    Drawing a bitmap inside a dialog
    33 Posts 0 Posters 18.2k Views
      On 14/02/2005 at 10:49, xxxxxxxx wrote:
      Okay, Rui,
      Try the relevant sections of this code (modified "Async Bounce.cof"). Seems to load my "about.jpg" image. Amazing! 🙂
      (using v8.012 to keep it near version)
      var PLUGIN_ID = 910000;
      // global variables
      var col,speed;
      var text;
      // definition of my user area
      class MyUserArea : GeUserArea
           private:
                var bbm;
                MyUserArea(id,dialog);
                Init();
                GetUserWidth();
                GetUserHeight();
                Draw(x1,y1,x2,y2);
      MyUserArea::MyUserArea(id,dialog)
           super(id,dialog);
      MyUserArea::Init()
           var filename = GeGetRootFilename();
           filename->RemoveLast();
           filename->AddLast("about.jpg");
           bbm = new(BaseBitmap, 256,256);
           bbm->Load(filename, 0);
           println(filename->GetFullString());
           Redraw();
      MyUserArea::GetUserWidth()
           return 256;
      MyUserArea::GetUserHeight()
           return 256;
      MyUserArea::Draw(x1,y1,x2,y2)
           OffScreenOn();
           SetClippingRegion(x1,y1,x2,y2);
           DrawBitmap(bbm, 0, 0, 255, 255, 0, 0, 255, 255, BMP_NORMAL);
      // definition of my Dialog class
      class MyDialog : GeDialog
           private:
                var ua;
                MyDialog();
                CreateLayout();
                Init();
                Command(id,msg);
      MyDialog::MyDialog()
           super(PLUGIN_ID);
           ua=NULL;
      MyDialog::CreateLayout()
           SetTitle("Bitmap");
           AddUserArea(5000,BFH_SCALEFIT|BFH_SCALEFIT,0,0);
           AddGroupBeginV(4000,0,3,"Group",0);
                AddStaticText (4001,BFH_FIT,0,0,"Name",0);
                AddEditText   (4002,BFH_FIT,0,0);
                AddCheckbox   (4003,BFH_FIT,0,0,"Test");
                AddStaticText (4004,BFH_FIT,0,0,"Speed",0);
                AddEditNumber (4005,BFH_FIT,70,0);
                AddStaticText (4001,BFH_FIT,0,0,"",0);
                AddStaticText (4006,BFH_FIT,0,0,"Color",0);
                AddColorField (4007,BFH_FIT,120,13);
           AddGroupEnd();
           AddRadioGroupV(7000,0,2);
           AddItem(7000,6000,"Test a");
           AddItem(7000,6001,"aha");
           AddItem(7000,6002,"bha");
           AddItem(7000,6003,"Test n");
           ua = new(MyUserArea,5000,this);
      MyDialog::Init()
           SetString (4002,text);
           SetCheckbox(4003,TRUE);
           SetPercent (4005,speed,0.0,100.0,1.0);
           SetColorField(4007,col);
           SetItem(7000,6002);
      MyDialog::Command(id,msg)
           switch (id)
                case 4005: speed = GetPercent(id); break;
                case 4007: col   = GetColor(id); break;
                case 4002: text = GetString(id); break;
      class MyMenuPlugin : MenuPlugin
                MyMenuPlugin();
                GetID();
                GetName();
                GetHelp();
                Execute(doc);
                RestoreLayout(secret,subid);
      MyMenuPlugin::MyMenuPlugin()
           super();
      MyMenuPlugin::GetID()
           return PLUGIN_ID;
      MyMenuPlugin::GetName()
           return "Async Bounce";
      MyMenuPlugin::GetHelp()
           return "Shows programming of async dialogs with timer events";
      var d;
      MyMenuPlugin::Execute(doc)
           d->Open(TRUE,-1,-1);
      MyMenuPlugin::RestoreLayout(secret,subid)
           if (!d) d = new(MyDialog);
           d->RestoreLayout(secret);
           d = new(MyDialog);
           col   = vector(1,0,0);
           speed = 50.0;
           text = "o";
           Register(MyMenuPlugin);
      Good luck - let me know if it works for you.
        On 14/02/2005 at 10:55, xxxxxxxx wrote:
        Should mention that there is a post where the code breaks in 8.5. If you have 8.5 or 9.0, try it there as well to see if it still displays the bitmap.
          On 14/02/2005 at 18:02, xxxxxxxx wrote:
          Well, the problem with it is that I don't know how to make it work with a dialog that is loaded from a resorce and where the User Areas are already defined. In your example (I had already found the "Async Bounce.cof" file) we define, manualy, our own User Area. In my example, I have three User Areas, defined with Resedit.
          Rui Batista
            On 14/02/2005 at 18:41, xxxxxxxx wrote:
            Hi Rui,
            all you then need to do is allocate the userarea that should be attached to your userarea fields.
            So if you defined a UA in ResEdit with the ID "IDC_RUISAREA" for example, you need to call
            ua = new(MyUserArea,IDC_RUISAREA,this);
              On 14/02/2005 at 18:44, xxxxxxxx wrote:
              Mmmmm, I will give it a try. What I can't understand is that is the "this" variable.
              Rui Batista
                On 14/02/2005 at 18:51, xxxxxxxx wrote:
                Hey Rui,
                if you look into the COFFEE docs you can see the constructor of the class:
                GeUserArea([int] id, [GeBaseDialog] dialog);
                id = IDC_RUISAREA
                and
                dialog = this
                "this" is the pointer of the class it´s used in. (in this case a pointer to your dialog)
                  On 15/02/2005 at 07:16, xxxxxxxx wrote:
                  I tried to use:
                  user_x=GeUserArea(X_PIC,this);
                  But I keep getting this error:
                  (7) CLASS is not a function
                  What can be wrong with it?
                  Rui Batista
                    On 15/02/2005 at 08:38, xxxxxxxx wrote:
                    You have to use 'new' on a class to call the constructor in COFFEE:
                    user_x = new(GeUserArea(X_PIC,this));
                      On 15/02/2005 at 08:57, xxxxxxxx wrote:
                      I still get the same error 😞
                      Rui Batista
                        On 15/02/2005 at 09:40, xxxxxxxx wrote:
                        If you are going to create the GeUserArea programatically and attach to the dialog, you may need to derive your own class and use the code as in the example. My experience with this stuff in COFFEE is limited, so I usually stick with the examples and other existing code when possible. 🙂
                          On 15/02/2005 at 09:45, xxxxxxxx wrote:
                          No, I'm not going to create a User Area programatically. I simply want to have access to user areas I already defined with Resedit in a dialog resorce. But I think this is excessivelly complicated 😞
                          Rui Batista
                            On 15/02/2005 at 09:57, xxxxxxxx wrote:
                            What´s the problem with using
                            new(name of your userarea class,IDC_RUISAREA,this);
                              On 15/02/2005 at 10:03, xxxxxxxx wrote:
                              In ResEdit you only define the UserArea gui, but that won´t create a GeUserArea instance for you. You have to derive your own class from the GeUserArea Base class to get access to it. There is no way around it afaik.
                                On 15/02/2005 at 10:12, xxxxxxxx wrote:
                                Oh, ok... so I still have to derive the class. Damn, its really confusing. No wonder so many people run away from programming 😉
                                I will give it a try. Probably I will only have time tomorrow. Thank you both for the time and effort into helping me out. I will report my success/failure 😉
                                Rui Batista
                                  On 16/02/2005 at 12:00, xxxxxxxx wrote:
                                       private:
                                            var bbm;
                                            Init();
                                            GetUserWidth();
                                            GetUserHeight();
                                            Draw_Pic(name);
                                       super(id,dialog);
                                  MyUserArea::Init()
                                  {var bm_path,bbm;
                                       bm_path=GeGetRootFilename();
                                       bm_path->RemoveLast();
                                       bm_path->AddLast("align_pics");
                                       bm_path->AddLast("x01.jpg");
                                       bbm=new(BaseBitmap,82,82);
                                       bbm->Load(bm_path,0);
                                       if(!bbm)
                                       println("Error getting a picture.");
                                       return;
                                       return 82;
                                       return 82;
                                  MyUserArea::Draw_Pic(name)
                                  {var bm_path,bbm;
                                      OffScreenOn();
                                       name=stradd(name,".jpg");
                                       bm_path->AddLast(name);
                                       if(!bbm)
                                       return;
                                       DrawBitmap(bbm,0,0,81,81,0,0,81,81,BMP_NORMAL);
                                  class PluginDialog : GeDialog
                                  private:
                                       var bc;
                                       ContainerToDialog();
                                       DialogToContainer();
                                  PluginDialog();
                                  CreateLayout();
                                  Init();
                                  GetContainer();
                                  SetContainer(_bc);
                                  Message(msg);
                                  Command(id, msg);
                                  PluginDialog::PluginDialog()
                                       super(PLUGIN_ID);
                                       bc = new(BaseContainer);
                                  PluginDialog::GetContainer() { return bc->GetClone(); }
                                  PluginDialog::SetContainer(_bc) { bc = _bc->GetClone(); }
                                  PluginDialog::CreateLayout()
                                       return LoadDialogResource(ALIGNER, PLUGIN_RES, 0);
                                  Where must I add the
                                  Rui Batista
                                    On 16/02/2005 at 12:44, xxxxxxxx wrote:
                                    In CreateLayout().
                                    Try it like this:
                                    var retval = LoadDialogResource(ALIGNER, PLUGIN_RES, 0);
                                    ua = new(MyUserArea, id, this);
                                    return reval;
                                    If your user area is defined in the Dialog Resource, then you don't need to AddUserArea(). If not, you must.
                                    Don't forget to set the id to the correct value!
                                      On 17/02/2005 at 05:17, xxxxxxxx wrote:
                                      Well, I'm not getting any errors now, but I'm not getting any picture in the user area either 😞
                                      This is a snippet of my code:
                                           super(id,dialog);
                                      private:
                                           var bc;
                                           var userx;
                                           turn_on_off();
                                      PluginDialog();
                                      CreateLayout();
                                      Init();
                                      GetContainer();
                                      SetContainer(_bc);
                                      Message(msg);
                                      Command(id, msg);
                                           super(PLUGIN_ID);
                                           userx=new(MyUserArea,X_PIC,this);
                                           return retval;
                                      PluginDialog::Init()
                                           bc->SetData(NONE_X,     NONE_X_VAR);
                                           bc->SetData(ALIGN_X,     ALIGN_X_VAR);
                                           bc->SetData(DISTRIB_X,     DISTRIB_X_VAR);
                                           bc->SetData(ADJUST_X,     ADJUST_X_VAR);
                                           bc->SetData(NONE_Y,     NONE_Y_VAR);
                                           bc->SetData(ALIGN_Y,     ALIGN_Y_VAR);
                                           bc->SetData(DISTRIB_Y,     DISTRIB_Y_VAR);
                                           bc->SetData(ADJUST_Y,     ADJUST_Y_VAR);
                                           bc->SetData(NONE_Z,     NONE_Z_VAR);
                                           bc->SetData(ALIGN_Z,     ALIGN_Z_VAR);
                                           bc->SetData(DISTRIB_Z,     DISTRIB_Z_VAR);
                                           bc->SetData(ADJUST_Z,     ADJUST_Z_VAR);
                                           bc->SetData(AMIN_X,     AMIN_X_VAR);
                                           bc->SetData(AMED_X,     AMED_X_VAR);
                                           bc->SetData(AMAX_X,     AMAX_X_VAR);
                                           bc->SetData(MIN_X,     MIN_X_VAR);
                                           bc->SetData(MED_X,     MED_X_VAR);
                                           bc->SetData(MAX_X,     MAX_X_VAR);
                                           bc->SetData(SPACE_X,     SPACE_X_VAR);
                                           bc->SetData(OF_X,     OF_X_VAR);
                                           bc->SetData(AMIN_Y,     AMIN_Y_VAR);
                                           bc->SetData(AMED_Y,     AMED_Y_VAR);
                                           bc->SetData(AMAX_Y,     AMAX_Y_VAR);
                                           bc->SetData(MIN_Y,     MIN_Y_VAR);
                                           bc->SetData(MED_Y,     MED_Y_VAR);
                                           bc->SetData(MAX_Y,     MAX_Y_VAR);
                                           bc->SetData(SPACE_Y,     SPACE_Y_VAR);
                                           bc->SetData(OF_Y,     OF_Y_VAR);
                                           bc->SetData(AMIN_Z,     AMIN_Z_VAR);
                                           bc->SetData(AMED_Z,     AMED_Z_VAR);
                                           bc->SetData(AMAX_Z,     AMAX_Z_VAR);
                                           bc->SetData(MIN_Z,     MIN_Z_VAR);
                                           bc->SetData(MED_Z,     MED_Z_VAR);
                                           bc->SetData(MAX_Z,     MAX_Z_VAR);
                                           bc->SetData(SPACE_Z,     SPACE_Z_VAR);
                                           bc->SetData(OF_Z,     OF_Z_VAR);
                                           bc->SetData(USE_GROUP,     USE_GROUP_VAR);
                                           turn_on_off();
                                      PluginDialog::turn_on_off()
                                      {var a_x,a_y,a_z,str;
                                           var bm_path,bbm;
                                           if(!bbm)
                                           println("Error getting a picture. Make sure the 'align_pics' folder is located in the same folder as the 'Aligner.cob' file.");
                                           return;
                                           userx->DrawBitmap(bbm,0,0,81,81,0,0,81,81,BMP_NORMAL);
                                           userx->Redraw();
                                           if(NONE_X_VAR)
                                           Enable(AMIN_X,FALSE);
                                           Enable(AMED_X,FALSE);
                                           Enable(AMAX_X,FALSE);
                                           Enable(MIN_X,FALSE);
                                           Enable(MED_X,FALSE);
                                           Enable(MAX_X,FALSE);
                                           Enable(OF_X_TXT,FALSE);
                                           Enable(OF_X,FALSE);
                                           Enable(SPACE_X,FALSE);
                                           if(NONE_Y_VAR)
                                      How do I place pictures in there, now?
                                      You guys are being a great help. Thank you 🙂
                                      Rui Batista
                                        On 17/02/2005 at 05:29, xxxxxxxx wrote:
                                        call your UserArea Draw function and call the member function DrawBitmap(...) to draw your image.
                                        See the example kuro posted
                                          On 17/02/2005 at 06:20, xxxxxxxx wrote:
                                          Know what? Its not working yet. I just have to type:
                                          userx->Draw(0,0,81,81)
                                          right?
                                          Isn't working 😞
                                          Rui Batista
                                            On 17/02/2005 at 06:27, xxxxxxxx wrote:
                                            no, you have to do it like this:
                                                 OffScreenOn();
                                                 DrawBitmap(your_bitmap, 0, 0, 81, 81, 0, 0, 81, 81, BMP_NORMAL);
