    Drawing a bitmap inside a dialog
    33 Posts 0 Posters 17.8k Views
      On 15/02/2005 at 07:16, xxxxxxxx wrote:
      I tried to use:
      user_x=GeUserArea(X_PIC,this);
      But I keep getting this error:
      (7) CLASS is not a function
      What can be wrong with it?
      Rui Batista
        On 15/02/2005 at 08:38, xxxxxxxx wrote:
        You have to use 'new' on a class to call the constructor in COFFEE:
        user_x = new(GeUserArea(X_PIC,this));
          On 15/02/2005 at 08:57, xxxxxxxx wrote:
          I still get the same error 😞
          Rui Batista
            On 15/02/2005 at 09:40, xxxxxxxx wrote:
            If you are going to create the GeUserArea programatically and attach to the dialog, you may need to derive your own class and use the code as in the example. My experience with this stuff in COFFEE is limited, so I usually stick with the examples and other existing code when possible. 🙂
              On 15/02/2005 at 09:45, xxxxxxxx wrote:
              No, I'm not going to create a User Area programatically. I simply want to have access to user areas I already defined with Resedit in a dialog resorce. But I think this is excessivelly complicated 😞
              Rui Batista
                On 15/02/2005 at 09:57, xxxxxxxx wrote:
                What´s the problem with using
                new(name of your userarea class,IDC_RUISAREA,this);
                  On 15/02/2005 at 10:03, xxxxxxxx wrote:
                  In ResEdit you only define the UserArea gui, but that won´t create a GeUserArea instance for you. You have to derive your own class from the GeUserArea Base class to get access to it. There is no way around it afaik.
                    On 15/02/2005 at 10:12, xxxxxxxx wrote:
                    Oh, ok... so I still have to derive the class. Damn, its really confusing. No wonder so many people run away from programming 😉
                    I will give it a try. Probably I will only have time tomorrow. Thank you both for the time and effort into helping me out. I will report my success/failure 😉
                    Rui Batista
                      On 16/02/2005 at 12:00, xxxxxxxx wrote:
                      Ok, definetely, I can't seem to make it work. This is what I wrote:
                      class MyUserArea : GeUserArea
                           private:
                                var bbm;
                                MyUserArea(id,dialog);
                                Init();
                                GetUserWidth();
                                GetUserHeight();
                                Draw_Pic(name);
                      MyUserArea::MyUserArea(id,dialog)
                           super(id,dialog);
                      MyUserArea::Init()
                      {var bm_path,bbm;
                           bm_path=GeGetRootFilename();
                           bm_path->RemoveLast();
                           bm_path->AddLast("align_pics");
                           bm_path->AddLast("x01.jpg");
                           bbm=new(BaseBitmap,82,82);
                           bbm->Load(bm_path,0);
                           if(!bbm)
                           println("Error getting a picture.");
                           return;
                      MyUserArea::GetUserWidth()
                           return 82;
                      MyUserArea::GetUserHeight()
                           return 82;
                      MyUserArea::Draw_Pic(name)
                      {var bm_path,bbm;
                          OffScreenOn();
                          SetClippingRegion(x1,y1,x2,y2);
                           name=stradd(name,".jpg");
                           bm_path->AddLast(name);
                           if(!bbm)
                           return;
                           DrawBitmap(bbm,0,0,81,81,0,0,81,81,BMP_NORMAL);
                      class PluginDialog : GeDialog
                      private:
                           var bc;
                           ContainerToDialog();
                           DialogToContainer();
                      PluginDialog();
                      CreateLayout();
                      Init();
                      GetContainer();
                      SetContainer(_bc);
                      Message(msg);
                      Command(id, msg);
                      PluginDialog::PluginDialog()
                           super(PLUGIN_ID);
                           bc = new(BaseContainer);
                      PluginDialog::GetContainer() { return bc->GetClone(); }
                      PluginDialog::SetContainer(_bc) { bc = _bc->GetClone(); }
                      PluginDialog::CreateLayout()
                           return LoadDialogResource(ALIGNER, PLUGIN_RES, 0);
                      Where must I add the
                      Rui Batista
                        On 16/02/2005 at 12:44, xxxxxxxx wrote:
                        In CreateLayout().
                        Try it like this:
                        var retval = LoadDialogResource(ALIGNER, PLUGIN_RES, 0);
                        ua = new(MyUserArea, id, this);
                        return reval;
                        If your user area is defined in the Dialog Resource, then you don't need to AddUserArea(). If not, you must.
                        Don't forget to set the id to the correct value!
                          On 17/02/2005 at 05:17, xxxxxxxx wrote:
                          Well, I'm not getting any errors now, but I'm not getting any picture in the user area either 😞
                          This is a snippet of my code:
                               super(id,dialog);
                          private:
                               var bc;
                               var userx;
                               turn_on_off();
                          PluginDialog();
                          CreateLayout();
                          Init();
                          GetContainer();
                          SetContainer(_bc);
                          Message(msg);
                          Command(id, msg);
                               super(PLUGIN_ID);
                               userx=new(MyUserArea,X_PIC,this);
                               return retval;
                          PluginDialog::Init()
                               bc->SetData(NONE_X,     NONE_X_VAR);
                               bc->SetData(ALIGN_X,     ALIGN_X_VAR);
                               bc->SetData(DISTRIB_X,     DISTRIB_X_VAR);
                               bc->SetData(ADJUST_X,     ADJUST_X_VAR);
                               bc->SetData(NONE_Y,     NONE_Y_VAR);
                               bc->SetData(ALIGN_Y,     ALIGN_Y_VAR);
                               bc->SetData(DISTRIB_Y,     DISTRIB_Y_VAR);
                               bc->SetData(ADJUST_Y,     ADJUST_Y_VAR);
                               bc->SetData(NONE_Z,     NONE_Z_VAR);
                               bc->SetData(ALIGN_Z,     ALIGN_Z_VAR);
                               bc->SetData(DISTRIB_Z,     DISTRIB_Z_VAR);
                               bc->SetData(ADJUST_Z,     ADJUST_Z_VAR);
                               bc->SetData(AMIN_X,     AMIN_X_VAR);
                               bc->SetData(AMED_X,     AMED_X_VAR);
                               bc->SetData(AMAX_X,     AMAX_X_VAR);
                               bc->SetData(MIN_X,     MIN_X_VAR);
                               bc->SetData(MED_X,     MED_X_VAR);
                               bc->SetData(MAX_X,     MAX_X_VAR);
                               bc->SetData(SPACE_X,     SPACE_X_VAR);
                               bc->SetData(OF_X,     OF_X_VAR);
                               bc->SetData(AMIN_Y,     AMIN_Y_VAR);
                               bc->SetData(AMED_Y,     AMED_Y_VAR);
                               bc->SetData(AMAX_Y,     AMAX_Y_VAR);
                               bc->SetData(MIN_Y,     MIN_Y_VAR);
                               bc->SetData(MED_Y,     MED_Y_VAR);
                               bc->SetData(MAX_Y,     MAX_Y_VAR);
                               bc->SetData(SPACE_Y,     SPACE_Y_VAR);
                               bc->SetData(OF_Y,     OF_Y_VAR);
                               bc->SetData(AMIN_Z,     AMIN_Z_VAR);
                               bc->SetData(AMED_Z,     AMED_Z_VAR);
                               bc->SetData(AMAX_Z,     AMAX_Z_VAR);
                               bc->SetData(MIN_Z,     MIN_Z_VAR);
                               bc->SetData(MED_Z,     MED_Z_VAR);
                               bc->SetData(MAX_Z,     MAX_Z_VAR);
                               bc->SetData(SPACE_Z,     SPACE_Z_VAR);
                               bc->SetData(OF_Z,     OF_Z_VAR);
                               bc->SetData(USE_GROUP,     USE_GROUP_VAR);
                               turn_on_off();
                          PluginDialog::turn_on_off()
                          {var a_x,a_y,a_z,str;
                               var bm_path,bbm;
                               if(!bbm)
                               println("Error getting a picture. Make sure the 'align_pics' folder is located in the same folder as the 'Aligner.cob' file.");
                               return;
                               userx->DrawBitmap(bbm,0,0,81,81,0,0,81,81,BMP_NORMAL);
                               userx->Redraw();
                               if(NONE_X_VAR)
                               Enable(AMIN_X,FALSE);
                               Enable(AMED_X,FALSE);
                               Enable(AMAX_X,FALSE);
                               Enable(MIN_X,FALSE);
                               Enable(MED_X,FALSE);
                               Enable(MAX_X,FALSE);
                               Enable(OF_X_TXT,FALSE);
                               Enable(OF_X,FALSE);
                               Enable(SPACE_X,FALSE);
                               if(NONE_Y_VAR)
                          How do I place pictures in there, now?
                          You guys are being a great help. Thank you 🙂
                          Rui Batista
                            On 17/02/2005 at 05:29, xxxxxxxx wrote:
                            call your UserArea Draw function and call the member function DrawBitmap(...) to draw your image.
                            See the example kuro posted
                              On 17/02/2005 at 06:20, xxxxxxxx wrote:
                              Know what? Its not working yet. I just have to type:
                              userx->Draw(0,0,81,81)
                              right?
                              Isn't working 😞
                              Rui Batista
                                On 17/02/2005 at 06:27, xxxxxxxx wrote:
                                no, you have to do it like this:
                                MyUserArea::Draw(x1,y1,x2,y2)
                                     OffScreenOn();
                                     DrawBitmap(your_bitmap, 0, 0, 81, 81, 0, 0, 81, 81, BMP_NORMAL);
                                  On 17/02/2005 at 06:31, xxxxxxxx wrote:
                                  I did, Samir. But I'm drawing it by calling userx->Draw(0,0,81,81); from inside my dialog routines. Or, how should I draw it?
                                  Rui Batista
                                    On 17/02/2005 at 06:36, xxxxxxxx wrote:
                                    ? you don´t need to call it seperately. Once you call the Draw method as I posted it, it will be drawn. If you change the bitmap, all you need to do is redrawing the userarea with userx->Redraw();
                                      On 17/02/2005 at 06:56, xxxxxxxx wrote:
                                      Well, the Draw method is never called. I placed a println in there and nothing is printed to the Console 😞
                                      Want me to send you the listing?
                                      Rui Batista
                                        On 17/02/2005 at 07:00, xxxxxxxx wrote:
                                        yeah, send it over.
                                          On 17/02/2005 at 07:30, xxxxxxxx wrote:
                                          Thank you. I just send it over to your mail 🙂
                                          Rui Batista
                                            On 17/02/2005 at 07:49, xxxxxxxx wrote:
                                            Hey, you guys are having way to much fun without me! 🙂
                                            Actually getting the GeUserArea to Draw() is the tricky part. As you can see by my code, I just 'force' a draw in the GeUserArea Init() method.
                                            Let me know how it turns out.
