModalDialog
              public:
                ModalRenderer() :
                    m_doc(NULL),
                    m_bmp(NULL),
                    m_p(0.0),
                    m_result(NOTOK),
                    m_showerrors(TRUE),
                    m_rt(this) {}
              virtual ~ModalRenderer()
                  FreeBaseBitmap(m_bmp);
                  ShutdownThread();
              // Render document 'doc' with settings 'rdata',
                // displaying a progress windows with 'title' and
                // optionally not showing error messages.
                Bool Render(BaseDocument* doc, const BaseContainer& rdata,
                            const String& title = String(), Bool showerrors = TRUE)
                  if (!doc) return FALSE;
                  if (m_rt.IsRunning()) return FALSE;
              m_doc = doc;
                  m_rdata = rdata;
                  m_title = title;
                  m_showerrors = showerrors;
              Bool success = Open();
                  ShutdownThread();
                  return success && GetResult();
              private:
                BaseDocument* m_doc;
                BaseContainer m_rdata;
                String m_title;
                BaseBitmap* m_bmp;
                Bool m_showerrors;
              Real m_p;
                LONG m_result;
              enum
                  SCROLL_GROUP_ID = 100000,
                  PREVIEW_AREA_ID,
                  DLGGROUP_ID,
                  MAIN_GROUP_ID
              // Build the dialog
                virtual Bool CreateLayout()
                  if (!InitBitmap()) return FALSE;
                  SetTitle(m_title);
                  GroupBegin(MAIN_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT, 1, 0, "", 0);
                    GroupSpace(4,4);
              ScrollGroupBegin(SCROLL_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT,
                                     SCROLLGROUP_STATUSBAR | SCROLLGROUP_BORDERIN |
                                     SCROLLGROUP_NOBLIT);
                      AddUserArea(PREVIEW_AREA_ID, 0, m_bmp->GetBw(), m_bmp->GetBh());
                      AttachImage(PREVIEW_AREA_ID, m_bmp, 0);
                    GroupEnd();
              AddDlgGroup(DLG_CANCEL);
                  GroupEnd();
              return TRUE;
              // Init dialog and start render
                virtual Bool InitValues()
                  UpdatePreview();
                  SetTimer(500);
              Bool success = TRUE;
                  if (!m_rt.IsRunning())
                    success = m_rt.Start(TRUE);
              return success;
              // Ask if the render is running
                virtual Bool AskClose()
                  if (!m_rt.IsRunning()) return FALSE;
                  return !QuestionDialog("Do you really want to abort the rendering?");
              // Deal with close box and cancel button problems
                virtual LONG Message(const BaseContainer &msg, BaseContainer &result)
                  // Workaround for bad base class implementation
                  if (msg.GetId() == BFM_ACTION &&
                      msg.GetLong(BFM_ACTION_ID) == IDC_CANCEL)
                    return Command(IDC_CANCEL, msg);
                  else if (msg.GetId() == BFM_CHECKCLOSE)
                    return AskClose();
                  else
                    return GeModalDialog::Message(msg,result);
              // Check for cancel button
                virtual Bool Command(LONG id, const BaseContainer& msg)
                  if (id == IDC_CANCEL && !AskClose())
                    ShutdownThread();
                    return Close(FALSE);
                  return FALSE;
              // Run every 500 ms...
                virtual void Timer(const BaseContainer& msg)
                  UpdatePreview();
                  UpdateStatus();
              CheckFinished();
              // Create preview bitmap
                Bool InitBitmap()
                  m_bmp = AllocBaseBitmap();
                  return m_bmp->Init(m_rdata.GetLong(RDATA_XRES),
                                     m_rdata.GetLong(RDATA_YRES)) == IMAGE_OK;
              // Tell the preview to redraw itself
                void UpdatePreview()
                  GeUserArea* ua = GetUserArea(PREVIEW_AREA_ID);
                  if (ua) ua->Redraw(TRUE);
              // Set new statusline text
                void UpdateStatus()
                  String txt;
                  if (m_p != 1.0)
                    txt = "Rendering: " + LongToString(m_p * 100) + "%";
                  else
                    txt = "Finished!";
              BaseContainer msg(BFM_SETSTATUSBAR);
                  msg.SetLong(BFM_STATUSBAR_PROGRESSON, TRUE);
                  msg.SetString(BFM_STATUSBAR_TXT, txt);
                  msg.SetReal(BFM_STATUSBAR_PROGRESS, m_p);
              SendMessage(SCROLL_GROUP_ID, msg);
              // Wait until render thread is stopped
                void ShutdownThread()
                  m_rt.End();
                  m_rt.Wait(FALSE);
              // Check if the render is finished
                void CheckFinished()
                    Close(m_result == RAY_OK);
              // Internal class with render thread
                class RenderThread : public Thread
                public:
                  RenderThread(ModalRenderer* dlg) : m_dlg(dlg) {}
                  virtual ~RenderThread() { m_dlg = NULL; End(); Wait(FALSE); }
              virtual void Main()
                    if (!m_dlg) return;
              // Start render
                    LONG result =
                      RenderDocument(m_dlg->m_doc,
                                     ProgressFunction, m_dlg,
                                     m_dlg->m_bmp, m_dlg->m_rdata,
                                     TRUE, m_dlg->m_showerrors, this);
                    if (m_dlg) m_dlg->m_result = result;
              private:
                  ModalRenderer* m_dlg;
              // Called by RenderDocument now and then
                  static void ProgressFunction(Real p, void* dlg)
                    static_cast<ModalRenderer*>(dlg)->m_p = p;
                } m_rt;
              // So that the internal class can access private variables
                friend class RenderThread;
              • H Offline
                Helper
                On 24/06/2003 at 12:24, xxxxxxxx wrote:
                Just wanted to say that I'm not ignoring this message, but just that I haven't got time right now to write any code right now. (See the docs, "The support team will not write code for you. "... 😉
                Perhaps I'll get time to look into it later and extend the example. Until then you should look into the AsyncTest.cpp example and try to ask more specific questions. Sorry for the inconvenience.
                • H Offline
                  Helper
                  On 24/06/2003 at 13:00, xxxxxxxx wrote:
                  no problem, I understand.  At this point the problem is that when I change both dialogs to GeDialogs the parent dialog closes and nothing happens in the child dialog.  I am just trying to figure out what is going on.  I think it may have something to do with the ID that I am using when calling Open(TRUE, ID, -1, -1) on the child.  I am using the same one as the parent.  Thanks for your time.
                  Nate
                  • H Offline
                    Helper
                    On 24/06/2003 at 13:06, xxxxxxxx wrote:
                    You need a unique ID here from Plugincafe for EACH dialog you are creating. Currently there is no other way afaik.
                    • H Offline
                      Helper
                      On 24/06/2003 at 13:31, xxxxxxxx wrote:
                      Thanks again, I will try that.  I haven't coded in C++ before (only Ada) so getting use to the syntax and functionality of the language slows me down.
                      • H Offline
                        Helper
                        On 24/06/2003 at 18:32, xxxxxxxx wrote:
                        Ok, I am going to try and be a little more specific with the problem I am having because I think I have a little better handle on it.  I have a plugin X.  Basically what happens is X is a command plugin that calls a (asynchronous)GeDialog Y.  I can have the Dialog  Y create a layout and render a document with a certain set of settings and cameras.  This works perfectly fine.
                        Now I create another asynchronous GeDialog  Z in the same plugin (Note I give it an unique ID number but its not registered because I only want one option in the plugin menu).  I now make Z get called in CommandData::Execute by Z.Open(TRUE, ZID, -1, -1).  Z gets some inputs from the user and then calls Y.Open(TRUE, YID, -1, -1).  Ok so now when I run this plugin Z works perfectly and Y almost works.  When I call RenderDocument(....) nothing happens.  The weird thing is that it works when I open Y as a modal dialog or Y.Open(FALSE, YID, -1, -1).
                        So what happens is
                        X calls Z
                        Z calls Y
                        Y does everything but Render
                        Any thoughts?
                        • H Offline
                          Helper
                          On 25/06/2003 at 12:49, xxxxxxxx wrote:
                          I am beginning to think that you can only call a thread from a GeModalDialog (or GeDialog that is not asynchronous) if the thread has RenderDocument() in it.  I mean the dialog will work correctly but thread does not seem to execute RenderDocument or it wont wait until it finishes.
                          Nate
                          • H Offline
                            Helper
                            On 27/06/2003 at 13:40, xxxxxxxx wrote:
                            Well after going back to scratch and making my plugin more basic I found my problem.  I was closing the parent dialog too soon and not letting the information flow to the child dialog.  Thanks for all of your help.  Sorry for so many questions.
                            Nate
