    SplineObject::ResizeObject help
    14 Posts 0 Posters 1.1k Views
      On 12/11/2004 at 11:39, xxxxxxxx wrote:
      did you call oSpline->Message(MSG_CHANGE); ? This is always necessary when modifying pointdata.
        On 12/11/2004 at 11:55, xxxxxxxx wrote:
        Yeah, I tried that
        This is the full code that i'm trying to work
             // Find Spline Object (This object is a empty spline)
             SplineObject *oSpline = (SplineObject* )hh->GetDocument()->SearchObject("Spline");
             if(!oSpline) return NULL;
             // Resize the Spline to have 10 points
             oSpline->ResizeObject(10,1);
             // Move the points
             for(LONG i=0; i < 10; i++)
                  Vector *vadr = oSpline->GetPoint();
                  vadr _= Vector(0.0,0.0,i*50.0);
             oSpline->Message(MSG_UPDATE);
        The thing that confuses me is that the points seem to be there (even though I can't see them), but I cannot access them with any of the C4D tools. Using live selection tool for example, actually highlights the points, but as soon as I release the mouse button, they de-select themselves
          On 12/11/2004 at 12:13, xxxxxxxx wrote:
          your code seems to be a bit wrong. It should look like this:
                **oSpline- >Message(MSG_CHANGE);** //Call it after resizing
               // Move the points
                **Vector *vadr = oSpline- >GetPoint();** //Get points already here (performance)
                    vadr **[ i ]** = Vector(0.0,0.0,i*50.0); //Missing index
            On 12/11/2004 at 14:35, xxxxxxxx wrote:
            It was a bit wrong because i typed it up and was rushing 🙂
            the only difference I did was I didnt do the message after resize. will try that next!
              On 12/11/2004 at 14:57, xxxxxxxx wrote:
              Howdy,
              I know this may look wrong but try changing your resize line to this:
              oSpline->ResizeObject(10,0);
              Adios,
              Cactus Dan
                On 12/11/2004 at 16:18, xxxxxxxx wrote:
                Quote: Originally posted by Cactus Dan on 12 November 2004
                > Howdy,
                > oSpline- >ResizeObject(10,0);
                > Adios,
                > Cactus Dan
                THANK YOU!
                I thought it was me going crazy. Everything I tried wouldn't, but I never imagined resizing the spline with 0 segments would of worked.
                Thanks for your help people, works a charm 🙂
                  On 12/11/2004 at 16:38, xxxxxxxx wrote:
                  Howdy,
                  I struggled for a long time with the same thing. One segment seemed more logical to me, but then I did a GetSegmentCount() beforehand and printed the result and it displayed the number 0.
                  Adios,
                  Cactus Dan
                    On 12/11/2004 at 18:59, xxxxxxxx wrote:
                    Good point. Haven´t thought of this myself. 🙂
                      On 13/11/2004 at 09:13, xxxxxxxx wrote:
                      Howdy,
                      > Quote: Originally posted by 3D Designer on 12 November 2004
                      Actually, I started using it like this:
                      LONG seg = oSpline- >GetSegmentCount();
                      oSpline->ResizeObject(10, seg);
                      That way I avoid any confusion on my part.
                      Adios,
                      Cactus Dan
                        On 13/11/2004 at 09:56, xxxxxxxx wrote:
                        Yeah, but it´s anyway not really logical. It´s plausible that if it is no multi-segment spline the count is unnecessary and is set to 0 but it would be more logical if one had to pass 1.
                        Anyway, I am not using this at all but always use the VariableChanged class, so I haven´t gotten into this problem yet either. 🙂
                          On 13/11/2004 at 10:27, xxxxxxxx wrote:
                          Howdy,
                          Hey, thanks for the tip. I wasn't aware of that class. It looks like a good one to know.
                          Adios,
                          Cactus Dan
