    SplineObject::ResizeObject help
    14 Posts 0 Posters 1.5k Views
      On 12/11/2004 at 11:35, xxxxxxxx wrote:
      Hi 3D Designer.
      Thing is, I HAVE moved them to another spot in the 3D world. But the spline doesn't show in the viewport, nor does any of the control points.
      It's fine if I create the spline object with default point count in the constructer, but after I Resize it, all points just dissappear.
        On 12/11/2004 at 11:39, xxxxxxxx wrote:
        did you call oSpline->Message(MSG_CHANGE); ? This is always necessary when modifying pointdata.
          On 12/11/2004 at 11:55, xxxxxxxx wrote:
          Yeah, I tried that
          This is the full code that i'm trying to work
               // Find Spline Object (This object is a empty spline)
               SplineObject *oSpline = (SplineObject* )hh->GetDocument()->SearchObject("Spline");
               if(!oSpline) return NULL;
               // Resize the Spline to have 10 points
               oSpline->ResizeObject(10,1);
               // Move the points
               for(LONG i=0; i < 10; i++)
                    Vector *vadr = oSpline->GetPoint();
                    vadr _= Vector(0.0,0.0,i*50.0);
               oSpline->Message(MSG_UPDATE);
          The thing that confuses me is that the points seem to be there (even though I can't see them), but I cannot access them with any of the C4D tools. Using live selection tool for example, actually highlights the points, but as soon as I release the mouse button, they de-select themselves
            On 12/11/2004 at 12:13, xxxxxxxx wrote:
            your code seems to be a bit wrong. It should look like this:
                  **oSpline- >Message(MSG_CHANGE);** //Call it after resizing
                 // Move the points
                  **Vector *vadr = oSpline- >GetPoint();** //Get points already here (performance)
                      vadr **[ i ]** = Vector(0.0,0.0,i*50.0); //Missing index
              On 12/11/2004 at 14:35, xxxxxxxx wrote:
              It was a bit wrong because i typed it up and was rushing 🙂
              the only difference I did was I didnt do the message after resize. will try that next!
                On 12/11/2004 at 14:57, xxxxxxxx wrote:
                Howdy,
                I know this may look wrong but try changing your resize line to this:
                oSpline->ResizeObject(10,0);
                Adios,
                Cactus Dan
                  On 12/11/2004 at 16:18, xxxxxxxx wrote:
                  Quote: Originally posted by Cactus Dan on 12 November 2004
                  > Howdy,
                  > oSpline- >ResizeObject(10,0);
                  > Adios,
                  > Cactus Dan
                  THANK YOU!
                  I thought it was me going crazy. Everything I tried wouldn't, but I never imagined resizing the spline with 0 segments would of worked.
                  Thanks for your help people, works a charm 🙂
                    On 12/11/2004 at 16:38, xxxxxxxx wrote:
                    Howdy,
                    I struggled for a long time with the same thing. One segment seemed more logical to me, but then I did a GetSegmentCount() beforehand and printed the result and it displayed the number 0.
                    Adios,
                    Cactus Dan
                      On 12/11/2004 at 18:59, xxxxxxxx wrote:
                      Good point. Haven´t thought of this myself. 🙂
                        On 13/11/2004 at 09:13, xxxxxxxx wrote:
                        Howdy,
                        > Quote: Originally posted by 3D Designer on 12 November 2004
                        Actually, I started using it like this:
                        LONG seg = oSpline- >GetSegmentCount();
                        oSpline->ResizeObject(10, seg);
                        That way I avoid any confusion on my part.
                        Adios,
                        Cactus Dan
                          On 13/11/2004 at 09:56, xxxxxxxx wrote:
                          Yeah, but it´s anyway not really logical. It´s plausible that if it is no multi-segment spline the count is unnecessary and is set to 0 but it would be more logical if one had to pass 1.
                          Anyway, I am not using this at all but always use the VariableChanged class, so I haven´t gotten into this problem yet either. 🙂
                            On 13/11/2004 at 10:27, xxxxxxxx wrote:
                            Howdy,
                            Hey, thanks for the tip. I wasn't aware of that class. It looks like a good one to know.
                            Adios,
                            Cactus Dan
