    Help with Modal Renderer
    12 Posts 0 Posters 1.7k Views
      On 22/06/2003 at 07:29, xxxxxxxx wrote:
      there aer non-modal examples in the project folder of the SDK. They might help you.
        On 22/06/2003 at 08:31, xxxxxxxx wrote:
        alright I will check them out
          On 22/06/2003 at 08:38, xxxxxxxx wrote:
          Thx for your help. The only thing though is that they don't have any examples of multiple dialog windows open at once, or one GeDialog calling the other.
            On 22/06/2003 at 08:44, xxxxxxxx wrote:
            Ok, here is the part of the code that I want to change to GeDialog in case it will help.
              BaseObject* null = doc->GetActiveObject();
              if (!null) return;
            CameraObject* cam = static_cast<CameraObject*>(AllocObject(Ocamera));
              doc->InsertObject(cam, NULL, NULL);
            cam->SetPos(null->GetMg().off); // Set pos. to global pos. of null
              cam->SetRot(Vector(0,0,0)); // Set rotation (radians, HPB)
            // Active the camera
              BaseObject* oldcam = doc->GetRenderBaseDraw()->GetSceneCamera(doc);
            doc->GetRenderBaseDraw()->SetSceneCamera(cam);
            // Create some temporaries for the render
              BaseContainer rdata = doc->GetActiveRenderData()->GetData();
              BaseBitmap* bmp = AllocBaseBitmap();
              bmp->Init(rdata.GetLong(RDATA_XRES),  rdata.GetLong(RDATA_YRES));
            // Set render settings
              rdata.SetFilename(RDATA_PATH, Filename(null->GetName()));
            // 3) delete cameras
            cam->Remove();
              FreeObject(cam);
            // Active the old camera
              doc->GetRenderBaseDraw()->SetSceneCamera(oldcam);
            // 4) display a progress bar showing rendering/view progress.
            ModalRenderer r;
              Bool success = r.Render(doc, rdata, null->GetName(), FALSE);
            class ModalRenderer : private GeModalDialog
              ModalRenderer() :
                  m_doc(NULL),
                  m_bmp(NULL),
                  m_p(0.0),
                  m_result(NOTOK),
                  m_showerrors(TRUE),
                  m_rt(this) {}
            virtual ~ModalRenderer()
                FreeBaseBitmap(m_bmp);
                ShutdownThread();
            // Render document 'doc' with settings 'rdata',
              // displaying a progress windows with 'title' and
              // optionally not showing error messages.
              Bool Render(BaseDocument* doc, const BaseContainer& rdata,
                          const String& title = String(), Bool showerrors = TRUE)
                if (!doc) return FALSE;
                if (m_rt.IsRunning()) return FALSE;
            m_doc = doc;
                m_rdata = rdata;
                m_title = title;
                m_showerrors = showerrors;
            Bool success = Open();
                ShutdownThread();
                return success && GetResult();
            private:
              BaseDocument* m_doc;
              BaseContainer m_rdata;
              String m_title;
              BaseBitmap* m_bmp;
              Bool m_showerrors;
            Real m_p;
              LONG m_result;
            enum
                SCROLL_GROUP_ID = 100000,
                PREVIEW_AREA_ID,
                DLGGROUP_ID,
                MAIN_GROUP_ID
            // Build the dialog
              virtual Bool CreateLayout()
                if (!InitBitmap()) return FALSE;
                SetTitle(m_title);
                GroupBegin(MAIN_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT, 1, 0, "", 0);
                  GroupSpace(4,4);
            ScrollGroupBegin(SCROLL_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT,
                                   SCROLLGROUP_STATUSBAR | SCROLLGROUP_BORDERIN |
                                   SCROLLGROUP_NOBLIT);
                    AddUserArea(PREVIEW_AREA_ID, 0, m_bmp->GetBw(), m_bmp->GetBh());
                    AttachImage(PREVIEW_AREA_ID, m_bmp, 0);
                  GroupEnd();
            AddDlgGroup(DLG_CANCEL);
                GroupEnd();
            // Init dialog and start render
              virtual Bool InitValues()
                UpdatePreview();
                SetTimer(500);
            Bool success = TRUE;
                if (!m_rt.IsRunning())
                  success = m_rt.Start(TRUE);
            return success;
            // Ask if the render is running
              virtual Bool AskClose()
                if (!m_rt.IsRunning()) return FALSE;
                return !QuestionDialog("Do you really want to abort the rendering?");
            // Deal with close box and cancel button problems
              virtual LONG Message(const BaseContainer &msg, BaseContainer &result)
                // Workaround for bad base class implementation
                if (msg.GetId() == BFM_ACTION &&
                    msg.GetLong(BFM_ACTION_ID) == IDC_CANCEL)
                  return Command(IDC_CANCEL, msg);
                else if (msg.GetId() == BFM_CHECKCLOSE)
                  return AskClose();
                else
                  return GeModalDialog::Message(msg,result);
            // Check for cancel button
              virtual Bool Command(LONG id, const BaseContainer& msg)
                if (id == IDC_CANCEL && !AskClose())
                  ShutdownThread();
                  return Close(FALSE);
                return FALSE;
            // Run every 500 ms...
              virtual void Timer(const BaseContainer& msg)
                UpdatePreview();
                UpdateStatus();
            CheckFinished();
            // Create preview bitmap
              Bool InitBitmap()
                m_bmp = AllocBaseBitmap();
                return m_bmp->Init(m_rdata.GetLong(RDATA_XRES),
                                   m_rdata.GetLong(RDATA_YRES)) == IMAGE_OK;
            // Tell the preview to redraw itself
              void UpdatePreview()
                GeUserArea* ua = GetUserArea(PREVIEW_AREA_ID);
                if (ua) ua->Redraw(TRUE);
            // Set new statusline text
              void UpdateStatus()
                String txt;
                if (m_p != 1.0)
                  txt = "Rendering: " + LongToString(m_p * 100) + "%";
                else
                  txt = "Finished!";
            BaseContainer msg(BFM_SETSTATUSBAR);
                msg.SetLong(BFM_STATUSBAR_PROGRESSON, TRUE);
                msg.SetString(BFM_STATUSBAR_TXT, txt);
                msg.SetReal(BFM_STATUSBAR_PROGRESS, m_p);
            SendMessage(SCROLL_GROUP_ID, msg);
            // Wait until render thread is stopped
              void ShutdownThread()
                m_rt.End();
                m_rt.Wait(FALSE);
            // Check if the render is finished
              void CheckFinished()
                  Close(m_result == RAY_OK);
            // Internal class with render thread
              class RenderThread : public Thread
                RenderThread(ModalRenderer* dlg) : m_dlg(dlg) {}
                virtual ~RenderThread() { m_dlg = NULL; End(); Wait(FALSE); }
            virtual void Main()
                  if (!m_dlg) return;
            // Start render
                  LONG result =
                    RenderDocument(m_dlg->m_doc,
                                   ProgressFunction, m_dlg,
                                   m_dlg->m_bmp, m_dlg->m_rdata,
                                   TRUE, m_dlg->m_showerrors, this);
                  if (m_dlg) m_dlg->m_result = result;
            private:
                ModalRenderer* m_dlg;
            // Called by RenderDocument now and then
                static void ProgressFunction(Real p, void* dlg)
                  static_cast<ModalRenderer*>(dlg)->m_p = p;
              } m_rt;
            // So that the internal class can access private variables
              friend class RenderThread;
              On 24/06/2003 at 12:24, xxxxxxxx wrote:
              Just wanted to say that I'm not ignoring this message, but just that I haven't got time right now to write any code right now. (See the docs, "The support team will not write code for you. "... 😉
              Perhaps I'll get time to look into it later and extend the example. Until then you should look into the AsyncTest.cpp example and try to ask more specific questions. Sorry for the inconvenience.
                On 24/06/2003 at 13:00, xxxxxxxx wrote:
                no problem, I understand.  At this point the problem is that when I change both dialogs to GeDialogs the parent dialog closes and nothing happens in the child dialog.  I am just trying to figure out what is going on.  I think it may have something to do with the ID that I am using when calling Open(TRUE, ID, -1, -1) on the child.  I am using the same one as the parent.  Thanks for your time.
                Nate
                  On 24/06/2003 at 13:06, xxxxxxxx wrote:
                  You need a unique ID here from Plugincafe for EACH dialog you are creating. Currently there is no other way afaik.
                    On 24/06/2003 at 13:31, xxxxxxxx wrote:
                    Thanks again, I will try that.  I haven't coded in C++ before (only Ada) so getting use to the syntax and functionality of the language slows me down.
                      On 24/06/2003 at 18:32, xxxxxxxx wrote:
                      Ok, I am going to try and be a little more specific with the problem I am having because I think I have a little better handle on it.  I have a plugin X.  Basically what happens is X is a command plugin that calls a (asynchronous)GeDialog Y.  I can have the Dialog  Y create a layout and render a document with a certain set of settings and cameras.  This works perfectly fine.
                      Now I create another asynchronous GeDialog  Z in the same plugin (Note I give it an unique ID number but its not registered because I only want one option in the plugin menu).  I now make Z get called in CommandData::Execute by Z.Open(TRUE, ZID, -1, -1).  Z gets some inputs from the user and then calls Y.Open(TRUE, YID, -1, -1).  Ok so now when I run this plugin Z works perfectly and Y almost works.  When I call RenderDocument(....) nothing happens.  The weird thing is that it works when I open Y as a modal dialog or Y.Open(FALSE, YID, -1, -1).
                      So what happens is
                      X calls Z
                      Z calls Y
                      Y does everything but Render
                      Any thoughts?
                        On 25/06/2003 at 12:49, xxxxxxxx wrote:
                        I am beginning to think that you can only call a thread from a GeModalDialog (or GeDialog that is not asynchronous) if the thread has RenderDocument() in it.  I mean the dialog will work correctly but thread does not seem to execute RenderDocument or it wont wait until it finishes.
                        Nate
                          On 27/06/2003 at 13:40, xxxxxxxx wrote:
                          Well after going back to scratch and making my plugin more basic I found my problem.  I was closing the parent dialog too soon and not letting the information flow to the child dialog.  Thanks for all of your help.  Sorry for so many questions.
                          Nate
