    math: project point on a poly
    14 Posts 0 Posters 1.2k Views
      On 11/06/2004 at 09:43, xxxxxxxx wrote:
      the solution of your problem is very difficult:
      it is ease to do this with a Plain and a Point, because a plane has infinite extension. but in your case you have to check the bounds (edges) of your poly. Another problem is that that a poly can also be nonplanar, so you have to do this with triangles, they are always planar!
      btw: I don´t know any function in the sdk that does your thing!
        On 11/06/2004 at 10:34, xxxxxxxx wrote:
        well,thanks for your answer..
        your probably right, especially about the poly vs triangle thing..
        ..didnt think of that before x-|
        what i am actually trying to do with my plugin
        is make a multispline stick to a deformable mesh..
        like when i make a spline-beard around a poly selection
        and then make some facial expression morphing with the head, the beard stays attached to the poly-selection..
        well maybe there's another solution somewhere..
        or somebody else already did it!
        thanks anyway,
        and have a good time all,
        devel
          On 11/06/2004 at 11:24, xxxxxxxx wrote:
          Don't 100% understand the question, but maybe you could use the GeRayCollider class.
          Its a class used to check if a ray has intersected a polygon, and it returns a whole great deal of information, the point of intersection, the polygons normal, etc
          The xpresso ray collider node is very useful to experiment with
            On 11/06/2004 at 12:03, xxxxxxxx wrote:
            thanks ill read it up in the manual and play around some,
            but it looks like it can only check collision between ray(line) and object and i need to check collision ray/poly..
            --edit---
            ..should have read the manual BEFORE posting...
            looks like the node can return the poly that was hit by the ray...
            so thanks again, looks like this might work! 😄
            devel
              On 11/06/2004 at 12:18, xxxxxxxx wrote:
              Yes its for object, but objects are made out of polygons right?
              Its also not that hard to check if a point is inside a polygon, there are many ways to do it.
              http://www.gametutorials.com/Tutorials/opengl/OpenGL_Pg3.htm
              I learn't all I know about polygon detection from that site
              1. Line Segment and Plane Collision
              2. Line Segment and Polygon Collision
              The source code contains a very good explaination on what is happening. Its easy to convert into c4d too, because sdk already has great vector operations 🙂
                On 11/06/2004 at 14:00, xxxxxxxx wrote:
                thanks, i'll check it out..
                  what i understood is that you need something that always stays at the same place on top of a (deformable) surface, right? In my opinion you should do this with the uv-coordinates of the poly. else you are getting problems with the right position when the shape of the poly is changing! I don´t know if there is any function in the sdk that extracts you the 3d-coordinates with the input of a poly and the uv-coordinates!
                    On 12/06/2004 at 02:07, xxxxxxxx wrote:
                    hmm, sounds like a good idea..
                    i'm not quite sure how to do it right now,
                    but im im just gonna play around with uv now, might
                    turn out to be easier than what i had in mind first..
                    thanks for the hint,
                    devel
                      On 12/06/2004 at 02:46, xxxxxxxx wrote:
                      bad idea. This would require the object to always have accurate UV coords which is not always the case (some don´t even have any UVs assigned)
                        On 12/06/2004 at 02:55, xxxxxxxx wrote:
                        yeah thats right,
                        but i actually need this plugin for my fully textured head (with complete uvw's), so that shouldnt be a problem..
                        on the other hand, that wouldnt make it very handy in terms of general usefulness (e.g. for other people) i guess...
                        well, so how'd you do it?
                        the problem is indeed to get the right coordinate on the poly, when the mesh has deformed..
                        greetings,
                        devel
                          On 12/06/2004 at 03:05, xxxxxxxx wrote:
                          Well, actually I already did this ;o) I am using this for my own plugin DPInstantTree (for it now has hair support) and so I wrote such a plugin some days ago. I am triangulating the object and then calculate the initial position on the triangle (as written a tri is always planar) and stick it to this position. Actually not that complicated. Do a google search for the position in a triangle. It´s more than easy.
                          Good luck
                            On 12/06/2004 at 03:06, xxxxxxxx wrote:
                            when deforming the barrycentric coords of the poly do change too (maybe maxx meant these coords by uv coords) so it works here too.
                              On 12/06/2004 at 03:21, xxxxxxxx wrote:
                              alright thanks Samir,
                              gonna check it out..
                              greetings,
                              devel
